Fitting suspension from 03 350z to 08 G35 Sedan?
Old 03-05-2016, 10:39 PM
Nackers
Nackers's Avatar
Default Fitting suspension from 03 350z to 08 G35 Sedan?
I'm not sure how to search this. It seems everywhere I look they sell coilovers for Z33 and V36 sedans separately, but my Z is still sitting around and I'm about to pick up a sedan this week. So I was curious if I could borrow them and put them on?
I'm assuming the spring rates and damper specs will be different because of weight or comfort, but mechanically, is there a difference in mounting?
BTW, coilovers are Z33 Stance GR+ full coilover style.
This should only be a temporary solution for the G. I hope to afford airlift for it eventually.
Old 03-12-2016, 06:37 AM
Nackers
Nackers's Avatar
FYI Rear bolts up fine.
Front... well not so much. A little modification to the coilover bottom mount should take care of that.
Straight off the Z
The Z... for the hell of it.
Old 03-12-2016, 03:45 PM
Nackers
Nackers's Avatar
Made it work still need to get tires for the front wheels.
orlando158
11-21-2014 12:40 PM
RFortier1796
04-18-2011 10:27 PM
Quick Reply: Fitting suspension from 03 350z to 08 G35 Sedan?
