Nismo Kit falling apart
Did you have any issues attaching the Nismo extensions with your stock skirts or was it a straight bolt on? Any additional drilling required? I'm gonna be installing a used set to my stock sides and didn't get a chance to look at both side by side yet. I noticed the stock skirts have that squarish indent towards the rear
can you pm me the pictures? it’s not letting me open them.
Here are some pics:
Inside the Nismo extension
I have one bolt slid into the bolt holder. The others are empty but they normally have bolts slid in them
Here is the underneath of the extension and the sideskirt. On the right are the holes that hold the sideskirt to the car. On the left are the bolts that hold the Nismo skirt extension to the sideskirt.
Here is the inside of the sideskirt with Nismo skirt attached.
See the white pins on the right? Those release by pulling on the top of the skirt. You can see the Nismo bolts in the middle of the side skirt which hold the Nismo extension to the side skirt
350Z/370Z Tech Moderator
Reason for rant... see above.
I usually keep stuff to myself considering the objectivity that an independent consultant should possess... But.....
Photobucket, you are an unscrupulous and unconscionable, money grubbing piece of sh*t company. I understand the tweaking of your business model from giving it away for free to a paid model. But your method of doing so leaves a lot to be desired.
Hope your new business model of screwing over all of your users AND all of the sites that have depended on your cooperation over the years works out juuuuust swell for you. Couldn't do the right thing and at least let people know how you were going to f**k them over before doing so, could you??
Hope you all like the unemployment lines because you just sealed your own fate.
KingBaby (07-07-2017)
i mean, at least, keep the old stuff accessible and whoever wants to keep using it from this point on, ask for money sure. but there are literally thousands of valuable and knowledgebale photos that are now omited, unless you pay the $400/year subscription(?).
Hardest Setting
on
it's 100 buck they want
It's the heat out here on the west coast with the colder night....it's oven/freezer like and I'm sure your car is keep outside ?
My new nismo has thousands of stressed and cracked parts and even broken as you post!
I will be fixed to the best of my ability as an adhesive on the back side of the side skirt should hold fine once prep.
and **** ******* photobucket and the Diaz bothers
Sorry to say, but if you cracked that NISMO urethane sideskirt, you caused some serious damage to it. If the mounting bolts are popping out, they may have been dislodged by the bump or jump you took. The anchor points may also be damaged or split to the point they no longer function.
Don't ignore the issue, address it. New fasteners and in new locations if need be. You don't have to use factory stuff that can't be found or priced at $8 a screw. Pull the side skirts off the car, it's simple unless they were molded in by the PO. Examine what's damaged or ghetto rigged and go to home Depot and lowes
