5AT: A detailed look at the trans used on 5AT Zs/Gs
Old 08-27-2007, 08:50 PM
MIAPLAYA
MIAPLAYA's Avatar
Default 5AT: A detailed look at the trans used on 5AT Zs/Gs
I haven't seen these posted here before but I found them on a Titan site. The Titan uses the same trans as the Z/G. The links include a 3 part article on the trans and there is one attachment that has rebuild info for the trans. I see tons of people asking questions about their tranny and what it can hold but there doesn't seem to be a lot of info about the trans itself. Enjoy!
Part 1:
http://turboneticsownersclub.com/simi/5AT1.pdf
Part 2:
http://turboneticsownersclub.com/simi/5AT2.pdf
Part 3:
http://turboneticsownersclub.com/simi/5AT3.pdf
Rebuild Info
http://turboneticsownersclub.com/simi/5ATREbuild.pdf
BTW mods can we get a sticky assuming this is new info..
Old 08-28-2007, 03:02 AM
NETSHARK
NETSHARK's Avatar
MIA WOW This has to be the Dictionary of the 5AT thanks alot for posting it !!
Old 08-28-2007, 05:49 AM
roncfpz
roncfpz's Avatar
Excellent info Rob. It is a complicated trans to say the least. Heat is the killer. The "failsafe mode" is troubling but it works in saving the transmission from damage. I had it twice with my old transmission and that one now is in another car working extremely well.
Old 08-28-2007, 06:54 AM
MIAPLAYA
MIAPLAYA's Avatar
I'm glad this info was worthwhile. It certainly does give us a look into why having a "built" auto is so expensive and tough to do.
Old 08-28-2007, 08:59 AM
ZU L8R
Viper Sellout
ZU L8R's Avatar
stuck
Old 08-28-2007, 09:49 AM
Twinturbo2800
Twinturbo2800's Avatar
nice read for later.
Old 08-28-2007, 10:54 AM
Z MANIA
psychedelic one
Z MANIA's Avatar
Yikes! I hope there's not going to be a short quiz next period, because my heads spinning with so much information. Very interesting though...thanks.
Old 08-28-2007, 11:28 AM
Sharif@Forged
Forged Performance
Sharif@Forged's Avatar
Good stuff...I saw this article in one of the truck mags..can't remember which one. Thanks for sharing.
Old 08-28-2007, 08:40 PM
helldorado
helldorado's Avatar
Its good info, but I would consider it the "idiot's guide" to the RE5R05A. The FSM contains all this information and world's more, just in less layman's terms so it takes a bit more to understand. Still, a good primer for anybody new to this transmission who doesn't want to be overwhelmed.
Also, the rebuild info you posted is the general rebuild kit, not an upgrade kit. Here is the info on the Alto Red Eagle rebuild kits that would interest most people in this forum.
http://www.altousa.com/np136.pdf
Old 08-28-2007, 08:58 PM
MIAPLAYA
MIAPLAYA's Avatar
Thank you for adding that. For some hopefully those articles are much easier to understand than the FSM which can become cryptic at times.
Old 09-01-2007, 05:07 AM
MardiGrasMax
MardiGrasMax's Avatar
There done! Yey!!!!!! Thanks!!!
Old 09-05-2007, 02:04 PM
MardiGrasMax
Here is a link to the place selling the clutch kits
http://www.transmissioncenter.net/Nissan_RE5R05A.htm
$252 for Alto Red Eagle/Kolene parts, not too bad at all!
Old 09-07-2007, 01:19 PM
failsafe306
failsafe306's Avatar
I'm assuming the Titan uses a beefier TC and VB?
Also, I'm assuming that a Titan engine should bolt right up to 350Z 5AT, right?
Old 09-09-2007, 07:46 AM
helldorado
helldorado's Avatar
Titan has a much larger torque converter and bellhousing that is designed to handle the V8's torque and abuse of moving heavy weight wiht load, so they won't bolt right up. But the internal clutch packs are identical to what is on our vehicle.
Old 09-27-2007, 09:19 AM
ajcool2
ajcool2's Avatar
I have a modification on my maxima where I hooked up a switch to my line pressure solnoid to make it shift at full line pressure when I go WOT. Could this be done on my Z?
Old 09-27-2007, 09:30 AM
marques1
marques1's Avatar
would this act like a valvebody upgrade
Old 09-27-2007, 09:34 AM
ajcool2
ajcool2's Avatar
Yes the transmission shifts the same as if I upgraded my valve body. Saved me $400.
Old 09-27-2007, 09:44 AM
marques1
marques1's Avatar
I'm also very interested in this if anyone could answer the question ajcool2 is asking. Hey aj dont you have a 5at z do you have any launch techniques you could share with me i understand you hold your own at the drag strip. Oh one more thing how does the valve body upgrade work their has to be a difference though don't you think between a switch on your solenoid line and the valve body upgrade.
Old 09-27-2007, 10:03 AM
ajcool2
ajcool2's Avatar
This thread should answer most of your questions. Mainly post #33 and #34. http://forums.maxima.org/showthread.php?t=208756 Of course this applies to the maxima but hopefully some of the Z gurus can apply this to our cars. I know the main difference is that the VB mod always shift hard no matter what and with this mod it can be turned off if you want your smooth shifts back. I know someone with the vb mod in his maxima and he says it shift the same as my car. I've been using this mod on my max for 2.5 years with 172000 miles on it and my transmission has been fine. As for the my launching techniques I'll pm you.
Old 09-27-2007, 10:13 AM
marques1
marques1's Avatar
oh ok cool well hopefully we can do this to the z im very interested in this. Well this cause you to run better 1/4 mile times because of crisper shifts or would you not notice the difference. I will check my pm for the launching techniques and thank you very much.
Quick Reply: 5AT: A detailed look at the trans used on 5AT Zs/Gs
