Unofficial Enkei Wheels Thread
Old 06-30-2016, 04:03 PM
  #2601
mr. sparco
mr. sparco's Avatar
Originally Posted by dboyzalter
Every time I wash the car I wash the hood with a 3m scotch brite pad...
Scotch brite pad to a car, that's awesome on such a wrong level.
Old 07-01-2016, 12:01 AM
  #2602
armt350z
armt350z's Avatar
I wish those came in a 10.5 width.
Old 07-01-2016, 04:16 AM
  #2603
NA&CH
NA&CH's Avatar
And a tad lighter. That Kojin is a nice wheel.
Chris
Old 07-01-2016, 06:36 PM
  #2604
Sak350
Sak350's Avatar
Unofficial Enkei Wheels Thread-aitkyxc.jpg one of my favorite wheels
Old 07-01-2016, 08:59 PM
  #2605
SonnyWu
SonnyWu's Avatar
Welp put these on... Thanks everyone for all the good information, so far the only regret is not getting them sooner
Remember imitation is the sincerest form of flattery...
Enkei kojin 18x9.5 +15 square 245/40 front 265/40 back
Looking good. Ordering a set very soon.
dboyzalter (07-02-2016)
Old 07-03-2016, 01:00 PM
  #2606
ARRRT
ARRRT's Avatar
Looks like Enkei managed to create a new bestseller)))
Old 07-06-2016, 08:54 PM
  #2607
LowRedRocket 8)
LowRedRocket 8)'s Avatar
Default Bbk fit with this?
Originally Posted by scotts300
RPF1s in SBC with 9.5 / 10.5 +15 offset, 265/35 and 285/35 tires, lowered on BC coilovers at the time. Now lowered on KW Clubsports, and about 1/2" lower.
(also for sale by PM)
would an Akebono BBK fit in this gray Z setup?
Old 07-07-2016, 02:15 PM
  #2608
BakaN20
BakaN20's Avatar
Here she is after a quick optimum no rinse wash. Just used my smartphone, no fancy camera. 50% Cartoon filter.
Old 07-17-2016, 09:57 AM
  #2609
plaight
plaight's Avatar
Default 17x8 RPF1
Has anyone tried to fit the 17x8 RPF1s over the track brembos? These would be scca wheels for c street so I have to stick with 17x8 in the front and 17x8.5 in the rear
Old 07-17-2016, 01:32 PM
  #2610
finewayne
finewayne's Avatar
Enkei always on top
Old 07-17-2016, 10:19 PM
  #2611
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
I would have to reread to rules for CS, but I don't remember being allowed to run a wider wheel. You would need a 7.5 front and 8 inch rear. Then if I remember, up to 5mm difference in offset from stock.
Old 07-18-2016, 06:08 AM
  #2612
plaight
plaight's Avatar
I have an 03 track so the stock wheels are 8 and 8.5 wide. I know the rears will fit. I just want to avoid ordering and returning the 17x8s if I can help it.
Old 07-18-2016, 09:26 PM
  #2613
mr. sparco
mr. sparco's Avatar
RPFs on the X.
Old 07-19-2016, 06:28 AM
  #2614
coletrickle74
coletrickle74's Avatar
Anyone else have a problem with the rears fitting? 10.5 +15/285 tire sticks out about an inch. Everything I read said it should'be fit fine. Hard to see in this pic
Old 07-19-2016, 09:05 AM
  #2615
Phenom
Toasty
Phenom's Avatar
Received 1,382 Likes on 990 Posts
Can you post a better picture? 285 on a +15 wheel should poke a little bit, but nowhere near an inch
Old 07-19-2016, 10:51 AM
  #2616
mr. sparco
mr. sparco's Avatar
285/40 or 35s? Looks like you're at stock height, it'll camber in once you lower the car. I had 285/35 Nitto Drag Radials in the rear, fits with a mild roll. Pic above is with a 10mm spacer, you should have room to spare if on 35 series.
Old 07-19-2016, 06:16 PM
  #2617
coletrickle74
Yeah its definitely not an inch. Maybe the suspension was sitting weird after I raised one side. Tire size is 35
Old 07-19-2016, 11:19 PM
  #2618
XM 1's Avatar
looks just fine to me. and yeah sometimes the suspension gets ****ed when u just raise one side, while the handbrake is still applied
Old 07-20-2016, 05:05 AM
  #2619
Phenom
Toasty
Phenom's Avatar
That looks a little more how you should expect. Also, if you jacked up the car and lowered it back down without rolling the car forward or back at all, the wheels will be sitting slightly off from their default position. If in that picture the car hasn't rolled at all after lowering it back down off the jack, the wheels will pull in a bit when you move it.
Old 07-30-2016, 07:27 AM
  #2620
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Some pics for you...
SonnyWu (08-08-2016)
Quick Reply: Unofficial Enkei Wheels Thread
