More turbo kit options (all new kit from BP)
Old 02-21-2012, 06:41 PM
  #41
MDHRZ
MDHRZ's Avatar
Quality work indeed. Are you still experimenting with the HR single?
Old 02-21-2012, 06:58 PM
  #42
Boosted Performance
Vendor - Former Vendor
Boosted Performance's Avatar
With the 370Z arriving for all of April, I will rather busy. Also trying to get this system done and ready to go for some testing. The 76mm turbo kit will be finished up in the next couple of weeks, so we can get some solid numbers out of that.
Old 02-21-2012, 08:04 PM
  #43
jdepe
jdepe's Avatar
looks good sasha
Old 02-22-2012, 12:11 AM
  #44
juicinjake
juicinjake's Avatar
Originally Posted by binder
QSV is 3/4" thick and there still is an actuator to take up room. In that location it would be hard to fit if not impossible. At minimum it would require a complete rebuild of the hotside piping.
QSV will NOT work on divided header systems. They work on a single header input system going into a divided housing only. It diverts all the exhaust into one scroll at first for fast spool. With separate chambers going to separate scrolls the valve would just close off one entire exhaust bank which means bad news.
The original BP kit with a twin scroll turbo would be perfect for a QSV setup.
thanks! that clears up any questions and concerns i had... good info!
Old 02-22-2012, 05:56 PM
  #45
xilovelsdx
xilovelsdx's Avatar
How much lower is the housing than the chassis?
Old 02-22-2012, 06:11 PM
  #46
Boosted Performance
It is not, there is a fair bit of room on that side.
Old 02-22-2012, 06:41 PM
  #47
Boosted Performance
Got a bit more work done the last couple of days.
Port matching: perfect..and everything gets back purged (the proper way to weld tubing) with argon to ensure very smooth joints
on the inside. No back purge= "sugaring" on the inside
Any time two solid exhaust banks are joined together a flex pipe is a MUST, so the passenger side looks like so:
Random shot..
All welded up on the outside:
Passenger side wastegate location:
Driver side wastegate location:
The whole thing comes off by removing 6 header bolts and one V-band clamp...not bad. Will try to make the oil lines easy
remove as well. So in case transmission servicing is needed this will be very easy to remove.
Passenger side 3-bolt flange will be the last thing to get welded do to things moving during welding. This ensures perfect fitment.
The two wastegates will join on the driver side where the transmission ends. Then the single 2" dump tube will be routed in to the down pipe. This will be an option (and will cost extra) once this kit is available for purchase because it requires extra piping, two extra flex couplers and is a PITA to build.
Old 02-22-2012, 06:58 PM
  #48
MDK
MDK's Avatar
That is a work of art. Congratulations!
Eagerly awaiting power figures.
Old 02-22-2012, 08:01 PM
  #49
MI 35th
OGPremierMafia
MI 35th's Avatar
I honestly am always amazed by the quality of your work. This is one of those things I look at and think man I'm glad I bought from that guy!
Old 02-23-2012, 05:23 AM
  #50
VQ35deMax
VQ35deMax's Avatar
Would an open-dump option be available for the wastegates?
Looks great though.
Old 02-23-2012, 05:42 AM
  #51
Boosted Performance
Looks great though.
Open dump would be standard, and recirculated would be the optioin.
Old 02-23-2012, 06:49 AM
  #52
NismoZ#1033
NismoZ#1033's Avatar
Originally Posted by Boosted Performance
I gotta check this out once its all finished
Old 02-23-2012, 09:52 AM
  #53
str8dum1
str8dum1's Avatar
well so far twin scroll trumps powerlab copy cat
Old 02-23-2012, 10:05 AM
  #54
Boosted Performance
I keep it original..
Old 02-23-2012, 10:25 AM
  #55
str8dum1
str8dum1's Avatar
well after Jtran's shop.
Old 02-23-2012, 10:59 AM
  #56
Boosted Performance
Piping is different, and the tubes are equal length, utilizing the twin scroll a bit more efficiently...the location is the same. You also don't have to drop the transmission to install it.
I expected you to mention that build.
Old 02-23-2012, 12:36 PM
  #57
str8dum1
str8dum1's Avatar
just busting your *****. i surprised by the lack of flex pipe in the Xover on the other kits honestly.
Old 02-23-2012, 01:25 PM
  #58
Boosted Performance
All good...
And yes, I don't get that either. It only costs $30 and does so much when things heat up, and during the install.
Old 02-25-2012, 09:56 AM
  #59
Boosted Performance
For all you kids that like it loud:
Old 02-25-2012, 10:58 AM
  #60
nismonian
nismonian's Avatar
looks too good to be hidden!
Quick Reply: More turbo kit options (all new kit from BP)
