Jacked my car up @ the wrong place, now there's a huge HUMP!
Old 01-08-2007, 05:27 PM
Mazinger Z
Mazinger Z's Avatar
Default Jacked my car up @ the wrong place, now there's a huge HUMP!
I jacked my car up at the wrong point (****!). It is near the front driver side. Now there's a sizable hump close to where the clutch pedal is. Apparently, the spot where I jacked it up is soft. The indentation from the bottom rose up to the top. Would there be any potential problems? How should I fix this? I tried using a hammer, but no luck. HELP! LOL
Old 01-08-2007, 05:30 PM
reptile718
reptile718's Avatar
Remove carpet and hammer it back, any place that you take it to will more then likely do that. Once you reinstall the carpet the damage will not be noticeable.
stein
stein's Avatar
Pull back the carpet and use a sledge hammer maybe....
Old 01-08-2007, 05:35 PM
Mazinger Z
Mazinger Z's Avatar
Remove the carpet completely?
Old 01-08-2007, 05:39 PM
jtabraham
jtabraham's Avatar
yeah, so you can see the indent in the actual metal. When you pound the hump out, use a piece of wood when you hammer, so you don't put a mallet direcly to the metal...that will just make it look bumpy in the other direction. The wood distributes the force over a wider area.
Old 01-08-2007, 05:49 PM
shinkuu
shinkuu's Avatar
this is an idea i had cause i had some difficulty finding jack points. paint all the jack points a different color so you know where to place the jack and jack stands with a quick glance.
Old 01-08-2007, 06:40 PM
Steve-O Z33
Steve-O Z33's Avatar
If it bent that easily, you should be able to hammer it back. Just hit it hard!
Old 01-08-2007, 06:44 PM
Sean
Sean's Avatar
call it a foot-rest
Old 01-08-2007, 06:53 PM
kaybee650
kaybee650's Avatar
yea but you have 3200lbs pressing against the jack, so i dont know, wood will be your best bet along with a hammer...... good luck
Old 01-08-2007, 07:09 PM
TheCajunStyle
TheCajunStyle's Avatar
yep did the same to my car... it wasn't a big deal to fix....get a metal plate (4" x 4") and place it over the indentation (on the inside of the car) and start hammering on the metal plate until the indentation goes away.
For some additional piece of mind, you may want to respray the exterior and interior with the black weatherproofing underspray.
Old 01-08-2007, 07:23 PM
Ichigo
Ichigo's Avatar
meh.. use it for a speaker pod
Old 01-08-2007, 07:26 PM
chuquison
chuquison's Avatar
take some pictures man
Old 01-08-2007, 07:38 PM
Eazzy
Eazzy's Avatar
Or lay some towels on top of it ----I use a 4X4 4 inches long and a heavy hammer--Whack Whack
Cannysage
Cannysage's Avatar
speaking of, does anybody know where the front jackpoint is? I do it on side frame (that's where you're suppose to do it, OP). I heard that there was one.
Old 01-08-2007, 07:42 PM
Eazzy
Eazzy's Avatar
Theres 2 notchs 2.5 inches apart that the jack goes between just in from the side skirts
Old 01-08-2007, 08:23 PM
UnderPressure
UnderPressure's Avatar
A picture would help
Old 01-08-2007, 09:59 PM
Steve_03
Steve_03's Avatar
Here you Go.
Jacked my car up @ the wrong place, now there's a huge HUMP!-800px-jackpoints.jpg
Old 01-08-2007, 10:10 PM
rlw222
rlw222's Avatar
it's about where the door starts and 21/2 in . 2 small dips about 1 in apart. or better yet take a look in the owners manual thats how I found them.
Old 01-08-2007, 10:15 PM
UnderPressure
I was refering to a pic of the damaged area.
Old 01-08-2007, 11:20 PM
Mazinger Z
Mazinger Z's Avatar
I could take a pic, but it probably wouldn't show up (black carpet). I'm too tired to do it today...just put on my rims!
Yea, I might keep it, feels good when I step on it...custom footrest! hahaha JK
Does anyone know if the carpet can be remove without cutting in to it?
Quick Reply: Jacked my car up @ the wrong place, now there's a huge HUMP!
