brake boosting a TT 350z.
Old 11-19-2006 | 03:03 PM
phunk's Avatar
phunk
CJ Motorsports
Default brake boosting a TT 350z.
Has anyone here tried disconnecting ECU pin 101 and then went out and tried to brake boost?
I been meaning to try this, somewhere in the manual it told me that if the ECU doesnt see the stoplamp signal on pin 101 for a certain time frame, it will trip a CEL. I was thinking of installing a pushbutton disconnect for this ECU pin for when I want to brake boost and do burnouts - that **** aint easy when your ECU is closing the throttle (that it does when it sees brake and gas at the same time).
Haha, have any of you tried brake boosting how the car sits? It just stops like normal almost as if your not on the gas at all = FTL.
BTW those who dont know WTF im talking about, it says in the service manual that pin 101 is used to show the ECU when you are pushing the brakes - and the ECU will close the throttle even if your on the gas pedal when it sees the stoplamp signal on this pin. This means no brake boosting, and makes it a pain in the *** to do good burnouts if your not in the waterbox.
Old 11-19-2006 | 03:07 PM
Mike Wazowski's Avatar
Mike Wazowski
There is a member that sells the by pass for this. KP Technologies I think that is it
Old 11-19-2006 | 03:09 PM
TheCajunStyle's Avatar
TheCajunStyle
I installed a switch next to the TCS button for the purpose of heating my tires up at the track. It took all of about 45 minutes. I haven't tried brake boosting on the highway; the BB530s spool in about .2 seconds...
Old 11-19-2006 | 03:10 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
you be the first and they will follow!!! you will go down as the man who saved brake boosting for all of us!
Old 11-19-2006 | 03:14 PM
phunk's Avatar
phunk
CJ Motorsports
well, since I run the FCON I have that spacer harness that would make it a super quick and easy job to wire this. I plan to take the car out a couple more times this year. I have all of this week off, perhaps I will give it a shot - Hope my tune is good in those areas of the map!!!!
Old 11-19-2006 | 03:43 PM
taurran's Avatar
taurran
I have a VDC kill switch wired into my console that does the same thing as pulling the fuse. I've been meaning to try brake boosting but up until recently I've been in bad need of new rotors pads. I just took care of that so I'll give it a try the next time I'm out.
It took me about 20 minutes to wire in my switch, and did it on the orange wire in the center console just under the coin holder.
Old 11-19-2006 | 04:25 PM
tig488's Avatar
tig488
my car does it even with the vdc off, it pretty much dies if i push the gas and brake together.
Old 11-19-2006 | 05:29 PM
phunk's Avatar
phunk
CJ Motorsports
yea, the deactivating the VDC does not fix this, this is a seperate issue.
Old 11-19-2006 | 05:35 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
id love to see a huge writup with pics!
Old 11-19-2006 | 05:40 PM
booger's Avatar
booger
Phunk
I have the switch hooked up to the brake light fuse . It works great , can sit and do a nice burn out . The only problem I've found is all the CEL, VDC , and slip lights come on untill you turn off the ignition and turn back on
Old 11-19-2006 | 07:21 PM
doug's Avatar
doug
thank you for explaining this.. i have been trying to tell these tards that turning off your VDC doesn't allow you to brake boost
Old 11-19-2006 | 07:40 PM
phunk's Avatar
phunk
CJ Motorsports
Originally Posted by booger
Phunk
the brake fuse eh... what you can do that should eliminate the trouble lights from coming on is by putting the switch just on the wire that goes to the ECU... well maybe anyhow, I would FIGURE you could get away with it for logn enough to do what you gotta do at least before the system catches on. By just disabling that single pin to the ECU, the brake lights and everything else would work perfect.
Old 11-19-2006 | 07:43 PM
taurran's Avatar
taurran
Maybe next you can explain to us how you manage to be on the rag every day of the month.
Old 11-19-2006 | 07:53 PM
failsafe306's Avatar
failsafe306
lol
Old 11-19-2006 | 09:20 PM
maximumsportZ's Avatar
maximumsportZ
Rode in Sharif's car and he was doing it. I believe he disconnected a relay behind the brake fluid bottle.
Old 11-20-2006 | 12:02 AM
silver nismo's Avatar
silver nismo
ok i have a question do u think u will have the same if u installed a line lock for the braks so u can do a burn out... I did this in my car but i cant tell u anything yet the car will b out on Sat. but i think this will solve the problem... or at least I hope so
Old 11-20-2006 | 01:27 AM
phunk's Avatar
phunk
CJ Motorsports
silver nismo, yes it will solve the problem as long as your not pressing the brake peddle while trying to give it gas. the line lock allows you to let off the brake while during the burnout.
Old 11-20-2006 | 02:45 AM
silver nismo
ya i know it will allow me to let go the break pedal but i was wondering if the front braks r still on thats what i was wondering about.
Old 11-20-2006 | 03:48 AM
doug's Avatar
doug
same way your daddy does
Old 11-20-2006 | 04:30 AM
booger's Avatar
booger
Wouldnt it still make the trouble lights come on ? The signal would still be missing if the switch was on the one wire going to the ECU`. Dont know ....just guessing
Quick Reply: brake boosting a TT 350z.
