Heater blows cold air at idle.
on
air in the coolant system or low coolant.
First and foremost coolant needs to be to the top or wherever the full line is.
Basically wait til warm operating temperatures on the motor then have a friend rev to around 2000 or a tad bit higher and hold it. Look for a pressure relief valve by the battery. Slowly....SLOWLY unscrew it. You'll hear stuff and may see some bubbles coming out. Do this as many times as needed until your car blows warm air at idle.
Don't worry it's a common problem and I have the problem too....but too cold and snowy to fix it right now.
on
After trying to top off and unscrewing the valve (maybe 30-40 times) it still didn't work for me. But then I have dumped some coolent and added water, it did help. I'm not saying put in water instead of coolent, but just make sure you have a mix. Hope it helps also
I thought I'd chime in with my experience on this as my heater was also blowing cold air at idle. I followed the FSM procedure to remove air from the system. The FSM does not mention anything about having the car parked on an incline to do this. I cheated a little bit and added my own step to the FSM to make things easier. Basically, once my radiator and overfill tank were filled to the proper level, I put the rad. cap back on and added more coolant via the air relief port. Once it started overflowing, I closed it up and proceeded to step # 5 in the FSM. It worked like a charm on the 1st try! I had to add a very small amount to the radiator once I got done with step #7.
Good luck!
Good luck!
350Z_Al
10-29-2020 07:44 PM
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
04-04-2016 07:52 AM
