Widest set up for stock 18 inch rims
Anyone run a 265 square setup? I'm looking at getting a set of track v2's in the spring but getting 4 front 18x9's instead of the 18x9f and 19x10r. I was thing a 265/40 setup would work. Thoughts?
what are your concerns? 265 square set up will work. im running 275 and l love it. obviously straight line acceleration isnt as good as a 275f 295r, but the cornering balance is alot better. its all a trade off
With those wheels, I would do 255/40-18 square
Why 255 instead of 265? Just curious.
More suitable than 265 for the wheel width. Cheaper. More available.
As for 265 up front. It depends on your offset. You could rub the control arms or if your offset are low, it can rub the fenders.
actually I run a 285/35-18 front tire.
265/40-18 is a bit tall for the front and its an odd size. I try stick to more popular sizes.
on
Hey
I was wondering for future knowledge I was planning on getting 20x9 and 20x10 inch aftermarket rims. I'm going for aggressive tires. And was wondering about what offset should I get so I can get my tires flush with the fendors.
350Z/370Z Tech Moderator
That's a very difficult question to answer definitively without knowing:
1. Your definition of "aggressive tires". You talking about stretch with camber or significantly "meaty"?
2. Your plans for suspension? Stock, sensible lowering for performance or eliminating bump stops and running purely for stance/appearance?
Both of these things affect what type of offset to run... a +15-20 sensible lowering with sensible tires (255/285) or a +0 for use with -3 camber and 245s on those 10s...
IOW, more detail on where you want to take your car = more definitive info.
on
No clearance issues at all. No spacers. This set up, square, incapacitates TC. Even on the street it acts up. It is driveable on the street but TC will interfere a fair amount. On track TC has to be off.
My next set of tires will be 265/40s. I get what terrasmak is saying but: I've driven 265/40s on track and on the street and everything is fine. Hankook makes the RS-3 in that size. TC issues are less with a square set up and, at the tracks I go to the effective final drive ratio is better with the 265/40s. With the 265/35s I'm hitting revs where it is just a tad too late to shift before the corner. With the 265/40's I don't need to shift at all approaching the corner and get better legs in 5th with long straights like VIR. Not sure any of that made sense, but to be clear, that is a track specific issue and it does come at the cost of some revs coming out of tight corners.
ZSpeedPerformance
Body Interior
09-27-2016 04:44 AM
ZFifty
12-02-2015 11:00 AM
