vortech/stock block let go...so *knock on wood, reliable build thread ;-)
Old 12-13-2015, 02:41 PM
  #381
Colombo's Avatar
Originally Posted by taywan
why does the sheet say 4.5 v8 ?
From my understanding the 4.5l motor is 96mm (.020 over) and uses same Pistons
Old 12-25-2015, 06:48 AM
  #382
Colombo's Avatar
Little update pics. Beginning re assembly now 👌🏽💯 also scooped up a set of dc sport headers for super cheap to replaced my poorly fitting poorly flowing top speed headers that I had before, they fit so bad I have to heavily massage them to fit. Bought some louvers to fit to the hood aswell.
Old 12-27-2015, 07:23 AM
  #383
Colombo's Avatar
Snagged some 6 shooters to replace my poly mounts. Will have my poly mounts for sale soon
Bottom end is almost patched up and torque to spec. Got crank and bearings all in and good. Got #1 and #2 Pistons in and rods torque to spec but the piston ring compressor I have is garbage do gonna get a better 1 today and finish the bottom end up. Then just waiting on my gasket kit to come in to assemble the rest of the motor. Goal is to have the motor atleast tempt into the car by early Jan.
Old 12-27-2015, 07:47 AM
  #384
Classy
Classy's Avatar
Solid mounts, it is officially a race car, lol.
I don't know what people are scared of with rebuilding a VQ, just gotta have some funky tools
Old 12-27-2015, 09:52 AM
  #385
Colombo's Avatar
I've actually only had to buy 2 tools that I didn't have before. A ring compressor and the reverse hex weird socket that the 16 main cap bolts have. The rest has been done with nothing but your every day tools, 10mm,12mm,14mm,17mm and a 19 here n there
Old 12-27-2015, 12:52 PM
  #386
Classy
Classy's Avatar
Main is weird and the ones for the fly wheel
Old 12-27-2015, 06:46 PM
  #387
Colombo's Avatar
Well bottom end is back together. Had the wife give me a hand. Waiting on my gasket kit then motor can go completely back together.
M
Old 12-27-2015, 07:39 PM
  #388
OldManZ350
OldManZ350's Avatar
Look Good Johnattan.......
What did you end up for Bearing Clearances?
And Crank Thrust clearance?
And Piston/cylinder chearance?
Did you upgrade the piston pins?
Thanks,
TimRod
Old 12-27-2015, 07:58 PM
  #389
Resmarted
Resmarted's Avatar
Thanks,
TimRod
Unless he sprays, there's no need to upgrade those wrist pins. They're good for a ton of power and piston speed. At least if those are wiseco's. I know CP are stronger compared to the wisecos too. The upgraded pins are just thicker from what I noticed. Pretty cheap though. I did the upgrade.
Old 12-28-2015, 08:45 AM
  #390
Colombo's Avatar
Tim I messaged you on fb w your question. And I'm running the JE wrist pins that came with the Pistons
Old 12-28-2015, 05:58 PM
  #391
OldManZ350
OldManZ350's Avatar
thanks, got it.....
Old 01-06-2016, 05:45 PM
  #392
Colombo's Avatar
Little update since motor is almost ready to go back in
Upgraded to L19 studs (Was on stock bolts holding 600+ without issue, was pretty impressive)
Wife helping me out.
Heads torque to spec buckets and cams back in
Old 01-09-2016, 07:43 PM
  #393
Colombo's Avatar
Timing done
Covers sealed up
Getting close
Old 01-16-2016, 04:43 PM
  #394
Colombo's Avatar
Ready to go in.
Motors in with the new solid mounts. Waiting on my ATI crank pulley and this thing can completely go back together and get cranked.
Old 01-25-2016, 04:19 PM
  #395
Colombo's Avatar
New oil cooler. Much larger
May put it here or off where the wiper fluid used to be.
Motors been ready to fire just waiting on this ATI.
Old 01-30-2016, 06:58 PM
  #396
Colombo's Avatar
Motor got started today no issues and sounds great 👍🏽👍🏽
Old 02-04-2016, 01:32 PM
  #397
OhioStyles
OhioStyles's Avatar
Hey which ATI pulley did you get? The race or street version. Im getting a lot of confusion from ATI about the race pulley
Old 02-19-2016, 05:25 AM
  #398
Colombo's Avatar
Race version would require some modifications to use. I run the street version even tho I don't have ac
Old 02-19-2016, 05:28 AM
  #399
Colombo's Avatar
Little update. Motor cranked up great! Drove her around and began break in process and found a rear main leak. Pulled trans and should have it back together here soon. Here's some videos
Old 03-10-2016, 09:24 AM
  #400
Colombo's Avatar
Update, motor is running smooth rear main is good to go now. Break in is done and have been starting to getting into boost. When rear main let go it got some oil on my clutch disk (6 puck) cleaned it as good as I could and tossed it back in. It seems the oil didn't completely clean off and car is slipping ever so slightly up top but it seems to be improving with every pull so hopefully it will dry out. Regardless car pulls very strong.
Quick Reply: vortech/stock block let go...so *knock on wood, reliable build thread ;-)
