ModBargains.com | Ohlins Road & Track Coilovers | Direct Dealer | DEALS!
Old 06-02-2012, 01:08 PM
ModBargains.com
Vendor - Former Vendor
ModBargains.com's Avatar
Default ModBargains.com | Ohlins Road & Track Coilovers | Direct Dealer | DEALS!
ModBargains.com is proud to announce it's new relationship with Ohlins as Ohlins authorized direct dealer. The Ohlins Road & Track Coilovers are designed for performance on the track while maintaining daily driving comfort.
All of the technology in the Ohlins Road & Track Coilovers for G35/350Z are patented and developed in different racing circuits to ensure that you are getting the best performance suspension parts available. This all results in the very best handling and braking performance in the market. With the Ohlins Road & Track Coilovers for G35/350Z, you will see reduced body roll and an increase in stiffness during spirited or track driving. The Ohlins Road & Track Coilovers are lightweight, corrosion resistant, and fully rebuildable with a two-year limited warranty.
Give me a call at 714 582 3330 ext 8003 or ask for Frank for the best deals period! Or feel free to shoot me a PM or email me at Frank@ModBargains.com.
Benefits:
  • Driver tunable ride height and shocks
  • Significant handling and performance improvement
  • Corrosion resistant finish
  • Dual-Flow Valve technology for maximum traction
  • Expandable needle bleed valve for consistent damping rate
  • Includes all hardware and instructions for installation
  • 2 year limited warranty
Features:
  • Front & rear conventional shocks
  • Front spring rate: 572lbs/in
  • Rear spring rate 315-400lbs/in progressive
  • Front and rear components have Dual-Flow Valves
  • Single-bleed adjuster and preload adjuster
  • Includes dust cover and top mount as applicable
  • Revalvable and rebuildable
Application:
  • 2003-2006 Infiniti G35 (NIS MI00)
  • 2002-2009 Nissan 350Z (NIS MI00)
Ohlins Road & Track Technology:
  • Hydro-Dynamic Damping: The Dual Flow Valve technology is a patented exclusive from Ohlins Suspension that ensure identical response on rebound and compression. This is achieved through a consistent path for damper-fluid in each direction. The results of the Dual Flow Valve technology is the tires quickly return to the ground for maximum traction, giving you daily driving comfort with track driving performance.
  • Driver-Tailored Tunability: Each Road & Track Coilover is height adjustable and properly maintains the optimal piston operating position so that you have control over your vehicle's ride height with uncompromised damping performance. The McPherson struts on the Ohlins Road & Track Coilovers include camber-adjustable upper and lower mounts for fine tuning for the street or the track.
  • Ride-Heat Hydraulics: The damping fluid's reduced viscosity due to heat is managed by an expanding needle bleed valve. When the damping fluid thins, the valve tightens. This technology is unique to all Ohlins Suspension that helps maintain a consistent damping rate during a wide range of temperatures.
ModBargains.com is offline
Old 06-05-2012, 03:52 PM
ModBargains.com
Tuesday bump!
-Frank
Old 06-07-2012, 02:07 PM
ModBargains.com
Thursday bump!
-Frank
Old 06-13-2012, 05:24 PM
ModBargains.com
Midweek bump!
Old 06-14-2012, 11:47 AM
ModBargains.com
PMs replied!
-Frank
Old 06-19-2012, 03:00 PM
ModBargains.com
Tuesday bump!
-Frank
Old 06-29-2012, 03:33 PM
ModBargains.com
PM me for the best deals on Ohlins Road & Track Coilovers!
-Frank
Old 07-03-2012, 02:03 PM
ModBargains.com
Offering great deals on Ohlins coilovers! PM me for more details!
-Frank
Old 07-04-2012, 10:20 AM
arcada
arcada's Avatar
Price to 92708.
arcada is offline
Old 07-05-2012, 03:36 PM
ModBargains.com
Originally Posted by arcada
Price to 92708.
PM sent!
-Frank
Old 07-10-2012, 10:35 AM
ModBargains.com
Give me call at 714 582 3330 ext 8003 for special forum member pricing!
-Frank
Old 07-11-2012, 04:05 PM
ModBargains.com
Need a price match? Give me a call at 714 582 3330 ext 8003!
-Frank
Old 07-14-2012, 09:48 AM
ModBargains.com
Give me a call today at 714 582 3330 ext 8003 for the best deals!
-Frank
Old 07-19-2012, 12:29 PM
ModBargains.com
Give me a call at 714 582 3330 ext 8003 or just ask for Frank for any questions/price quotes!
Old 07-25-2012, 04:55 PM
ModBargains.com
Midweek bump!
Old 08-01-2012, 04:41 PM
ModBargains.com
PM me or give me a call at 714 582 3330 ext 8003 for the best deals!
-Frank
Old 08-08-2012, 10:43 AM
ModBargains.com
PM me today if you are interested in a price quote!
-Frank
Old 08-15-2012, 02:30 PM
ModBargains.com
PM sent!
Give me call for the best deals PERIOD. 714 582 3330 ext 8003 - I'll make it worth your time calling in!
-Frank
Old 08-28-2012, 09:33 AM
ModBargains.com
Looking to purchase today? Give me a call at 714 582 3330 ext 8003 to get the absolute best deal.
-Frank
Old 08-31-2012, 03:17 PM
ModBargains.com
GIVE ME A CALL AT 714 582 3330 ext 8003 to apply your discounts or place your order over the phone!
-Frank
Quick Reply: ModBargains.com | Ohlins Road & Track Coilovers | Direct Dealer | DEALS!
