Idle issues when cold
Old Sep 18, 2010 | 03:39 PM
IvoryPearl07g's Avatar
IvoryPearl07g
SUBSCRIBED!
been fighting with this issue for a year now....i kept wanting to say its camshaft position sensors, but i replaced them with known working ones, and it didnt solve it. i cleaned all the electrical connectors/sensors i could find. checked battery and alternator outputs independently. took off grounding system. checked o2 sensors. replaced cats with GTM test pipes. now i have the headers off as i am looking for exhaust leaks...cant find any.
i have considered selling the car three times now but am hoping the dealers issue a TSB once a resolution is found since stock vq35hr's have this issue too.
Old Sep 18, 2010 | 07:54 PM
singh's Avatar
singh
_______________
whoa i thought i was the only one with this problem..
so I have had this problem for as long back as i can remember.. it does not occur in the morning when I start the car.. but after sitting in my campus parking lot for hours i come back to start up the engine and occasionally it idles very weird - almost like something is stuck in my exhaust system and the engine is choking. Just a few weeks ago i was experimenting with the problem to see why its doing it.. well I haven't found a diagnosis but I did realize that when (sitting in neutral clutch not engaged) i apply throttle slowly and consistently and once i hit 1900rpm it's as if though it's hitting a rev limiter.. and if i put it into gear and start driving my car starts shaking violently and the exhaust sounds different and nasty.. but as soon as i rev past 1900rpm it sounds normal, but once i shift into second and i'm back around 1900 rpm it sounds nasty weird again..BUT after driving for approximately 3 minutes the car runs perfect as if nothing ever happened..
it may have something to do with the ecu and test pipes... this is another thing pushing me to take off my test pipes..
Old Sep 20, 2010 | 01:47 PM
srsairbags's Avatar
srsairbags
same here . . .
Old Sep 20, 2010 | 02:12 PM
Sooner350's Avatar
Sooner350
Check out this thread, https://my350z.com/forum/vq35hr/3078...g-warm-up.html You're definitely not the only one.
Old Sep 20, 2010 | 02:19 PM
MM'08_350Z's Avatar
When that problem occurs does your Oil Pressure guage sky rocket to 120 psi?
Old Sep 20, 2010 | 02:53 PM
srsairbags's Avatar
srsairbags
. . but after sitting in my campus parking lot for hours i come back to start up the engine and occasionally it idles very weird - almost like something is stuck in my exhaust system and the engine is choking. . . . . . i apply throttle slowly and consistently and once i hit 1900rpm it's as if though it's hitting a rev limiter. . . .
i have had this issue with stock cats, hfc, etc etc . . soo be absolutely sure the TP are not the culprit. . (actually they may ease the issue). . . it happened to me tooo just like you said . . and it happens no matter if the clutch is engaged or not . . . . car in neutral or not . . .just like hitting rev limiter at 2k after 5 mins of idle or low rev warmup . . . im thinking ECU mapping issue
Old Sep 20, 2010 | 08:13 PM
singh's Avatar
singh
_______________
okay so test pipes are not the problem. Thanks for the feedback.
It does this every single day. But the weird thing is that it does not do it in the morning when I leave my house. It only does it on my way back from work/school.
So no one has been able to pin point the problem? In the thread someone posted up pics of coolant leaking onto the exhaust manifolds.. but if leaking coolant is the case then wouldn't we eventually start running low on coolant and throw a CEL?
Old Sep 21, 2010 | 06:53 AM
srsairbags's Avatar
srsairbags
Question
my Z is a DD now since my other car broke down . . . and the sad part is that it does it in the mornings too, but the issue is much milder and fades away quicker than the afternoons/evenings (im in Fl btw) . . . . actually as im typing this . . im thinking . . . can the injectors be a contributing factor ?
cause i had an old car which had an issue with injectors getting warm . . losing resistance and robbing good injectors of the open voltage, starving the engine of fuel. . . . . anyone having changed injectors and issue still existing ? ? ? do HR and DE have the same injectors? ? ?
Old Sep 24, 2010 | 09:13 AM
hellsoldiers08's Avatar
hellsoldiers08
Would a injector cleaner could solve the problem?? Even if a injector was going bad we would get a cell light right??
Old Sep 24, 2010 | 12:14 PM
srsairbags's Avatar
srsairbags
i use a can of techron every 1500 miles and always use chevron premium 93 gas. . . have been using since i bought my car . . . issue still exits . .
Old Sep 27, 2010 | 08:48 AM
hellsoldiers08
Hmm well see I had my car sense day 1 and this did happen toll I got my final tune and during that time I changed oil from role purple syn to castoral synthec both were 5w-30. I'm about to change my oil today to amsoil 5-40 to see if it needs a lil thicker oil to be running right. Sorry for all the bad grammar, I'm using my iPhone and my fingers like me to misspell things and ya
Old Sep 27, 2010 | 10:16 AM
armando325's Avatar
armando325
I'm having the same problem. Once I left it in idle without revving and the rpms dropped to 0 and it turned off. My only mod is a Borla TD exhaust.
Old Sep 27, 2010 | 11:30 AM
trodis's Avatar
trodis
/Thread
lapham3
Oct 7, 2022 03:15 PM
liqalu04
Jan 2, 2022 12:58 PM
350z82
Oct 1, 2015 06:25 PM
