Differents in OEM suspension between years
I am trying to find out whats the differents in the Stock OEM Suspension between the years of the 350Z, thats would be including the different models available, like convertable, performance, track, etc. I hear that there are different spring rates in the rear from 03-04 and 04.5-05, but when i try looking for part number I see there there are different number for cars coming with and without the 18in wheels. I am also looking in to the differents in shocks.
The reason I am asking is cause I have a G35 sedan and am looking to lower the car with the stock 350Z suspension. I have a set 03 on now but the car seems to bounce alot. I am not looking for that. I just put on a set of the stiffer 04.5 rear springs and it seems to still be bouncing. Can someone please let me know. If someone has a list of part number for the shocks or/and springs please list them here.
Originally Posted by Speedracer
The bouncing occurs because the dampening ability of the shock is inadequate for the spring rate under a given load condition. Are you using both the Z springs and shocks, or just the springs? Also, the G is heavier in the rear than the Z. Your best bet is to get the Nismo suspension for the G35.
The G's added weight doesn't help a already well defined oem 2003 Z suspension behavior. Pretty much every work typed by a large mass of 2003 Z owner's here matches up exactly to how the same suspension behaves on a G35 sedan or on a G coupe. And the G35's longer wheelbase does nothing to help insulate it from this trait. The oem spring rates on the 2003 Z are the same as on a 2003 sedan with the sport suspension, same as on the G35 coupe, all use the same oem sway bars too, not until the 2004.5 Z changes did we see this change.
The Nismo sedan suspension is a whole different animal vs the same thing for the Z, though both use progressive springs. $1600 for a 1" progressive spring drop that is hardly any stiffer then the oem springs on non adjustable dampners. Tokico D-specs on Tein 350Z H-techs would be a vastly superior choice, linear springs on a 1.3" drop with adjustable dampenrs all for about $780. The bilstein pss coilover system would also be a better choice, monotube dampners with height adjustablity for about $1200 shipped.
tm9293
North East Marketplace
13
10-17-2015 10:14 PM
