- [FS]: 2004 Nissan 350 Kelford N/A cams
- [FS]: nismo tomie twin disc clutch kit with flywheel
- [FS]: oem 6 speed transmission
- [FS]: Lots of parts G35/350Z Trans, AC....
- (WTB): 4.08 FD gears
- OEM [FS]: 3.5 Rear Gear & Open LSD
- [FS]: JWT Light Weight Flywheel 2005 Z - NEW - Seattle
- [FS]: ACT Prolite Flywheel 03-06 350z/G35 13.3 Lbs
- [FS]: DSS Pro Axles
- (WTB): Stock Shifter
- [FS]: B&M short shifter
- [FS]: OEM Open Differential
- [FS]: Nismo Stainless Braided Clutch Line 350Z / G35
- [FS]: TWM Short Shifter and Piston knob
- [FS]: 2008 350z OEM 3.5 Final Drive
- OEM [FS]: vlsd and shafts
- (WTB): FLYWHEEL - OEM or Aftermarket - 2003 350z
- OEM (WTB): Clutch, Flywheel, and Pressure Plate 03-05
- [FS]: OS Giken Triple Disc Clutch & CSC
- [FS]: 350z / G35 Nismo LSD - Pumpkin ( diff ) $550
- (WTB): Triple Plate Clutch for DE
- OEM (WTB): 04 OEM Flywheel.
- [FS]: 3.5 Diff with Quaife LSD + extras. DSS PRO AXLES
- (WTB): 05-06 350z 6 spd M/T
- (WTB): Flywheel and Pressure Plate BOLTS
- OEM [FS]: 2008 Nismo Ed OEM Clutch/Flywheel
- [FS]: nismo adj short shifter
- (WTB): Quaife with 3.5 to 4.08 gears! (center section)
- [FS]: Alto re5r05a clutches
- [FS]: OEM VLSD, 15K miles- $100
- [FS]: 06 350z 6MT 45k CD009 Transmission Christmas Special!!!
- [FS]: torque solutions polyurethane transmission mount - $80
- [FS]: Fidanza Aluminum Flywheel (New)
- OEM (WTB): OEM CD009 6M Transmission Any Miles
- (WTB): 6MT Parts
- [FS]: jwt heavy duty clutch and pressure plate
- OEM [FS]: VLSD Axle Stubs
- OEM [FS]: BRAND NEW OEM clutch and pressure plate for 05 350z
- [FS]: (3) 6spd transmission (space cleanout sale)
- [FS]: Exedy D-Core Carbon Twin Clutch Kit
- (WTB): stock/oem flywheel
- [FS]: oem exedy replacement clutch, f1 spec light weight fly
- [FS]: Used LSD
- OEM [FS]: Clutch, Flywheel, and Pressure Plate
- OEM [FS]: OEM Differential Diff cover
- OEM (WTB): Clutch , flywheel 350Z 03
- OEM (WTB): CD009 Starter & Clutch setup
- (WTB): 03-06 transmission
- [FS]: Whiteline bushings, motor mounts, transmission mount
- [FS]: Carbonetic's triple, CD05 tranny, OEM clutch
- OEM (WTB): Decent stock clutch,pp, and flywheel
- [FS]: 2007 cd009 transmission
- OEM (WTB): CD009 trans for my 03
- [FS]: SouthBend stg 5 and ACT flywheel combo. Must go
- OEM [FS]: NorthEast: 350z CD008 tranny
- OEM [FS]: NorthEast: 350Z Driveshaft low miles
- [FS]: NISMO Aluminum Differential Cover 350Z/G35
- [FS]: Default Amazing deals 350z! Nismo LSD, Samco rad houses
- OEM [FS]: 2008 Nismo OEM VLSD
- (WTB): jwt pressure plate 03-06 models
- [FS]: Exedy Clutch + Flywheel Stage 1 NEW VQ35HR
- OEM (WTB): I'm looking for 2007 350z OEM flywheel.
- (WTB): WTB: DSS Level 2 and/or level 5 Axles
- [FS]: JWT clutch and flywheel and more
- [FS]: BN Cusco RS LSD
- [FS]: DSS Pro Axles & OS Giken LSD
- [FS]: competition twin disk clutch
- (WTB): South Bend Stage 1 rally clutch/pressure plate/flywheel
- [FS]: CD009 6sp Transmission + Bonus
- OEM [FS]: 6 Speed CD009 650.00 plus Shipping
- (WTB): Need some aftermarket parts!
- [FS]: Brand New: ACT Streetlite Flywheel & OEM Clutch
- [FS]: TransGo Shift Kit VB Upgrade 5AT
- [FS]: Torque Solutions Poly Trans Mount (NEW)
- [FS]: 07 NEW Nissan Valvebody with Trans-go Installed
- [FS]: New! Comp Clutch Steel Flywheel
- [FS]: Brand New Quaife LSD
- (WTB): Diff Housing/Center Section for '07 6 Sp 350Z - Atl, GA
- (WTB): 4.083 Final Drive CASH IN HAND!!
- OEM [FS]: G35/350z LSD rear diff. - Low miles in So. Cal.
- OEM [FS]: Brand NEW Transmission 6 speed man. 07 & up Z / G35
- [FS]: Nismo clutch
- (WTB): Need 1.5 LSD with 3.9 Final
- [FS]: NEW HR South Bend Clutch, Flywheel and CSC with sleeve!
- (WTB): Kaaz 1.5 Way LSD or Os Giken 1.5 way LSD
- [FS]: OS Giken Triple Plate Clutch & Slave Cyl. (New)
- [FS]: DSS Stage 5 Axles
- [FS]: 350 EVO short Shifter
- [FS]: [SoCal]: TransGo Performance RE5R05A-HD2 BNIB
- (WTB): Looking for 1.5 LSD
- OEM [FS]: Open Differential Pumpkin from 2007 350Z Base
- [FS]: [SoCal]: New zero miles CD009 Transmission
- [FS]: open diff, clutch, subframe bushings,stub axles
- [FS]: Spec Twin Disc Clutch $500
- OEM (WTB): WTB: oem flywheel or trade for JWT
- OEM [FS]: 07-08 HR 6 Speed Tranny (9k+ miles)
- [FS]: ACT Heavy Duty Clutch Kit NIB
- [FS]: Jim Wolf clutch and flywheel & stock axles
- OEM (WTB): Shifter
- (WTB): tilton
