Misfiring Issue. Safe to drive? P0300.
Old 04-24-2016, 06:50 PM
Noodlez
Noodlez's Avatar
Angry Misfiring Issue. Safe to drive? P0300.
Driving along and all of the sudden I have a loss in power and a really rough idle. I know these are symptoms of the dreaded P0300 code so I went and got it scanned at autozone. Sure enough I was right. They recommended new valve cover gaskets but they were fine. I took it to Nissan for further inspection and other than a dirty MAS they saw nothing that could be causing the misfiring. My thoughts were a bad coilpack or plugs. There is not any vacuum leaks as far as I can tell. My question is, is it safe to drive until I have time to get the coil packs checked out? Not sure if driving will damage anything. Any comments will be appreciated! Thanks.
Sorry if I posted in the wrong place...still figuring things out.
Old 04-24-2016, 06:57 PM
travlee
Master
travlee's Avatar
Received 9,048 Likes on 6,514 Posts
is it optimal to drive it that way, no not at all
coil packs aren't too bad and plugs are cheap.
Old 04-24-2016, 07:10 PM
Noodlez
Noodlez's Avatar
Am I hurting anything by driving it? I runs fine half the time and then all of the sudden it randomly misfires.
Old 04-27-2016, 10:44 AM
Noodlez
Noodlez's Avatar
Smile Update
After a quick clean and reoil of the filter things seem to back to normal. Looks like the coilpacks were fine after all.
Thanks for the help
that350tho
05-06-2016 02:00 PM
Zaksle75
05-06-2016 12:31 PM
Sleeper_Z
04-28-2016 09:21 PM
Quick Reply: Misfiring Issue. Safe to drive? P0300.
