NA Build: Kacz07's 2006 SS 350z RevUP
Old Jan 24, 2011 | 09:02 PM
  #321
kacz07's Avatar
kacz07
Because the revup has a later peak, it gives me the impression that it will have a longer powerband. If I pinched the revup powerband by the apex and pulled it up, it would dwarf the mrev2/non rev and extend power with cams. JWT designed cams specifically for the revup. It would lead me to believe that they are designed for the revup lower, like SG's setup. The mrev2 was not designed for high rpm power and I don't think JWT took into account using anything other than OEM Nissan and Nismo parts. Could the Motordyne's, Crawford's, etc., work? Sure, but their low end driveability might suffer. The revup allows the car to make power longer and higher in the rpm range.
My most immediate interest is the peak and peak to redline gain I'll see with the SG headers. If I am able to hold or recover power higher in the rpm range with those and the mrev2, we'll get a better understanding of the revup's exhaust cam phasing on high rpms, even with the mrev2 on. I'll be getting an untuned vs. tuned dyno comparison of the headers. Then, I'll make my next move.
Old Mar 7, 2011 | 05:07 AM
  #322
e30cabrio's Avatar
e30cabrio
Great thread. I'll add my results if that is ok when I do my build, hopefully starting today.
Old Mar 7, 2011 | 07:38 AM
  #323
Zazz93's Avatar
Zazz93
Why no thread of your own?
Old Mar 7, 2011 | 08:01 AM
  #324
e30cabrio's Avatar
e30cabrio
I have a thread for my car I just dropped my parts off at the shop for the machine work to start.
I will start a NA build thread when I get home.
Old Mar 7, 2011 | 01:50 PM
  #325
Zazz93's Avatar
Zazz93
Gotcha.
Old Apr 24, 2011 | 09:05 PM
  #326
kacz07's Avatar
kacz07
http://www.youtube.com/watch?v=oCEgr4dqf-0
Old Apr 24, 2011 | 09:23 PM
  #327
kacz07's Avatar
kacz07
So, I've updated my setup.
Cosmetically, I wanted to use the Cosworth manifold, so I put it in. I like the way it looks. I also installed an Injen CAI. Again, I like the way the setup looks. I swapped the MD Shockwave V1 straight pipes for Harakiri canisters. This quieted the car down a bit, but it's still a screamer.
Combined with the SG headers, the car made no more peak power. Could be my heads, could be the dyno. Could be my setup w/ the high lift cams just don't complement the other parts. The Cosworth 270 cam has 10.56mm of lift, my JWT C8Rs have 12.01mm. A quest (or walkabout with the NA rev up motor) more than a competition, but the car is one of the higher powered NA builds on the site. I'm excited to see how Intimazy fairs with the SG long tubes. E30Cab has his build coming down the line as well. Should be an interesting summer.
Dyno'd in 4th gear, the numbers are are still abt 300+ whp and 260+ wtq. A flat 300whp from about 6400-7500+rpm. I don't know in what gear what other high hp NA builds were tested.
Not going to say anymore until I get the dynos up. Car was enjoyed this weekend.
Old Apr 25, 2011 | 02:22 AM
  #328
gabe3d's Avatar
gabe3d
Sounds great, hope you'll enjoy the car some more before you start going at it again. We are all in the same boat, like most of the guys in this section.
Old Apr 25, 2011 | 12:40 PM
  #329
mgrotel's Avatar
mgrotel
so adding sg headers didnt produce any more power? i forget, what headers did you have before?
Old Apr 25, 2011 | 12:51 PM
  #330
SexyRob's Avatar
SexyRob
I think whatever he gained with the headers, he lost with the cosworth and injen intake. cosworth has yet to prove useful to any NA build. Even on gabes stroker he lost power.
Old Apr 25, 2011 | 04:01 PM
  #331
mgrotel's Avatar
mgrotel
ok, so cosworth loses power over just a stock, spaced plenum?
