Shop Builds Temp moving posts for some clean up of this section.
The Build BEGINS! Gamermodz/GReddy/S&R Z goes under the knife!
Old 08-19-2010, 03:14 PM
S&R Performance
Vendor - Former Vendor
S&R Performance's Avatar
Default The Build BEGINS! Gamermodz/GReddy/S&R Z goes under the knife!
As many of you know, this build has been in the works for a while. A lot of R&D, building, manufacturing and testing has lead up to this build. We got the motor all done, turbo kit is ready and the build begins!
Mod List as of right now!
Motor:
VQ35HR Stroked to 4.2L
Greddy Twin Turbos (Two 20G Turbos with larger compressor wheels) Ported & Polished
CP Pistons
Brian Crower Rods
Brian Crower Billet Crank
Ferrea 2mm over sized competition valves, springs and titanium retainers
Ported, Polished and Reflowed Heads (Flowed 37% more than stock)
Engine completely balanced and blueprinted
Tomei Pro Cams
Block sleeved by Darton
Custom Designed 6061 T6 Aluminum Twin Throttlebody Plenum
All components have been Cryogenically treated in an SubZero Cryo unit
1600cc Injectors
Exhaust:
Ported and Polished Headers
Ceramic Coated Headers and Exhaust System
Greddy Ti-C Exhaust
Suspension:
Tein SRC Dual Dampening Coilovers with External Reservoirs
2 Tein Electronic Dampening Force Controller (EDFC) Units cockpit mounted
Tein 16kg Springs Front and Rear
Tein Tie Rods
GTSpec 2 Point Rear Lower Brace
GTSpec Front 4 Point Ladder Brace
GTSpec Front Lower Tie Brace
GTSpec Rear Lower Tie Brace
GTSpec Rear Lateral Arm Brace
GTSpec Fender Braces
Hotchkis Adjustable Sway Bars
PowerGrid Swaybar Endlinks
SPL Adjustable A-Arms
SPL Adjustable Rear Toe Arm
SPL Adjustable Rear Trailing Arm
Stillen Core Support Bar
Whiteline Front and Rear Urethane Bushings
Whiteline Rear Traction Bushings
Whiteline Sub-Frame Bushings
Custom Roll Cage by SnR Performance
Brakes:
Greddy 8POT Front Calipers
Greddy 4POT Rear Calipers
Greddy 385MM Slotted Front Rotors
Greddy 335MM Slotted Rear Rotors
Greddy Stainless Steel Brake Lines
Stillen Master Cylinder Support Bar
Cooling and Fuel:
Greddy Performance Radiator
Greddy Oil Cooler
Greddy Air Diversion Plate
NISMO Thermostat
AEM Stage 1 & 2 Fuel Return System with 3 pumps
Custom Brake Cooling Duct System
ARC Belly Pan
Rear diff cooler
Transmission Cooler
Transmission:
OS Giken Triple Plate Racing Clutch
OS Giken Racing LSD
Rear Axle Brace
Electronics:
Haltech Platinum Pro
Greddy Infometer Touch Complete System with all sensors
Greddy Profec B-Spec II Boost Controller
Greddy Profec Remote Switch
DashDaq Datalogging System with Accelerometers
Video Datalogging system is still to be determined.
Stillen Grounding Kit
And here are some of the pics!
Engine Assembly, Short Block after assembly.
some fun in the back...
Long Block Assembly....
Long Block Assembled....
Old 08-19-2010, 03:29 PM
S&R Performance
Default and the tear down begins!
so now the car is here and we're starting the tear down for the build!!!!!
the stock powertrain is out!!!
new long block and a whole lot of GReddy awesomeness!
and she's waiting for the transplant!
Bobby being, well, just being Bobby...
more on the madness tomorrow! stay tuned! Project super power is in the works!
Old 08-19-2010, 03:42 PM
str8dum1
str8dum1's Avatar
cam specs? how long did it take to get that crank?
Old 08-19-2010, 11:27 PM
AZHR
AZHR's Avatar
sweet, lots of money spent
also can we haz update on the manifold?
Old 08-20-2010, 06:18 AM
S&R Performance
it's a very big build so there was quite a bit of expense. We'll post up results the second she's on the dyno.
Old 08-20-2010, 07:54 AM
lgear080
lgear080's Avatar
amazing... so what is the plan for the old motor? I recall you attempting a sale to no avail? Another awesome florida build. Are you going to rewrap the car? If you have
vectors of the vehicle I could have a buddy shoot you some reworks if you're interested.
perhaps its time for a change both inside and out.
Old 08-20-2010, 09:05 AM
MDHRZ
MDHRZ's Avatar
Can't even imagine how much money went into this car. Looks like it's coming along nicely though. Looking forward to updates!
...and more info on the manifold!!!
Old 08-20-2010, 09:21 AM
S&R Performance
it takes a good size budget to achieve what we're shooting for. It'll pay off in the end and as long as the owner is happy, we're happy.
Old 08-20-2010, 10:03 AM
MDHRZ
MDHRZ's Avatar
Is the front strut bar going back on or did you guys come up with a new design?
Edit: failed at reading first post lol
Old 08-20-2010, 02:30 PM
GAMERMODZoCOM
GAMERMODZoCOM's Avatar
Car is being re-wrapped in a couple months by a company we have been using for years.
We are hoping the strut bar can go back on. We are having custom plates made that will raise it up a little to clear everything.
The motor nor NA upgrades have sold. I am still concidering selling the stock motor but for a fair price.
The cams are Tomei's most agressive cams for the HR. We got the 4.2 crank from crower.
As far as the plenum goes, we will see what this one does when it's finished. The NA benifit wasn't there however keep in mind, it was designed specifically for this car (ie 4.2L FI). the NA version is still being worked on.
Old 08-20-2010, 02:41 PM
CRIDDA
CRIDDA's Avatar
In for the epicness!!!
Old 08-23-2010, 10:03 AM
S&R Performance
thanks folks. The car is being worked on right now! More updates to come.
Old 08-23-2010, 10:07 AM
MDHRZ
MDHRZ's Avatar
Group buy? I will def take a pair if they are willing to make some more .
Old 08-24-2010, 11:53 PM
Cossack
Cossack's Avatar
pretty much wat i was planning on doing to my car.
Old 08-25-2010, 04:15 AM
siberian57
siberian57's Avatar
Yeah I was just going to say I'd grab a set myself if they were made
Old 08-25-2010, 07:41 AM
S&R Performance
we'll see how it goes. Bushings and some suspension parts are being worked on now.
Old 08-25-2010, 07:52 PM
midz350
midz350's Avatar
In your dreams
Old 08-26-2010, 12:04 PM
S&R Performance
TONS of suspension stuff is done. This thing is going to be a damn go-kart... well, a bigger and faster one but you get the point. more pics, coming soon!
Old 08-27-2010, 07:39 AM
S&R Performance
Default OS G Diff with custom work!
This gem is all set and ready to go!
even a one off, billet collar!
Old 08-27-2010, 10:36 AM
S&R Performance
Default and it's in!
The guys have been hard at work. The turbo system is on, the motor is in and we're on a roll.
customer OS G triple plate clutch kit.
more pics to come.
Quick Reply: The Build BEGINS! Gamermodz/GReddy/S&R Z goes under the knife!
