vortech/stock block let go...so *knock on wood, reliable build thread ;-)
Old 10-30-2013, 08:33 AM
  #261
the3kgt2
the3kgt2's Avatar
What tires were you running?
Old 10-30-2013, 03:18 PM
  #262
Colombo's Avatar
Thanks guys. In on nitto nt05s right now in a 245/285 setup but she just toast these up. May be going to a much stickier tire and larger sizes soon. 2 weeks after my tune and my 1 year old tires are already down To 4/32nds tread I have been doin a lot of pulls to say the least haha monthly autox and a road course possibly this next month and I will need new tires by next year so we will see.
Old 10-30-2013, 04:04 PM
  #263
Classy
Classy's Avatar
You know you can always powder coat another 2 XXR 521 18x10 and throw those up front, I had those up front when in had a 350Z, with a 275 up front, with my fenders rolled up fit a 295/35/18 in back, probably could fit a 305
Old 10-30-2013, 04:48 PM
  #264
OldManZ350
OldManZ350's Avatar
Motor Sound Good……
How in the hell can you tell where the Track is?
Need some Drag Times on your Car…..ASAP
Old 11-01-2013, 08:55 AM
  #265
Colombo's Avatar
Originally Posted by OldManZ350
Motor Sound Good……
haha you get used to seeing where the track is. and i will have to give the drag strip a shot 1 of these days. i have never been a fan of drag racing, and with these tires i have no first/some of second but why not . i would love to borrow a set of drag slicks for the rear and give it a real shot tho. we will see.
Old 01-06-2014, 08:38 AM
  #266
OldManZ350
OldManZ350's Avatar
How did you determined your rev limit?
Your SC gearing with a 6.12 damper, 32/28 cog and 2.87 is nearly identical to
My SC gearing with a 5.75 damper, 34/28 cog and 2.87.
I rev to 7100 rpm and my stock V2 SC-Trim blower is holding up fine. (62,314)
The Ti-Trim is a much tougher blower, I think it can handle the 2.87 and 7400rpm
You could also try
1. Raise your rev limiter to 7700rpm and the 3.12 SC @ (62,314)
2. Lower your rev limiter to 7200rpm and 2.87 SC @ (63,343)
and see how it works for you.
Old 01-06-2014, 11:03 AM
  #267
Colombo's Avatar
You could also try
tim i calculated it with the 3.12 at 7400 rpm = 59,839.36
with the 2.87 at 7400 rpm it was 65156.1 rpm which is where it let go.
im sure this blower can handle it better then the last 1 but i cannot really afford to chance it much... what i may do is spin the 3.12 to 7600 rpm maybe for the extra power band.. however i will have the 2.87 with me.. at this point i really want longevity of the blower so the less over spinning the better..
how long have u been overspinning that blower to those rpms tim? if you had to guess how many hard hard pulls has it seen?
not saying that 928m did something wrong with my bearing install when they did the 928m impeller but i have my wild thoughts every now and again considering my stock SC trim i was spinning with a stock crank pulley to 7200 all day for over 8 months of racing with no issues.
Old 01-06-2014, 11:42 AM
  #268
OldManZ350
OldManZ350's Avatar
Blower has been on the car for 45,000 mile
1. last 12,000 miles ………..…blower @ 62,355rpm hundreds and hundreds of hard pulls
2. before that 20,000 miles blower @ 58,687rpm hundreds and hundreds of hard pulls
3. before that 8,000 miles blower @ 54,554rpm
and so on…….
Keep in mind there is always some SLIP with a Serp Belt.
When we refer to Belt Slip, we are talking about when the belt lets go and can't hold the load.
I think something happened at 928, may just have been out of balance.
Old 01-20-2014, 12:28 PM
  #269
Colombo's Avatar
Yesterday's race.
Old 01-20-2014, 12:37 PM
  #270
OldManZ350
OldManZ350's Avatar
Video can' play
Old 01-20-2014, 01:20 PM
  #271
Conway_160
Conway_160's Avatar
This is his video.
Old 01-20-2014, 02:06 PM
  #272
Colombo's Avatar
thanks conway dono what happened.
Old 01-20-2014, 02:35 PM
  #273
Conway_160
Conway_160's Avatar
No Problem
Old 01-20-2014, 03:00 PM
  #274
iStan
ZR
iStan's Avatar
Did I miss the new tune numbers?
Old 01-21-2014, 04:22 AM
  #275
Classy
Classy's Avatar
His dyno numbers are almost the same as before, "604/445 with an extremely slipping belt at 17psi" on the 3.12 pulley
Old 01-21-2014, 12:52 PM
  #276
OldManZ350
OldManZ350's Avatar
Hay Johnattan,
So how does it feel on the track for you compared to before?
Old 01-22-2014, 05:41 AM
  #277
Colombo's Avatar
Hay Johnattan,
It's about the same slightly diff in how quickly it builds boost up top which breaks traction in second gear but it's deff a blast to try and control.
I did throw a lean bank 1 sensor 1 at the race which once it came on and I turn the car off it would have issues starting right up had to give it a little throttle for it to crank but still raced fine the rest of the day I reset the code but it's not the first time it has popped up. I'm gonna check for exhaust leaks and then possibly replace that sensor...
Also awaiting a new tensioner in the mail to install the green back and crank it down to see if she can make 20+psi again however the Poly carbon belts have not snapped once I spaced out the cog tensioner (thanks Tim) so all is well as of now
Old 01-22-2014, 09:02 AM
  #278
the3kgt2
the3kgt2's Avatar
Does anybody have a part number for the 79" Gates green stripe serp belt?
Old 01-22-2014, 10:05 AM
  #279
Threads's Avatar
K060795HD
That's the 79.5". The next one up is a 80.6". However, You may want to take a look at Gates' catalog for a more complete listing.
Old 01-30-2014, 09:07 AM
  #280
Colombo's Avatar
just as an update car is still running like a champ. i was throwing cog belts for a little bit which threw me off. so i looked over my bracket and blower and found that i may have had the blower bracket just slightly incorrectly spaced (when i got the kit i didnt have all the correct sized spacer so i guessed) it ran perfectly fine like this for a long time but after i correctly installed and measured all spacers everything is good. few races down and who knows how many hard pulls to 7600rpm, i have been lazy and have not swapped tensioners or to the greenback belt yet but i have seen consequtive 20psi pulls even with this belt. but all is well :-) oh i also switched to the 400 times stronger cog belts just in case.
Quick Reply: vortech/stock block let go...so *knock on wood, reliable build thread ;-)
