Driveshaft Vibration!!!
No giubo's anywhere on a Z, or any other Japanese car I'm aware of. Common on Italian and German cars, though.
I have the SAME problem. between 2 and 3 k my shifter and trans rumbles like a bit*h on deceleration. I'm thinking ujoints or trans mount? also a loud vibration when I turn the car off (intermittant). I have already replaced my diff mounts with polys and it helped take the shutter away, but above problem is still an issue. anyone find a solution??
I urethane mounted my diff and Trans mount still have the same issue and now it's worse
[QUOTE=cmoose11;7166971]tire balance would be a lot different and would be speed related not rpm.
i know it is the drive shaft vibrating but i'm wondering if it is just rear diff. mounts that i have to change, maybe get some solid mounts? I have read that the mounts are
on
Just to add to this, I have the same issue, with solid diff mounts, trans mount and engine mounts and things still vibrate heavily, specifically after pushing the car then coasting or downshifting and letting rpms drop. I don't think changing any mounts will help any of you
I think whoever mentioned the flywheel causing it may be on to something. I never noticed it when I had a lightweight flywheel... only after I went back to OEM and put some miles and drag racing abuse on it.
