winter storage on 2003
Old Sep 10, 2008 | 09:23 AM
Z04's Avatar
Z04
Originally Posted by king007007
This is the first year I am storing my Z over the winter. As the temps can get pretty f'n cold -35 degrees C, what are you guys doing about the coolant? Does anyone replace for winter?
it is nice to see that the search function does work. now think about your question. what is another name for coolant? here is a hint, it is also called anti-freeze.
did that help?
Old Sep 10, 2008 | 12:11 PM
king007007's Avatar
king007007
thanks for the sarcasm - we can always use a little more
Old Sep 10, 2008 | 12:42 PM
Z04's Avatar
Z04
actually, was being serious and trying to help think through a problem.
Old Sep 10, 2008 | 12:46 PM
Spork's Avatar
Spork
I actually just let my car run over the entire winter period. Keeps the engine good, but goes through a bit of gas.
Old Sep 12, 2008 | 03:55 PM
tchesney's Avatar
tchesney
i read this whole thread...thanks for putting up again :-) however, unfortuantely i do not have the luxury of a garage. any tips on outside winter storage?
Old Sep 13, 2008 | 11:20 AM
Zultimate's Avatar
Zultimate
Not a good idea IMO. Moisture accumulates inside your engine during winter down-time. The only way to get rid of this moisture is to get your engine up to full operating temp and burn it off. If you just start your engine and let it run for a few minutes then all you are doing is circulating that moisture around in your engine - NOT GOOD.
Best you can do for your car before storage is a fresh oil change and fill your tank with gas. No need for gas stabilizer unless it's going to be more than six months. Also a good cleaning/wax job. If you have problems with moisture in your garage then put a moisture barrier under the car. Make sure your tires have good pressure - do not overfill. You don't have to worry about flat spots with today's radial tires. If you cover it make sure it's a breathable cover. Batteries suffer reduced life if not kept charged. Best to take the battery out and connect to a trickle charge (Batter Tender). Oh, and plugging the exhaust with steel wool is a good idea if you have rodent problems.
lapham3
Oct 7, 2022 03:15 PM
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
