winter storage on 2003
Old Jan 1, 2005 | 07:17 PM
simpley amaZing's Avatar
simpley amaZing
Lightbulb winter storage on 2003
i have the intake and exhaust plugged, there is 44psi in the tires and i have a full tank of petrol with stabillizer. It's been sleeping for about a month now. Is this all i need to do to protect my baby? 8000kms on the engine. NEED HELP. thanx
Old Jan 1, 2005 | 07:28 PM
lunartick13's Avatar
lunartick13
Default Re: winter storage on 2003
I did all of the above with the exception of plugging the exhaust and intake ( not sure why you are doing this) is this to keep the moisture out?
Is you Z inside a garage? or outside.
Simplely amaZing I also put mine up on stands and removed the wheels and batt. Lower windows about .75 prior to batt. removal.
Old Jan 1, 2005 | 07:29 PM
biscotti's Avatar
biscotti
Did you disconnect the negative terminal of your battery? You've got everything else covered.
Old Jan 2, 2005 | 06:56 AM
simpley amaZing
Default Re: Re: winter storage on 2003
i plugged the exhaust and intake with steel wool so criters wouldnt get in there. i was told if i over inflated the tires i wouldnt need to jack it up and would avoid flat spots. i will probably rock her back and forth to aid in flat spot avoidence. yes she's in a garage...not heated. but darn i didn't yank the battery...you think it will leak?...i also kept the windows shut as to keep that sweet leather smell fresh...bad idea too?....i was told to lay down plastic and wood to soak up any moisture...necessary?...how many times have you done this...i want to keep it in show condition which also means i have no under coat...am i beggin for rust problems?
Old Jan 2, 2005 | 02:43 PM
ohw's Avatar
ohw
I pumped up the tires like you did. Lower a small crack for the window to have some air exchange, put a dryer sheet to keep the inside smell good. Left the battery connected and put a charger on it once a month to keep the battery fresh. And put a cover on the car. The engine oil was changed just before the sleep, and the car was carefully washed with the interior vacumned, took out any food or things that might smell. I have been storing one of my cars over the winters for the last 10 years this way with no problems.
If you choose to disconnect the battery, make sure you lower both windows 1st for the Z, this way you won't have any problem when you reconnect the battery.
Where are you in Canada?
Old Jan 2, 2005 | 05:41 PM
lunartick13
Default Re: Re: Re: winter storage on 2003
THe steel wool thing, valid point, I always find mouse turds in my garage during winter and they`re almost impossible to cotrol. Way back (11 yrs. more or less I do recall when I had my Vette. a spider built a web inside the carb. and in spring time I had a hell of a time trying to figure out why my car would`nt start.
Simpley AmaZing I used this method for Winter storage maybe for the last 15 years and I too lay down plastic and a heavy caboard untherneath. As for the batt. the cold can do a lot of damege if it just sits for long periods, recharging once a month should be ok. I preffer to remove the batt. and bring it in the basement. and trickle charge it some where in mid. Winter.
Hope this helps
Old Jan 2, 2005 | 06:28 PM
simpley amaZing
ya..d'oh! playing nfs2 isn't cuttin it either! thanx fer the tips!
Old Jan 2, 2005 | 06:30 PM
simpley amaZing
no is this a bad thing i mean isn't the worst to happen is i will have to boost?...somewhere i read that the Z comes with a power shut off that kills the juice after ten days so it will still start?...no?
Old Jan 2, 2005 | 06:41 PM
simpley amaZing
Default Re: Re: Re: Re: winter storage on 2003
Hope this helps
it sure did. thanx allot hey where are your pics of yer sweet sweet? I posted under the color forum and i thought you'd have some for sure...i couldnt find any
Old Jan 3, 2005 | 12:28 PM
Z'd's Avatar
Z'd
Drain your fuel tank and replace with fresh gas WITHOUT the stabilizer. That crap has no business running through your Z engine!!!!(unless you placed your VQ with a Toro gas lawnmower engine)
Also, you are better off leaving your battery connected and adding a maintainer which will keep the battery charged without overcharging.
Old Jan 3, 2005 | 01:48 PM
lunartick13
Default Re: Re: Re: Re: Re: winter storage on 2003
I `am working on pics, need to upload them and find a host and then figure out how to do it..
Ther`re coming.
Love the L S, nothing like it out there unless you do a custom paint job..
Old Jan 3, 2005 | 01:54 PM
bobS's Avatar
bobS
My x girl's dad stores his shelby gt500, 60 something corvette, a bunch of other old cars in a barn and said u don't need to use stabilizer just fill the car up with gas before storing. Also he said to put moth ***** under the hood or anywhere u don't want rodents b/c mice/rats dont like the smell of them. Disconnect the battery and u should be fine.
Old Jan 3, 2005 | 02:41 PM
simpley amaZing
Default Re: Re: Re: Re: Re: Re: winter storage on 2003
Ther`re coming.
easy...just go to www.photobucket.com (it's free) use the browse button to select from your comp the pics you want posted. submit.
then in this forum (works anywhere in my350Z.com) hit the "IMG" button and copy the "URL" addy from the photobucket site (you'll need to have both sites open when doing this...just get on the internet twice in order to have two windows open) then paste in the spot provided. voila! nice posted pics of yer sweet ride for everyone to drool over! lol
check the 35th anniversary Z:[IMG]img.photobucket.com/albums/v217/mysweetride/350z35th05_04.jpg[/IMG]
Old Jan 3, 2005 | 02:43 PM
simpley amaZing
Default Re: Re: Re: Re: Re: Re: Re: winter storage on 2003
doh! it must have been the picture...it sure is one hot machine!
Old Jan 3, 2005 | 02:48 PM
simpley amaZing
thanx man! ...hopefully she is not your "X" because she found out that you love her dad's gt500 more than her! lol ...just jokes
hopefully he took you out in it at least once!
Old Nov 30, 2006 | 02:00 PM
bamyi's Avatar
bamyi
I'm bringing these "winter" threads back. Why? Cause winter is here and every year ppl will post "how to store for winter", "winter tires" and "winter driving" where there is already tons of these threads.
Old Dec 10, 2006 | 05:59 PM
Reality350's Avatar
Reality350
Bump, for a good tip.
R350z
Old Sep 10, 2008 | 07:50 AM
king007007's Avatar
king007007
This is the first year I am storing my Z over the winter. As the temps can get pretty f'n cold -35 degrees C, what are you guys doing about the coolant? Does anyone replace for winter?
Old Sep 10, 2008 | 08:11 AM
terrasmak's Avatar
A battery tender couldn't hurt.
Old Sep 10, 2008 | 09:10 AM
Category5's Avatar
Category5
What a waste.
