My g37s build single turbo 550 whp
Old 07-23-2012, 09:47 AM
gotboost1099
gotboost1099's Avatar
Default My g37s build single turbo 550 whp
So I've been holding out on showing progress of this build because I was kicking around the idea of mass producing the kit, but it's just plain to much work to sell it cheap enough for people to buy a kit not made by gtm greddy hks ect. Anways here's my 2009 g37s 6 speed 50k miles I'm using a ball bearing billet wheel 67mm turbo from on 3 performance along with their 44 mm Wastegate. I fabricated a custom transmisson crossmember to mount the turbo and fit the air filter right on the turbo. I'm building a aluminum air box around the filter to protect from water and dirt. Here's pics so far please feel free to comment wi suggestions criticism.
Old 07-24-2012, 09:24 AM
Highway Riding
Highway Riding's Avatar
Interesting.. GL from another NJ bro!
Old 07-24-2012, 09:29 AM
Ztouring04
Ztouring04's Avatar
Nice
Old 07-24-2012, 10:05 AM
konrad
konrad's Avatar
Looks good so far, but why does the passanger side look like its bigger right before the merge? Also you got a link to the turbo you using?
Old 07-24-2012, 10:26 AM
Cux350z
hatersgonnahate
Cux350z's Avatar
Nice work so far.
Where in nj?
Old 07-24-2012, 03:56 PM
gotboost1099
It's 3 inches off the turbo and to the center of the transmission. Then the header to the 3 inch pipe is all 2.5.
Link to turbo
http://www.ebay.com/itm/On-3-Perform...c04f40&vxp=mtr
I'm right outside cherry hill new jersey close to Philadelphia. I'm looking for a local place to get intercooler piping and stainless piping. I really need. 3" flex pipe ASAP because Im close to starting the car.
I finished more then half of the intercooler piping today, the oil filter relocation didnt give me the clerarence I was hoping but I don't have to drop an intercooler pipe everytime I change the oil.
Old 07-25-2012, 04:30 PM
BoomerZ33
BoomerZ33's Avatar
awesome stuff jersey dude
Old 07-25-2012, 07:44 PM
bbs350z
bbs350z's Avatar
what kind of oil pump are you using?? i know comp turbos makes an oil less turbo now that the ls guys are having success with. its a sealed cartridge and is cooled by coolant which is always pressurized.
Old 07-26-2012, 12:55 PM
gotboost1099
The comp turbo I would need is about 1350$ I looked into going that route, my turbo and wastegate were only 800$ billet wheel ball bearing from on 3 performance. This is a budget build, the oil pump i actually found on eBay. There's a guy here in new jersey that manufactures oil pumps for sts he also has a street version he sells for around 160$. Saved more then 500$ on one part of this build, all the parts add up quick.
Old 07-26-2012, 10:18 PM
quakerroatmeal
quakerroatmeal's Avatar
You have a lift inside your home garage?
Old 07-27-2012, 12:56 PM
gotboost1099
Yeah got it on Craigslist for 400 spent 500 in new cables trans fluid synchs and rented a impact drill.
Finished hot side today on to Wastegate any thoughts on dumped vs routed back into exhaust
Old 07-27-2012, 01:50 PM
eltness350
The Untouchable
eltness350's Avatar
open dumps ftw!! i heart how mine sound!
Old 07-27-2012, 06:09 PM
t6378tp1
t6378tp1's Avatar
Well I have a 3 inch sleeved flex and live in Philly, I was going to use it this weekend to make a 3inch downpipe for my buddy but that may have to wait till next weekend due to the weather
Or you can order one from the link below the company is in Maryland and I normally have my stuff in 1-2 days have placing my order depending on the time
Last route the wg back into the exhaust if this is your DD all that noise gets old real fast
http://stores.ebay.com/Mandrel-Bendi...id=p4340.l2563
Old 07-28-2012, 05:53 AM
gotboost1099
Extreme psi in Bensalem has the flex pipe in stock. And I already picked up a u and 45 to make the Wastegate routing. Good to know though
Old 07-29-2012, 07:12 PM
gotboost1099
I mounted the Wastegate dumped but facing my exhaust so if I get annoyed I can send a straight pipe into the exhaust to reroute it.
Old 08-01-2012, 03:49 AM
t6378tp1
t6378tp1's Avatar
any updates
Old 08-01-2012, 08:07 AM
gotboost1099
Was gonna paint intercooler and oil cooler black for sleeper look but I kind of like them polished with the bumper on
Made a simple version of oil drain system boosted performance uses.
And grinded the whole exhaust gonna polish it today
Getting so close just waiting on oil pump and oil feed and return lines. Drop in fuel pump and injectors. And connect the two upper charge pipes to throttle bodies
Old 08-07-2012, 10:57 AM
Jtran Studios
Vendor - Former Vendor
Jtran Studios's Avatar
props for doing the work your self! few things, i would definitely make a bracket to hold the weight of the wastegate up. using that thin of material with no flex section, it will eventually crack at the weld and break off. secondly, the clocking of the wastegate isnt correct. you have to set the pipe up to flow with the exhaust gas's not against it also the driverside feed from the header to the "merge" needs to be a smoother transition. if you can correct these issues, car would spool faster, hold boost better, and also be more efficient! just giving my .02 cents!
Old 08-07-2012, 11:01 AM
Ztouring04
Ztouring04's Avatar
Vids?
Old 08-07-2012, 11:09 AM
konrad
konrad's Avatar
+1 on what jtran said. I'm in the process of fabricating my 3rd kit this time it will be a compound T4 6766+t3 60-1 and I would take any advice he would give me
Quick Reply: My g37s build single turbo 550 whp
