ChriZTT's Pikes Peak White 350Z Build Thread
Old 12-01-2014, 05:23 AM
  #61
meanz
meanz's Avatar
Great build so far!
Old 12-01-2014, 06:45 AM
  #62
pyshin
pyshin's Avatar
Lookin' good, Chris
Old 12-02-2014, 07:40 PM
  #63
ChriZTT
ChriZTT's Avatar
Awesome car build, cutoff shorts ftw. lol
HA! Thanks for the for the kind words Sparco
Originally Posted by meanz
Great build so far!
Many thanks meanz. I've enjoyed your build thread. I'm loving the new look of the front end.
Originally Posted by pyshin
Lookin' good, Chris
Thanks Peter. You did a really nice job on tearing down your interior! I've been going back and forth on whether to keep or remove the rear speaker bar. It's only a matter of time I guess lol.
Old 12-03-2014, 01:08 AM
  #64
KingBaby
Hardest Setting
KingBaby's Avatar
always is lol again love your build, and it's nice to enjoy each stage as you progress on...
I think this is the best look, so removing the speaker box alone is prefect. The cubby can be used as storage, as another member did a wirte up to make dual cubbies which is genious...I'd have to look for it, not finding it easily at the moment.
How's the diff holding up?
Old 12-03-2014, 05:24 AM
  #65
Blurvision
Blurvision's Avatar
Looks great! Is there an off season in FL?
Old 12-03-2014, 11:54 AM
  #66
pyshin
pyshin's Avatar
Originally Posted by KingBaby
Thanks for the inspiration, King . Will be making those carbon cubby covers out of aluminum most likely.. looks so clean.
Old 12-07-2014, 07:00 AM
  #67
NA&CH
NA&CH's Avatar
Find that thread for the rear speaker area Please
Awesome progress man!!
and Yes PPW FTW!
Chris
Old 12-07-2014, 12:23 PM
  #68
mr. sparco
mr. sparco's Avatar
Really liking that interior, so simple and clean.
Old 12-07-2014, 01:49 PM
  #69
ChriZTT
ChriZTT's Avatar
Very true. Thanks for the love King
The diff is running strong. I'm really enjoying it.
That interior is from the 350Z NISMO 380RS-Competition. I came across that same picture earlier this year and it's definitely the inspiration for my interior.
One thing to take note of with the 380RS-C's interior (and probably why it appears so clean looking) is that the majority of it has been shaved. If you look at the area below the quarter panel glass on any stripped down Z the sheet metal is naturally riddled with holes. Same with the rear strut bar. These holes do not appear in photos of the 380RS-C's interior.
Old 12-07-2014, 01:52 PM
  #70
ChriZTT
ChriZTT's Avatar
Thanks! No official offseason that I know of. Winter time in Florida provides the best weather of the year.
Old 12-08-2014, 04:56 PM
  #71
NA&CH
NA&CH's Avatar
Offseason can be the summer with boost.. Still nice to drive in though...
I love the square setup. I need to adjust the entire suspension. I have been talking with some racecar drivers(z owners) that track. All know of your alignment shop. The wheels are 18x11 +17 with the 285-35-18. I am looking for a set of rpf1(again) 18x10.5
Chris
Old 01-21-2015, 07:25 PM
  #72
ChriZTT
ChriZTT's Avatar
Time for an update on the build! I've been in and out of the garage since the end of September working little by little and here is where I'm at.
Just to breifly recap all the progress on the interior. I've removed all the plastic trim from the cubbies rearward. I did away with all the sound detenating tar in these areas. Cleaned up all the seam sealant. Removed all the miscellaneous brackets in the trunk, and also neatly cut out the rear speaker bar. Cleaned out all the spot welds with an angle grinder, welded up some holes and used a bit of body filler to make all the metal work flush. I measured, drew up, and cut out my templates for the cubby covers I am going to fab up. Prepped all the metal in the stripped out areas for paint. Layed down some 2K primer and followed that up with a few coats of paint.
Mocking up the cubby cover templates.
Cardboard-fiber templates installed
Cutting out the speaker bar.
Doing some welding.
Weld, Grind, Weld, Grind Repeat.
Cleaned up all the spot welds and leveled the surface with body filler.
Tendious paint prep = masking everything off
Soooo much news paper!
Results after the first few coats:
Still plenty to get done, but I'm content with the progress.
Old 01-21-2015, 08:29 PM
  #73
KingBaby
Hardest Setting
KingBaby's Avatar
Excellence !
Old 01-27-2015, 09:39 AM
  #74
isy_nismo
isy_nismo's Avatar
If you produce the carbon fiber covers I would like to get a set, it would be much appreciated if you can produce it!! Grate progress!!
Old 01-27-2015, 05:21 PM
  #75
ChriZTT
ChriZTT's Avatar
Excellence !
Thank you! Thank you! Plenty of time and love has gone into this build. Thank you for the appreciation King!
I am going to produce them, but they won't be carbon!
Old 01-27-2015, 08:07 PM
  #76
ap2_S2Kyle
ap2_S2Kyle's Avatar
This is awesome lol..good work Chris!
Old 01-27-2015, 10:00 PM
  #77
XM 1's Avatar
absolutly insane! nice work...really love this look. carbon covers would look sick though
Old 01-28-2015, 02:41 AM
  #78
isy_nismo
isy_nismo's Avatar
I'll be interested even not build in carbon fiber.... keep us updated!!
Old 01-28-2015, 04:00 AM
  #79
ChriZTT
ChriZTT's Avatar
Thanks Kyle! Hopefully you'll get to see it in person one of these days!
Thanks XM 1! I hope your putting some miles on that Z of yours!
Stay tuned
Old 01-28-2015, 04:01 AM
  #80
ChriZTT
ChriZTT's Avatar
Just a little update to show that the paint is done and everything is wired back up and working. After more than a week of hibernation in the garage she breathes again!
Quick Reply: ChriZTT's Pikes Peak White 350Z Build Thread
