Where to place Radar Detector???? :confused:
Old 11-14-2007, 05:19 PM
yuri
yuri's Avatar
Default Where to place Radar Detector???? :confused:
I have an 03 Z and the only place that I have an outlet for my radar detector is in the back???? any advice from you z owners out there????
Old 11-14-2007, 05:24 PM
Sean
Sean's Avatar
isn't there one about a foot below your cup holder?
Old 11-14-2007, 07:40 PM
nothix
nothix's Avatar
I have mine running across the center console and its annoying as hell.
Going to run the cable through the dash within a week or two.
cheshirecat79
cheshirecat79's Avatar
Use the one under your cup holder, mount it on top of your dividing partition and use the rear one, or hardwire it and latch it onto your rearview.
Old 11-15-2007, 04:09 AM
StreetOC192
StreetOC192's Avatar
Not in an '03......that was an addition on the '04.5 I think.
Old 11-15-2007, 04:10 AM
StreetOC192
Best bet is to hardwire it.
Old 11-15-2007, 04:22 AM
NismoZ350
NismoZ350's Avatar
I have an 03 as well. I have mine wired into my rearview mirror and attached to the stock of the mirror with a specially designed bracket.. The wires are almost invisible and it almost looks like it's part of the mirror. Just do a search on "radar detector" and you'll find all the parts you need to do this on here. It's like 40 bucks I believe.
Old 11-15-2007, 04:26 AM
NismoZ350
NismoZ350's Avatar
Here is the bracket:
http://www.countryjoycrafts.com/Conn...arDetector.htm
Old 11-15-2007, 04:28 AM
NismoZ350
NismoZ350's Avatar
and here is the cord:
http://www.invisicord.com/
10 minute install.
Old 11-19-2007, 12:50 PM
tquill
tquill's Avatar
If you don't have the homelink mirror, then you can't hardwire it to the mirror. I hardwired mine to the fuse box, real simple... like 10 minutes max. PM me if you want more details.
Old 11-20-2007, 05:30 AM
therock2689
therock2689's Avatar
I ran a wire under the dash and put a cig lighter end of it so i didn't have to mangle the end of the radar. I also have it placed on the bottom of the a-pillar. looks good and clean and works great.
Old 11-20-2007, 05:43 AM
Z04
Z04's Avatar
+1 agreed. looks 10 times better
Old 11-20-2007, 06:17 AM
Paul350Z
Living in 350Z
Paul350Z's Avatar
The radar detector itself needs to go high in the front window. If you've added tint to the windows you'll have to make sure that they're not metallic based as that's a double whammy. The same metal partials which will block your radar detector's view of the world will increase the reflectiveness of your car to the po-po's radar beam.
Hardwiring is just dead nutz simple.
BTW: V1 and be done.
Old 11-20-2007, 11:23 AM
BlueZ33
BlueZ33's Avatar
i have an 03 as well with the same problem so i just went out and bought the solo s2 cordless and just run that, but good luck
Old 11-21-2007, 05:54 AM
tquill
tquill's Avatar
Return it and get your money back... the solo 2 is horrible.
http://www.guysoflidar.com/august-20...ctor-test.html
http://www.valentine1.com/cordless/
Old 12-16-2007, 12:52 PM
Z_Youlater
Z_Youlater's Avatar
I let mine sit right on top of the 3 gauges, and i ran the wire behind/under the airvent that blow the front winshield. YOu dont see any wires at all hanging out. I'll do a write-up and have pictures later.
-Tu-
Old 12-16-2007, 01:12 PM
TheProfessional
TheProfessional's Avatar
Do it right the first time, follow my instructions:
https://my350z.com/forum/audio-and-video/178934-valentine-v1-intall-pics-hardware.html
Old 12-19-2007, 11:03 PM
Z_Youlater
Z_Youlater's Avatar
I placed my radar on windshield like everyone else, but what i did was ran the wire beneath the dashboard (how to take it apart step-by-step is here http://liljerk.morpheus.net/350Z/dash_removal/), and just snip the wire like 3-5 inches from the cigarett plug, so its easier to run the wire. I will post up pics later.
All you can see is a small 2 or so inches or the wire coming out from the airvent below the winshield when the radar is unplugged.
-Tu-
Old 12-25-2007, 05:50 PM
MIKE3348
MIKE3348's Avatar
-Tu-
Z_oulater,
I make mounts that clamp to the mirror mounting shaft. Most people use the Invisicord and tap into the mirror power. I have mounts for the V1, Escort and Bel detectors. I have sold hunderds to forum members. PM me for details. Enclosed are a couple install pictures.
mike3348
Attached Thumbnails Where to place Radar Detector???? :confused:-v1side-view.jpg   Where to place Radar Detector???? :confused:-v1-windshield.jpg
Old 12-26-2007, 07:28 AM
Daytona350Texas
Daytona350Texas's Avatar
Mikes mount + hardwired
Only way to go for me
Quick Reply: Where to place Radar Detector???? :confused:
