Time for dyno!
Time for dyno!
Current mods -
Custom Sri (stock maf)
Port and polished lower plenum similar to mrev2
5/16" spacer
Port and polished upper Z1 plenum
EBay catback purchase in good condition from another member here.
May get invidia test pipes installed pre dyno but don't se it happening.
What's everyone's guess/ bet? 06 DE non rev 5AT
I'm putting my money on 256 hp. Trying to be optimistic and leave room for a surprise
Also this is all on stock tune. I want to see what the difference in power will be with no tune vs tune.
Dyno is this Saturday on a dynojet
5/16" spacer
I think it will be pretty interesting since everyone say the mrev2 paired with spacer on de will result in lower power. Although I haven't heard of them p&p the upper plenum as well.
My next step will be bigger injectors and tune, I think with the bigger injectors I would see more power than someone with same setup but with only spacer or mrev2. Although that is just an assumption of more air needs more fuel. But I could be wrong.
Jerz350 -
I can't see sigs on mobile, what are your numbers and mods?
Also the member I purchased the plenum setup w/ spacer from dynod 276whp with other similiar mods and maybe some more stuff he has a de non rev as well.
So hopefully ill get closer to that mark than the 250-255 mark that I believe I will fall into.
Jerz350 -
I think you should land in the mid 250s, but most of your potential gain is tied up in the factory cats. Test pipes would be most beneficial before you decide to dyno tune the car.
I really want to get the test pipes in but I don't think ill be able to before the dyno. But I will for sure have them in before I get a tune. But at least then I will see my gains due to test pipes and tune.
I think my biggest problem will be it running a bit lean due to the plenum. I feel a tune will yield me nice gains.
I made that 276 number with momentum headers and a tomei single exhaust when matched with that plenum combo. I was closer to about 265 when matched with a momentum dual exhaust, motordyne xyz w/resonator, and z1 test pipes.
For sure. Make sure you get the test pipes before a tune. Those factory cats are one of the most restrictive parts.
Renfro, I'm currently with a similar setup like you minus the headers. 276 is pretty darn good. Is that your current setup? Momentum headers, TPs, Tomei full single, and plenum?
And IIRC he sold me his plenum because he was going vortech. And as far as I know his current plenum is the kinetix v+
However I don't know if he has vortech installed yet or not so I'm not going to say he does, and I do recall him saying he was with the single exit, although that could of been someone else so don't take my word for it. But that's just what I seem to remember.
And I agree those are good numbers for a de with boltons. Probably shut a lot of people up that said you can't break 260-270 with boltons on a de. He almost broke 280 lol! cams wouldda got you that far for sure.
Don't get all caught up in dyno numbers op. I've seen a hr can't break into the 13s and a de hit mid 13 second quarter mile times... It's all who is driving... Knowing that your car is running a safe afr is key... My mild mods I was hitting the knock sensor at 220hp.
Main reason I'm even doing it is just to know, and the money the raise for this dyno/car show day is all going to charity so I figure it will be a good time to hit a dyno
I'm more concerned in actually hitting the track just havent had the time or the money when I have the time.
And I agree its all about the driver, I've seen hrs in the 14 second range. Ans I've seen des in the low 13 range so it really depends on how you drive. I won't even try to speculate what times I would get at the track, its a lot different then speculating an average dyno number based on someones mods.
Jerz350 -
Engine has 105k on it,
Results are in though!
Afr was crazy lean in some spots going into high 16's almost 17's I can't upload a pic here but posting a link to photobucket. I am extremely willing to email the pic to someone that can post it up for me tho
Results are 249.55 hp / 229.32 tq uncorrected
238.65 hp / 219.31 tq SAE
Pic is of uncorrected numbers.
Also please remember this is without a tune! And is a 5AT
I think its pretty decent given the miles and no tune or test pipes. And there's lots of room under the curve and is a pretty consistent curve. Definitely can't wait to see what tp's and a tune do.
Also this goes to show a replica exhaust is intact worth a fraction of the cost, pretty much the same results, your just paying for the sound differences IMO.
But also the power could all just be from the plenum and exhaust may have caused lower numbers but won't know til I upgrade, to each their own though.
Thanks for all the interest, hope someone finds this useful!
http://s288.photobucket.com/user/Daniellehyper12/media/Mobile%20Uploads/IMAG1064_zpsszqbxlvf.jpg.html?sort=3&o=0
Again, if someone will upload the pic better I'd be more than happy to email or text it to you
Thanks again!
Thanks again!
