FI bug has bit, going Vortech
Old 12-18-2016, 08:43 PM
  #101
terrasmak's Avatar
Received 2,296 Likes on 1,653 Posts
Originally Posted by dikspiel
dreamer build
Dreaming of keeping up with GTR and Vettes on the track.
dikspiel (12-18-2016)
Old 12-21-2016, 07:32 PM
  #102
terrasmak's Avatar
V3 setup on the way , I need to get a R-Ryders charge pipe. Fuel rails and the rest I need to build my return system with the surge tank. I have an external mount 255 pump, may need to swap it to something else. Get a boost gauge, no idea where to mount it, don't really see it as that important except for tuning.
I'm just going to set everything up on the stock block , install my fuilddamper and run the 3.3 pulley get the little tweaks and stuff worked out before I toss in a fresh motor.
BluestreamDE (12-21-2016)
Old 12-21-2016, 07:41 PM
  #103
BluestreamDE
BluestreamDE's Avatar
I didn't read anything on injectors, some GTR injectors (550cc) will be perfect with that 8lb 3.33 pulley. The Fluidampr will spin the blower a lil faster, less than one psi on top of the 7-8 you will get from the 3.33.
Old 12-21-2016, 07:55 PM
  #104
terrasmak's Avatar
Got a set of ID1000's
Also have a 2.87 pulley coming, figure it out later if I run it or not. Won't be on the current motor
Old 12-21-2016, 07:59 PM
  #105
BluestreamDE
Ahh didn't catch that. Good luck, can't wait to see ur numbers and how u fair with those more powerful cars on the track.
Old 12-22-2016, 10:01 PM
  #106
terrasmak's Avatar
Need to get parts on the way to complete my fuel system. Trying to figure out fuel rails, iD1000 injectors being used, it will be a return system, and power Goals are around 450 when I swap to the built block. Can I keep the keep the factory rails using CJM parts or do I want to swap them to aftermarket ?
Old 12-23-2016, 07:15 AM
  #107
Conway_160
Conway_160's Avatar
If you cut off the ends and weld on -6 or -8an fittings they can handle what ever you want to throw at them. But you best bet is to get rails that have dampers built in so you don't go lean @3k ish.
Old 12-23-2016, 09:40 AM
  #108
jdm-v35
jdm-v35's Avatar
the oem fuel rails will be good to 600. 450 is very modest and even those 1000cc injectors will be overkill and only make it harder to get a nice idle. just get a CJM stage 0 kit, walbro 255 or larger pump and youre set. If you're not going for more than 450, running new fuel lines and spending more money on the higher CJM kits is a waste.
with my RC750's at 400whp I was at 51% duty cycle. you just want to keep it under 80% to be safe.
Old 12-23-2016, 09:10 PM
  #109
terrasmak's Avatar
I guess the CJM stage 0 fitting to adapt the rail would handle all.
Old 12-24-2016, 07:29 AM
  #110
jdm-v35
jdm-v35's Avatar
The adapter would not make it handle anything extra, as the bottleneck is the ID of the adapter itself.
Old 12-24-2016, 10:43 AM
  #111
03threefiftyz
03threefiftyz's Avatar
You probably won't need to go to the 2.87. We had to detune mine. It was pounding out 430-435 on a 3.33. That was on 93 instead of ethanol, too.
Old 12-24-2016, 02:21 PM
  #112
terrasmak's Avatar
But is the adaptor just fine for the power level I'm looking at running ?
Was kinda hoping for 3.12 with fluiddamper would hit my goal.
Old 12-24-2016, 02:46 PM
  #113
jdm-v35
jdm-v35's Avatar
Yes for your power levels the adapter will work perfectly. You don't need anything above the stage 0 kit. don't cut the rails and weld AN fittings on it as its a waste of time and heard its hard to get it welded good.
Old 12-24-2016, 03:10 PM
  #114
terrasmak's Avatar
Cool, I was looking at stage 0, not going to buy it, I already have a regulator and most if the fittings. Also my return will go back to the surge tank, so their lines will not work.
Old 12-25-2016, 04:35 AM
  #115
03threefiftyz
I would try the fluidampr with a 3.33 first. That said, a 3.12, though. You can pull a little timing up top and flatten the power on the top end, too if it goes over. You'll be fighting belt slip and all of that with the crank pulley and a 2.87.
BluestreamDE (12-25-2016)
Old 12-25-2016, 06:03 AM
  #116
BluestreamDE
^I would suggest if more boost is needed after changing to the 3.12 is to change the Jackshaft cog from the 32T to the 34T and it will keep the same surface area for your serpentine belt. It will spin the blower a bit faster and produce about 1.5 psi. On top of the Fluidampr and 3.12 and 928M impeller combo I have on my Z, it makes 13.5/13.8 at 6600rpm with no beltslip.
Old 12-25-2016, 07:57 AM
  #117
terrasmak's Avatar
The goal was to not run the 2.87 pulley , bigger pulley has less potential slip. Kinda thinking about the cog swap now with the 3.3 pulley . That may be a smart idea
Old 12-25-2016, 11:48 AM
  #118
03threefiftyz
Definitely go the fluidampr/cog route and and keep the 3.33. You should be able to do 440-450 w/o breaking a sweat.
Old 12-25-2016, 04:53 PM
  #119
OldManZ350
OldManZ350's Avatar
You will not fight any belt slip, if you just get a Radius Rod.
Old 12-25-2016, 06:21 PM
  #120
terrasmak's Avatar
The Tim-Rod?
Quick Reply: FI bug has bit, going Vortech
