Unofficial Enkei Wheels Thread
Old 08-20-2015, 04:30 PM
  #2421
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
Originally Posted by Spike100
10" +38 on the front will appear "tucked." It will not look good on a 350z.
Not to mention, I doubt it will clear the spindle. It would require a spacer of at least 10mm
Old 08-20-2015, 05:31 PM
  #2422
nextcore
nextcore's Avatar
Originally Posted by Austin88
nextcore, that makes sense haha I wouldn't mind doing that. I am pretty new to wheel sizes because I bought my car with aftermarket wheels already installed.
I believe the 10.5 +15 would extend about one inch further in the front than what I have right now. Do your front wheels extend beyond the fender? What tire size do you run?
Thanks!
It does stick out a little from the front fender, id say roughly 10mm ish but that all depends on how low you are and your camber. ive seen someone else run same spec wheels but didnt stick out as much because of his camber setting. I ran 275/35 -18r all around
Also, Terrasmak is right. i doubt you'd be able to clear the spindle with a 10 +38. There was someone who had to run a 3mm spacer to clear the front spindle on a 18x11 +17 wheel.
Austin88 (08-20-2015)
Old 08-20-2015, 05:36 PM
  #2423
zumspeedsupra
zumspeedsupra's Avatar
Enkei RPF1's wrapped in Nitto 555. 18X9.5 +15 front and 18X10.5 +15 rear. Limited edition bronze. 255/35 up front and 285/40 in the rear.
Old 08-20-2015, 06:25 PM
  #2424
Austin88
Austin88's Avatar
Thank you all so much, this has been really helpful! Thanks zumspeedsupra for those pictures!! That is exactly what I have been looking for Can I ask how much lower that Z is from stock?
Old 08-20-2015, 07:06 PM
  #2425
zumspeedsupra
I am on HSD coilovers. Not sure an exact number. Originally I believe we dropped the front an inch and the rear an inch and a quarter. With the new wheels we kept the rear the same and lowered the front about another half inch. I do rub up front slightly. Full stiff setting up front.
Old 08-21-2015, 04:46 AM
  #2426
Austin88
Austin88's Avatar
Awesome, I love how it sits with those wheels.
Old 08-21-2015, 09:00 AM
  #2427
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
I'll play, but it needs a bath.
superlim9 (08-21-2015)
Old 08-21-2015, 03:52 PM
  #2428
superlim9
superlim9's Avatar
so need to get my coils put in .. but only had a few weeks at home last month.. this next month is a trip to hawaii... so probably not going to get it done soon... there always when in storage this winter.. i guess
jhc (08-21-2015)
Old 08-21-2015, 05:25 PM
  #2429
jhc
jhc's Avatar
Specs?
Old 08-21-2015, 05:41 PM
  #2430
superlim9
superlim9's Avatar
Originally Posted by jhc
Specs?
17x10 w/275 square
Old 08-21-2015, 05:42 PM
  #2431
jhc
jhc's Avatar
Sweet, thanQ!
Old 08-21-2015, 05:52 PM
  #2432
superlim9
superlim9's Avatar
Sweet, thanQ!
+38 though... went high and adjusted with spacers to fit more rubber.. 12.5mm up front 10mm in back right now. Will adjust more when I get her lowered a bit. I have about 3mm clearance from the suspension on inside and 2mm from fender fully tucked with no strut or sway bar installed on the front.
Now just have to figure out how much rake I want with the suspension
Old 08-21-2015, 06:01 PM
  #2433
jhc
jhc's Avatar
17s have less weight so less rotating mass= faster off a line. Enjoy your weekend, Super.
Old 08-21-2015, 09:41 PM
  #2434
superlim9
superlim9's Avatar
haha.. wish i could... at work so pulling 12hr shifts, 7 days a week..
7lbs total less on each side on the front... and 1.5 lb less on each rear corner... I've surprised quite a few 370z owners in my club with the gains i have
Old 09-06-2015, 08:48 AM
  #2435
3vilbunny
3vilbunny's Avatar
Hey everyone!
I am wondering what the best RPF1 setup is for autocross / tracking in your experience. I know there will probably be some conflicting responses.
I am switching to 18" RPF1 wheels and my current 19" Volk setup is 10.5" 285 rear and 9.5" 265 front and I have had good handling with a bit of understeer. I want more neutral handling in my Z so I am thinking of going with a square setup (also to rotate tires).
It seems that most people run 10.5" rear and 9.5" front +15 offsets with the RPF1s. I am open to any setup including 10.5" square but I am worried about the front wheels sticking out too far (one inch further than my current wheels). Also, I am not sure what the difference in unsprung weight vs. traction with greater tire width would be if I ran 9.5" square with 275s as opposed to 10.5" square with wider tires. I also don't know if there is a clearance issue with 9.5" in the rear with spacers because it doesn't seem like a popular setup for the RPF1s, correct me if I am wrong.
I am also pretty set on 18" wheels.
Thoughts?
Old 09-06-2015, 10:50 AM
  #2436
mr. sparco
mr. sparco's Avatar
Thoughts?
You worry too much. 10.5 +15 on 275/30 fronts will work with a roll. 18x9.5s are lighter, jhc weighed his at 17 lbs iirc. My 18x10.5 +15 weighed in at 19 and 20 lbs. The weights advertised are not exact from Enkei. I have owned several sets of RPF1s and each time I weighed them brand new, they varied +/- 1 lb from Enkei's quote. Every tire will weigh differently as well, Tirerack usually have tire weights posted. Go back and look through this thread, most people have their wheel and tire specs posted.
Old 09-07-2015, 02:53 PM
  #2437
terrasmak's Avatar
Me and a couple others run 10.5 RPF1 up front with a 285/35-18 , a 275 is easier to fit
Old 09-08-2015, 04:43 AM
  #2438
3vilbunny
3vilbunny's Avatar
mr. sparco and terrasmak, thank you for the responses. I found some more pictures of 10.5" square RPF1 setups and really like the look. I don't know why I thought they would stick out so much. I think I am going to go with this setup.
If you don't mind me asking, what would you have to do to fit 285s? I already have rolled front fenders and no drop in suspension yet.
thanks!
Old 09-08-2015, 07:09 AM
  #2439
jhc
jhc's Avatar
Been pretty happy with my RPF1s, for verification. 18s.
9.5 fr
10.5 Rr
The following 2 users liked this post by jhc:
3vilbunny (09-08-2015), BigBlue (09-08-2015)
Old 09-09-2015, 07:22 PM
  #2440
Hotlaprc
Hotlaprc's Avatar
How much are you lowered?
Quick Reply: Unofficial Enkei Wheels Thread
