Nitrous Oxide Too soon, jr.
Window switch
Old Dec 12, 2006 | 08:59 AM
GodZilla's Avatar
GodZilla
Bad Mojo
Default Window switch
Who is using one?
What RPM levels did you set yours at and what wire did you tap into for the sensor?
I plan on using this one
http://store.summitracing.com/partde...0&autoview=sku
Mainly because I have the Zex kit that already comes with the WOT switch
Old Dec 12, 2006 | 09:18 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
3000 and 500 shy of your rev limiter are fine
any of the coils are fine, just get the voltage meter out and poke one to get the right one with the right voltage
Old Dec 12, 2006 | 10:23 AM
Old School's Avatar
Old School
Shift_Boost
keep in mind you have to modify the MSD to work with the Z. I used the dynotune nitrous window/tps switch. I'd rather get a signal than have a microswitch. I dunno if Zex uses the TPS or not. Gear lockout is a cool feature with the dynotune as well.
I have my window switch set at 3800 rpms right now. Think I'm gonna lower it to 3200 next chance I get.
Old Dec 12, 2006 | 10:30 AM
350Z_LEE's Avatar
350Z_LEE
I have a NX window switch for sale with a bag full of rpm pills. I was using the 3000 and the 6400 pill
Old Dec 12, 2006 | 12:05 PM
GodZilla's Avatar
GodZilla
Bad Mojo
I had thought about getting that one because of the gear lockout
Any idea what I'll have to modify
GodZilla's Avatar
GodZilla
Bad Mojo
Too bad I had ordered mine last night..
Old Dec 12, 2006 | 01:33 PM
Old School's Avatar
Old School
Shift_Boost
They have to replace something in it....it has to be able to read the low voltage the Z puts out on the tach signal.
Old Dec 18, 2006 | 03:13 AM
Audible Mayhem
My350z
you have to send it off to MSD and have them restructure it to read 5 volts and 1 cylinder, it costs about 40 dollars and will take a week to get it there and back... i would say to buy a utec!!
Old Dec 25, 2006 | 01:44 PM
GodZilla's Avatar
GodZilla
Bad Mojo
Actually I got it to work fine..
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
AP350z223
Sep 8, 2015 04:38 PM