Old Apr 25, 2011 | 04:55 PM
  #332
SexyRob's Avatar
SexyRob
well mrev2/spacer
cosworth only seems to be worth it on hi revving FI builds
Old Apr 25, 2011 | 06:49 PM
  #333
mgrotel's Avatar
mgrotel
from what ive read people have had better luck with a worked non-rev lower, which is what i have, will be going with a 1/2" spacer, and my upper plen is worked some too, and everything is gasket matched. im going with megan headers
Old Apr 25, 2011 | 08:27 PM
  #334
Zazz93's Avatar
Zazz93
I don't think the Cosworth loses out over stock but its not quite as efficent as some of the other combos without Cosworth techs massaging it.
Kacz, I've always had better numbers from the 1:1 gear, 5th. But if your saying the powerband looks good with a solid 300 at the wheels you're golden. Stop chasing -start driving.
Old Apr 26, 2011 | 02:44 AM
  #335
tuko316's Avatar
tuko316
Any dyno to post up?
How does it feel compared to before?
I agree, I think its time to enjoy your car now.
Old Apr 26, 2011 | 04:07 AM
  #336
SexyRob's Avatar
SexyRob
Originally Posted by gabe3d
Small update on this project prior to the car being taken a apart. Zcargarage put my car on the dyno as is with the cosworth and Samco tube being the only difference and it pulled a whopping 259.92HP and 236.91 TQ, compared to my last run of 276hp and 251TQ. That is quite an amazing loss of power. However the weather is much hotter where some timing pulling probably occurred and the car is running extremely lean compared to my prior tune. My AFR at around 12pts, yield the best power results and now the car is over 13pts. Promising but not sure if it can compensate back for the 16hp/14tq loss. He will try to do a quick tune and not spend too much time since this is merely for additional info for people that may be interested in that plenum. He might also do a quick tune on the 3" MAF to see how that goes. I'll keep you guys up to date.
this is before he sleeved/stroked his engine.
Old Apr 26, 2011 | 04:13 AM
  #337
SexyRob's Avatar
SexyRob
and another
Originally Posted by ___JB
I have an NA engine build that I was sure would benefit from a Cosworth plenum. I have gone through several iterations of engine management, tuners and plenums. Unfortunately, differences in Tuners (original shop went out of business), dynos, weather and many other things have made some of my dyno data hard to interpret correctly... at least it is hard for me to interpret correctly. I don't want to load Gabe's thread down with stuff on my car, but you can read about it in my engine building thread.
I have had very similar results to yours after adding a Cosworth plenum. I have fairly large cams (in retrospect, possibly too large) that I have been trying to make high RPM power with. My engine will turn 8,000 rpm and indeed we have done it several times on the dyno. I originally had a rev-up lower plenum (I thought it would be better for my engine because I wanted to turn high RPM) and a Crawford upper plenum. With the Crawford and rev-up plenums my engine always made maximum power in the 7,500 rpm range... regardless of the weather or dyno type.
In talking to Jim Wolf, he originally thought I would need to turn the engine more to make better power with his C8R cams. Sounded like I was a perfect candidate for a Cosworth plenum! I installed a Cosworth plenum, 3" MAF tube, and a JWT Pop Charger. Then I had my car tuned again by the same Tuner on the same dyno. As always, I expected to make more power. My car made roughly the same amount of power, but the power dropped off at 7,000 rpm instead of 7.500. Installing a Cosworth plenum dropped my peak power range by 500 rpm.
I couldn't understand why my engine showed the exact opposite characteristics for what the Cosworth plenum is known for. Seeing Gabes results makes me understand a bit more. Thanks for posting your results, Gabe.
Old Apr 26, 2011 | 04:19 AM
  #338
SexyRob's Avatar
SexyRob
and after he finished the build
3. Test of how the Cosworth Intake performed against the Motordyne 5/16th and MREV2
Old Apr 26, 2011 | 05:50 AM
  #339
mgrotel's Avatar
mgrotel
wow, but cosworth is still the clear winner by using area under the curve as a measurement
Old Apr 26, 2011 | 07:26 AM
  #340
SexyRob's Avatar
SexyRob
uh the cosworth is the blue line.
