Injen CAI Install Time (Being Ripped Off?)
Old 06-25-2015, 07:11 AM
yosip1115
yosip1115's Avatar
I don't agree that headers aren't worth it. Grab some HFC's or test pipes and headers. After a tune it will be a new car to you.
I am basing my argument off the fact that changing my headers alone after I was already re-tuned for a y pipe and HFC's gave me over 15HP with a new tune on the same dyno.
Old 06-25-2015, 07:15 AM
travlee
Master
travlee's Avatar
Received 9,048 Likes on 6,514 Posts
almost everyone will agree with me on headers, and he is going to pay out the *** for the install, but not my problem.
Old 06-25-2015, 07:58 AM
TitaniumT8
TitaniumT8's Avatar
Originally Posted by travlee
see if you have someone close to you
http://uprev.com/secure/dealers
I really appreciate the info. There is a PTuning less than 15 miles from my house. I had no idea it was there because it's not a direction I usually travel in for work or play, but apparently it's there. I'm going to contact them about their tuning prices. Hopefully I can squeeze a little more power out of the mods and get better mpg.
Old 06-25-2015, 08:03 AM
travlee
Master
travlee's Avatar
it usually runs about $700
Old 06-25-2015, 08:16 AM
travlee
Master
travlee's Avatar
dont get too hurt if you dont get the number you thought you would hit..... the car is more fun to drive after a tune though. on my 08 HR, i gained 19 total with full bolt ons
Old 06-25-2015, 08:22 AM
TitaniumT8
TitaniumT8's Avatar
My goal from the beginning was 330-340 HP at the crank with only bolt ons and a tune. I started at 287 (DE). I have absolutely no idea how close I am to my goal, but I hope I can reach the goal with the tune.
After the tune I'll be working on suspension and finally an aftermarket flywheel and clutch, but that will be in 2016 since I just got a clutch and flywheel (OEM) in April 2014. That will be it. Nothing extreme. I just want 330 HP crank and 3100 lbs without gas. Spare and jack were removed, cats removed, lighter wheels are in the works for this summer, and suspension next year. That should get me at 3,100 pounds.
Old 06-25-2015, 08:24 AM
TitaniumT8
TitaniumT8's Avatar
Oh, and I read ALL 40 pages of the Less weight = more power thread that dates back to 2004. A ton of info, but a lot of extreme measures people took to save weight.
Old 06-25-2015, 08:28 AM
travlee
Master
travlee's Avatar
remember the number they give you will be wheel hp. if i remember correctly mine hit 286*, and a buddy that had a de with full bolt ons, headers, etc hit 253*
**note, mustang dyno which are known to read a little low, but any dyno can be tweaked to read high or low
Old 06-26-2015, 05:33 AM
StuLax18
General & Tech Moderator
StuLax18's Avatar
Received 3,339 Likes on 2,379 Posts
From the short research I did just now they use a Dyno Dynamics dyno, which is said to read just lower than a Mustang. One place said a Mustang is about 12% lower than DynoJet, and DD is about 15% lower.
I'd say if you hit around 230-240 whp on the DD at PT Tuning that would be very good.
Old 07-02-2015, 02:50 PM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
This might be a good option for you to get your car running right if you dont plan to add any more bolt on parts.http://www.z1motorsports.com/350_g35...oducts_id=3294
Good luck.
Old 07-02-2015, 06:17 PM
travlee
Master
travlee's Avatar
Good luck.
late to the party noob
Old 07-02-2015, 06:35 PM
350zchad
350zchad's Avatar
Default Injen CAI Install Time (Being Ripped Off?)
Haha
Old 07-03-2015, 02:12 AM
dboyzalter
dboyzalter's Avatar
only like a week late better then my years old reserection.
I didnt even notice your post I was too in shock about the helpful header comment. And how nice you handled the 14hp claim.
I was actually wondering what happened to you in this one you must have won the lotto last week or something. Op sure did and he didnt even know it.
Old 07-03-2015, 06:13 AM
Syner
Syner's Avatar
I lol'd hard at this.
You'd be extremely lucky to see 285 at the wheels on a full bolt-on, tuned DE. 250-270 is more realistic.
You will NOT break the 300 mark.
Old 07-03-2015, 06:24 AM
travlee
Master
travlee's Avatar
troof!
Old 07-04-2015, 06:35 PM
TitaniumT8
TitaniumT8's Avatar
I'm not sure why you "Lol'd hard" at me aspiring to hit 330 HP crank with bolt ons and a tune. If we assume 15% loss at the wheels then I'm at 244 WHP stock. 330 HP crank is 280 WHP. That's only a difference of 36 WHP. I believe it's completely realistic with intake, plenum spacer, test pipes, aftermarket Y pipe, cat back, and tune. I never mentioned 300 WHP. Even my upper estimate/goal of 340 crank HP is only 289 WHP. I simply want 330 crank and I'll hit it.
For sake of argument, let's say I can't hit 280 WHP with a tune. Your estimate of 250-270 is ridiculous (more so the 250).
I consider myself a reasonable guy. I am confident in my goal and estimation. Once I get tuned I'll post dyno results. Even without a tune yet I notice a nice difference in power. No, I don't think it's at 280 WHP right now, but it may be close. I anticipate buying an aftermarket flywheel even though I just replaced my flywheel last April.
Thanks, all, for the constructive advice. I'll keep you updated.
Old 07-04-2015, 09:55 PM
Syner
Syner's Avatar
First off, crank doesn't mean anything. Any talk of HP is WHP.
Trav's HR hit mid 280's and he spent top dollar. Read previous posts and look at past dyno results (the car is over a decade old, there isn't much mystery what the car will make). Full bolt-on, tuned, NA DE's don't produce overwhelming numbers. 250-270 is a reasonable range for a DE.
EDIT: I missed the "crank" indication in your OP. Regardless, when you're talking about HP, say what you want to make at the wheels; it's still a relatively useless number, but at least it's a somewhat useful indication of performance (vs crank any way).
Old 07-05-2015, 01:53 AM
  #38
TitaniumT8
TitaniumT8's Avatar
I totally understand what you're saying. Normally I would only talk about WHP but I was citing the 330 HP number from the more modern vehicles such as: 3 Series, 370, G37, STI (more like 315), and a few others. It was my understanding that some of those vehicles make slightly different WHP because of different drivetrains. I simply thought it was simpler to use crank, but I do (edited, typo) understand how it's kinda useless to talk about it.
nanotech
10-02-2015 05:02 AM
codek
09-28-2015 03:03 AM
SharX59
09-27-2015 09:23 AM
Quick Reply: Injen CAI Install Time (Being Ripped Off?)
