Bumping timing question
Old Dec 27, 2007 | 07:57 AM
PM-Performance's Avatar
PM-Performance
Default Bumping timing question
Is it possible to bump timing on this motor? If so has anyone done it to test the affect and know the base timing and a safe range for a change?
Just thinking of free mods yesterday. I was thinking about trying it on my Pathfinder cuz my friend did that and a K&N on his and he said it helped his gas mileage and maybe a tad more umph.
I was thinking about maybe trying this on the Z also.
Sorry if this sounds stupid. I haven't done any research on this car yet or touched anything. So Im kinda new to whats in this thing and what can and cant be done.
Old Dec 27, 2007 | 08:03 AM
rookie's Avatar
rookie
The dealer can do a +2 with the consult, it can also be done with the cipher program.
Old Dec 27, 2007 | 09:22 AM
PM-Performance
More details please? Something thru the ECU I am assuming since this is DLI?
I am sure dealers would not want to do this or would charge to do so with much questioning.
Old Dec 27, 2007 | 09:29 AM
rookie's Avatar
rookie
The Consult II or III is the handheld diagnostic device used by the dealer. Not sure on the HRs but the DE and the rev ups have had +/-2 degrees of adjustment in the factory ecu. Some dealers are a little more versed with the Consult than others.
Cipher is available from uprev. It has some cool functions including the timing adjustment and monitoring of the factory sensors.
Old Dec 27, 2007 | 09:32 AM
PM-Performance
ahhhhh. Hmm, let me check into that with someone at the dealer that I know
thanks.
Old Dec 27, 2007 | 11:57 AM
PM-Performance
Nissan dealers crack me up. So much for free gains.
30 min labor for each vehicle.
Old Dec 27, 2007 | 12:09 PM
rookie's Avatar
rookie
I've heard of any where between free and 1 hour of labor even though it takes about 5 minutes. Have also heard techs saying it won't stay due to vaiable timing but it does stay. What's the btdc on the HRs? Should be a sticker under the hood I think.
Old Dec 27, 2007 | 12:23 PM
warmmilk's Avatar
warmmilk
Not sure on the HR
non of the DE tuners or timing adjusters or any stuff like that works on the HR, cipher doens't work on the HR
Old Dec 27, 2007 | 12:25 PM
rookie's Avatar
rookie
That was going to be my next question if anyone had contacted uprev. They have not updated the cipher for a while now. Technosquare can probably bump the timing if the ecu has been unlocked already.
Old Dec 27, 2007 | 12:29 PM
PM-Performance
they said only 2 degree max and then it will kick back if past that.
I know it cant be a labor intensive job. Yea well, the gain is prob not worth the effort. Just kinda thinking out loud. bleh
Old Dec 27, 2007 | 12:31 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
If you find someone with a cipher in your area they can hook up to the car and do it.
Old Dec 27, 2007 | 12:35 PM
ZLadie2000's Avatar
ZLadie2000
I got this done as a friend of mine works at a dealer, it does only take 5 mins. Not sure about the gains though, had my car dynoed and it dynoed less than stock, granted my filters were VERY dirty, but removing them only gained me 8 hp and I still didnt hit the 265rwhp i hit stock...in other words the gains are questionable...I think it may kick it back.
Old Dec 28, 2007 | 04:40 AM
tourinz's Avatar
tourinz
I have recently done it in my car, I had to use the Consult III to do it, it wouldn't take it on consult 2. Definatelly felt a diference on higher RPM's. planing to get my car dinoed to see the results. The only thing about upping your timing is that you have to run 93 octane not 91, b/c it could create some pinging. I also run octane booster w/ every tank, diference definattely present there, will post dyno results as soon as they are done
Old Dec 28, 2007 | 08:38 AM
PM-Performance
I run 93 all the time anyway on the Z.
Curious to see if there are results though.
Old Dec 28, 2007 | 08:49 AM
ZLadie2000's Avatar
ZLadie2000
The only way to see true gains from the mod would be to do a before and after right there on the dyno. and maybe an after a month later to make sure ecu hasnt corrected...
Old Dec 28, 2007 | 02:38 PM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
We have a consult III here and I'm not able to adjust the timing correction to a positive number on my car. I can pull timing out, but it won't let me add any timing.
It may just be the card/program in the consult, I'm not sure. I haven't really looked into it too much.
Old Dec 29, 2007 | 05:17 AM
tourinz's Avatar
tourinz
Ok, did it on a friends car.... on his car it wouldn't take it on consult III (kept freezing the program) but it did take on consult II... odd
Old Jan 21, 2008 | 05:48 AM
tourinz's Avatar
tourinz
oK, unfortunatelly I did not do a baseline but this may contribute.... On my current mods (greddy tt exhaust and fujita intakes) + my timing bumped I pulled 294 on a mustang dyno... from what I see it's the largest number on a HR so I dunno what it means
Old Jan 21, 2008 | 07:02 AM
rkemp1's Avatar
rkemp1
is that 294 uncorrected? STD, SAE etc? Cuz I know my car dynoed 292 and Gooey's did 290 but they were uncorrected numbers. As soon as the SAE correction factor was added it brought it back to a more expected 276-285 range. Also I'm not as familiar with the readings from Mustang dynos. I know they say dynojets read high and dyno dynamics read lower.
Old Jan 21, 2008 | 07:10 AM
tourinz's Avatar
tourinz
https://my350z.com/forum/vq35hr/329662-post-here-your-dyno-slips-and-modifications.html
Here is the sheet... I know that in order to calculate what a dynojet # would be I have to add 15% to 294 which would bring me to 328...
