greddy twin build...
Old 12-05-2016, 03:10 PM
  #241
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
Originally Posted by Escobar
nice to see your still working on this and making progress. I did have issues with fitting those svrtech wastegate relocation pipes. I could never get them to fit right with my down pipes. Ended up just having a whole exhaust system custom made. Best decision for sure. Everything fits perfectly. keep up the good work sir
Thanks! Turbos didnt arrive today...but says they are in Denver...so maybe tomorrow? The TotalD cloned a set and they are pretty good ... passenger side needed about a 1/2" extension but not a big deal...
Originally Posted by OldManZ350
-4 Fuel Feed is very small...... hummmmm
Mine is a -8 Feed, then Tee's to two -6's
the -4 are oil feed lines for the turbos...(earlier in the thread) I toasted my driver side blower due to a clogged lines...upsizing and lines, added a filter, considering adding pressure gauges at the blowers...
my fuel setup is the cjm stage 2...
Old 12-05-2016, 05:16 PM
  #242
OldManZ350
OldManZ350's Avatar
sorry I miss-understood.......
Old 12-05-2016, 06:46 PM
  #243
bealljk
bealljk's Avatar
no worries ... can you imagine a twin setup running 1/4" lines... lol!
Old 01-03-2017, 07:25 PM
  #244
bealljk
bealljk's Avatar
back on it...tackling the drivers side first...been waiting on AN fittings...but got a few things buttoned up like the test pipes/Ypipe, o2 sensors, waste gates are all wrapped up, boost control solenoid, vac block...
a few pictures...
more for comparison - going to have a set of solid engine mounts fab'd-up ... similar to what Z1 sells but I have a little bit of a twist as far as ease-of-installation goes.
Additionally want fabricate the bracket between the mount and the engine block - hoping to free up space for the intake duct(down the road)...
In an effort to not repeat the same issues that blitzed my previous turbos I've installed oil pressure gauges at the blowers - running simple mechanical gauges.
Old 01-13-2017, 03:13 PM
  #245
SAMzG35
SAMzG35's Avatar
Originally Posted by bealljk
waste gate relocation kit came in... tip of the hat to Jeremiah @ Sucker Punch Motorspots - I was pretty happy that he fabricates them up! Beautiful welds ...
Do they sell this or was it custom built for your setup? I have Greddy setup and would love open dumps
Are they installed yet?
Old 01-13-2017, 09:51 PM
  #246
bealljk
bealljk's Avatar
^your man is Jeramiah, 'TotalD' on this forum. He runs Sucker Punch Motorsports. He's around $325 for the kit. Couldnt say nicer things about Jeramiah and the kit is fabricated with high quality parts and the welds are top notch. May not be able to tell from the pictures but the appropriate flanges are threaded which helped a ton. I did need to run a 1/2" spacer on my passenger side waste gate (between the greddy manifold and the pipe) and also took 3/4" off the dump pipe after the waste gate...but I'm not concerned with either.
Old 01-14-2017, 06:03 PM
  #247
Cux350z
hatersgonnahate
Cux350z's Avatar
you need to clock that driver side turbo CHRA some. The oil feed/return should be as close to vertical as you can get it. youre sitting at about the 1:45 position, need to be at noon.
Oil needs to drain.
Old 01-15-2017, 07:33 AM
  #248
bealljk
bealljk's Avatar
Cux - yea...that 90* hard pipe is my constraint as it's hitting the mount...luckily my solid mounts are finished and I should get them tonight which should help...additionally, I just bought a TIG so if I gotta re-weld those IC ducts can.
Thanks for the heads up and input - much appreciated
Old 01-15-2017, 09:09 AM
  #249
Cux350z
hatersgonnahate
Cux350z's Avatar
I like the thinner profile in the middle..more clearance for the intake coupler on pass side
You can clock the CHRA relative the the impeller housing as well. It is held in place by a large snap ring. Any time they are rebuilt you normally need to check the clock or even better mark it before hand.
Old 02-26-2017, 09:26 PM
  #250
bealljk
bealljk's Avatar
Everything is back together...
I re-plumbed the blowers so the charge-pipe and oil feed line up accordingly...
looking up at the blowers...couldnt fit the AN fitting, a AN / 1/8"NPT Tee and the feed line...so I made a 8" line off the blower take the AN / 1/8"NPT tee...worked out well...will give me a few options here down the road.
