Main girdle help. Modifying windage tray
Thanks for the info! that makes a lot of sense. I do plan to boost again eventually. I had a procharger but it did not put down the kind of power I'm looking for and was out of potential. I may go Single turbo or vortech v7 YSi. I still havent decided.
I am just in the process of collecting parts for the build right now. gonna take it slow and find what I want. I do have the pistons though which are wiseco 96mm 11:1. I would be happy to hit 700 when all is said and done. I still need to call around for machine shops about the torque plate as well.
RJM makes the closed deck block.
Facebook Post
on
thanks for the info on the closed deck block! I would rather go that route if possible.
Just took a look at the closed deck blocks.. looks like they welded a block guard in there then drilled and decked the block. It is definitely an OEM core and im guessing OEM sleeves.
Yes RJM clutch pedal manufactures, extreme quality top notch design...
Whereas, the other RJM, that puts in that sleeve option in your block. Well they just let go the dirtiest filthiest blocks I’ve ever seen in my life. Just crap ..... what are the word can I use for that, crap .
soulchain247
06-12-2016 11:22 PM
