AEM water injection is a waste, I would get something better like Aquamist or not do it at all. You will only see marginal benefits. AEM wideband, way better products out there for the money look into the Innovate LC-1.
drop the powerlab kit and get the Momentum or Boosted Performance.
momentum pretty much copied powerlab..and use cheaper stuff if u compare it really..smaller intercooler..piping looks like ****..everything else is basically the same..plus i got a lot lot less for the full kit...im not even gunna say on here lol...
Innovate, defi makes really good gauges in amber to match the interior cluster gauges for that oem look. Look into the package deals
drop mishimoto's fan shroud from the list/oem fans are better
the only reason i got the fans in cause it was all one package deal..cost me less to get it all then just to buy the radiator from anyone else..but really??
Im serious. I had the mishimoto fans and they werent keeping my car cool enough in the summer last year. You do know that they only have one speed and most people that run them end up replacing the idle fan with a bigger one?
I have no compains about the mishimoto radiator thus far.
agreed on the wideband setup..il look into the aqua mist..just running 8 pounds of boost i just wanted to run it safer on stock block is all
Not much to say that hasn't been said i agree with everything the others said, I wouldn't cheap out on meth kit or wide band they help keep your car alive.
Just plan for the build now..forget about water injection. Its not gonna prevent anything..the stock block will fail, its just a matter when its going to happen.
My OEM fans, did crap for me last summer in TX heat. I saw temps abover 240. since then I've gotten a vented hood (which dropped down 10 degrees) then the mishimoto shroud with a 14 inch spal fan wired to a pwm, and a 12inch mr gasket fan wired into the factory harness and I stay around 200 degrees and we've already had temps in the 98-100s already. Was it the most cost effective method...not sure. but, in my case, OEM fans were not sufficient.
I already bouht everything on list excpet for wide band and boostcooler...i just dont get y somone would say go with turbonetics or momentum kit...please give me a good reason y i would do that..