Size:  150.2 KBName:  7B924EAF-95BD-44AD-8C2A-BB34D5EFD9FD_zpsbvf5fpfo.jpg
I'm not sure if it was coincidence, me being paranoid, or truly an issue but the blowers were spinning at an abnormally slow rate (~10 RPMs). My fear was they were not getting lubricated. Checked multiple spots along the oil lines and it appeared that oil was flowing. Regardless, I swapped the oil feed line to the OEM oil pressure sensor port.
Old 02-26-2017, 09:28 PM
  #251
bealljk
bealljk's Avatar
Video of the slow blower -
video of normal operation -
Old 02-26-2017, 09:36 PM
  #252
bealljk
bealljk's Avatar
Everything bolted back together and need to wrap up a few loose ends ...
Hat-tip to Cux350z and 35Reilly for their help in clearing up the air on the MAC boost control solenoid. This was something I was going to leave to my tuner but I'm glad I got it worked out.
ordered a second set of AN3 hoses and a few misc fittings for the top port of the wastegates ... in the meantime - a buddy welded on a AN3 to my intake track - post IC, Post BOV, Pre-TB.
Old 02-26-2017, 09:44 PM
  #253
bealljk
bealljk's Avatar
With the solid engine mounts installed and ready to go it was foolish to rely on the OEM polymer transmission mount. Member Fixxxcask had a Z1 polyurethane un-used and threw me a deal on it. Should be in early this week and I can get the mounts buttoned-up. Was disappointed with the nissan OEM mount...happy to get something a little more significant in there.
Old 02-26-2017, 09:50 PM
  #254
bealljk
bealljk's Avatar
It's a pet-peeve of mine but I cannot stand those greddy-blue intercooler pipe couplers...I understand a few are necessary ... but they are f'n annoying...
My buddy (with the welding skills) and I fab'd up and welded the aluminum charge pipes. We were able to fab the drivers side line as a single piece - I thought it came out pretty good and his welds looked really good.
while the passenger side was done in two pieces due to it's curls & wraps.
Old 02-27-2017, 05:59 AM
  #255
TT03Z
TT03Z's Avatar
Who did you get these motor mounts from? They look good i like the machined look. Z1 sells something similar with their 6 shooter mounts but id like to go with these also if i can get my hands on a set.
Old 02-27-2017, 09:04 AM
  #256
bealljk
bealljk's Avatar
They are a one off - I designed with the help of a machinist here in Colorado...they came out better than I design based on the machinist's skill & experience (he's does a lot of custom vintage VW work). Very similar to Z1s but these install/uninstall significantly easier and more efficient with the bolt drop through design. PM me for more details.
TT03Z (02-28-2017)
Old 02-27-2017, 08:49 PM
  #257
bealljk
bealljk's Avatar
Good G-d'it! Fncken installed a urethane motor mount ...went just fine...
lying on my back basically cranking a 1/2" bolt (between the cross member and the urethane mount) for final torquing, fncken box wrench came off the bolt and I clocked the **** out of myself...cut open my lip on my teeth...I'm a big puss...
The trans mount came in as did my AN3 fittings needed for the top port of the waste gates...hoses and sintered filter (for the boost solenoid) some time this week. I think I can get the car on the ground for some road testing...
need to cut a little 1/8" thick 'doughnuts' to mount the secondary oil filter...
Old 03-03-2017, 10:48 PM
  #258
SAMzG35
SAMzG35's Avatar
When is this gonna be done? i really wanna hear the open dumps before I order them lol
Old 03-04-2017, 08:12 AM
  #259
bealljk
bealljk's Avatar
its done now ... I'd like to do some road tuning & test to ensure it's ready for the dyno.
A buddy owes me $500...once I get that I'll go and formally tune!
Old 03-04-2017, 07:03 PM
  #260
Juztin
Juztin's Avatar
There's not much to hear, they are raw sounding and very loud when they open up, you just got to like really loud and raw sound. Not exhaust note loud, just raw loud.
I had open dumps on my old DE with Greddy kit and the dumps basically drowned out the exhaust note at WOT. If you want to hear an exhaust note I'd suggest recirculated, otherwise, go ***** out open dumps haha.
Quick Reply: greddy twin build...
