FS: OEM differential, flywheel and pressure plate CHEAP
Old May 6, 2017 | 01:14 PM
blknblk's Avatar
blknblk
Default OEM differential, flywheel and pressure plate CHEAP
I have a stock open diff from a 04.5 350z that was removed at around 50k miles about 9 years ago. Worked great, replaced with an extremely noisy Cuzco RS LSD. I am moving and want to get it out of my garage. Asking $50. Located in San Jose CA.
Edit: Adding my used stock flywheel and pressure plate that's been taking up room in my garage. This also has about 50k miles and had no issues. At that time all I had was an intake and exhaust and had not yet tracked the car. I ended up upgrading to an alum flywheel and aftermarket clutch. You can still see the factory machined "grooves" on the surfaces. Asking $40. Located in San Jose CA. Willing to ship.
Attached Thumbnails OEM differential, flywheel and pressure plate CHEAP-20170506_085249.jpg   OEM differential, flywheel and pressure plate CHEAP-20170506_085301.jpg   OEM differential, flywheel and pressure plate CHEAP-20170506_085328.jpg   OEM differential, flywheel and pressure plate CHEAP-20170506_090013.jpg   OEM differential, flywheel and pressure plate CHEAP-20170506_085922.jpg
OEM differential, flywheel and pressure plate CHEAP-20170506_085837.jpg   OEM differential, flywheel and pressure plate CHEAP-20170506_085817.jpg   OEM differential, flywheel and pressure plate CHEAP-20170506_085805.jpg
Last edited by blknblk; May 8, 2017 at 01:32 PM. Reason: Adding flywheel and pressure plate to ad.
Old May 6, 2017 | 06:35 PM
dcains's Avatar
dcains
Your car may be an Enthusiast version, but that's not the VLSD diff it left the factory with. That's an open diff from a Base car.
Old May 6, 2017 | 08:50 PM
blknblk's Avatar
blknblk
I know its an open diff. Did all enthusiasts some with vlsd? If so, I will edit my post since I don't want to be misleading.
Old May 6, 2017 | 09:16 PM
dcains's Avatar
dcains
Only the Base cars had the open diff, and when you stepped up to the Enthusiast you got the VLSD, aluminum pedals, self-dimming mirror, etc.
Old May 8, 2017 | 10:03 AM
blknblk's Avatar
blknblk
What the heck. I bought the car when it was a couple years old from the dealer. Either my car is a base or it got swapped out. I will edit my post to avoid confusion.
Old May 8, 2017 | 10:04 AM
dcains's Avatar
dcains
If you have no buttons on the steering wheel, it's a Base. Otherwise, it's a higher trim level.
Old May 8, 2017 | 01:34 PM
blknblk's Avatar
blknblk
Damn its base then! Its ok. I still love her the same. Thanks for the 411.
Old May 8, 2017 | 01:47 PM
dcains's Avatar
dcains
Nothing wrong with that, When I was shopping for my '08, all I wanted was a Base, as I didn't want the Bose, Cruise, VDC/TCS, etc.
I'd prefer to mod the car the way I want it, and since then I've installed a Quaife LSD, Brembo's, full Nismo suspension, Nismo S-Tune exhaust, Ray's LM-GT4 wheels, etc. IMO, the VDC/TCS is nothing but trouble, and I'm capable of driving the car without any assistance.
Old May 8, 2017 | 03:08 PM
blknblk's Avatar
blknblk
Now that you make me think about it I am glad I have the base too. Nice setup, jealous of your HR motor. I have too much money into my DE motor to change.
Old May 8, 2017 | 06:46 PM
dcains's Avatar
dcains
It's a sports car. Either Base or Nismo, those are the 2 best choices.
Old May 18, 2017 | 03:17 PM
blknblk's Avatar
blknblk
bump
zwei_the_c
Mar 16, 2026 03:13 PM
fridaytech21
Aug 14, 2017 12:18 PM
Dr.Factory
May 18, 2017 05:52 AM
gotparts?
Apr 27, 2017 08:07 AM
