Fuel compensation issues please advise!!
Old 05-24-2016, 07:30 PM
timmays350
timmays350's Avatar
Default Fuel compensation issues please advise!!
Gonna get right to it. Built motor 8.8-1 plus vortech v2 walbro 250, 600cc injectors and tuned with uprev. Runs like a damn dream till about 5400rpm, when my air fuel decides to dip into the tens. Fuel compensation map is set mid elevens but chooses to dip regardless. I'd like to lean it out.... What am I missing??
Old 05-25-2016, 01:25 AM
tcode
tcode's Avatar
You should work on your MAF table first. Then (if needed) fuel compensation.
Old 05-25-2016, 05:59 AM
i8acobra
i8acobra's Avatar
Received 1,267 Likes on 1,015 Posts
This.
Old 05-25-2016, 04:09 PM
timmays350
timmays350's Avatar
MAF table is perfect, idles great, runs fantastic. Just likes to run rich at higher rpms regardless of my table
Old 05-25-2016, 04:52 PM
Conway_160
Conway_160's Avatar
You need to set you fuel compensation table to 100.Then fix your MAF table. If your running rich then your maf table is to high at those RPMS.
Old 05-25-2016, 05:03 PM
i8acobra
i8acobra's Avatar
You're airflow is exceeding the factory MAF's electronic range. You need to adjust the MAF tables to allow a greater range of airflow.
Tintspectrum
04-25-2016 04:24 PM
onagao
Tuning
03-19-2016 08:07 PM
350zDCalb
04-03-2005 09:00 AM
350zDCalb
03-21-2005 02:22 PM
t32gzz
11-24-2004 04:18 PM
Quick Reply: Fuel compensation issues please advise!!
