RX8 or 350Z.. I have both
Old Dec 14, 2004 | 12:54 AM
  #81
Sins4u33's Avatar
Sins4u33
I too have both of these cars at my house.....
Mine being the Z and my sisters being the RX8....
I drove the RX8 after driving mine for months and i was not satisfied with any good amount of power...it feels as is if i am going slow....the engine rev's soo damn high...and when i was driving up to richmond from NC @ wilmington...it was a good 5 + hr drive and the MPG was rediculous....6th gear @ 80mph was still reving around 4k+ rpms...i was alittle skeptical about this....i think the gear ratio is very high on this and allows for more acceleration...the turning ability on the RX8 is pretty nice though ill give it that....but i dont see the sports car here...no power no torque..and it revs too damn high for my liking...and the motor whines soo much to me...i guess i am too used to my popcharger and plenum....i love the sound of the Z and my engine makes...nothing matches it...the rotary engine is beautifull design but i cant stand the noise....it doesn't feel or sound powerful to me...like in my Z i can feel and hear how fast i am going...and i love it...nothing beats it...
my vote goes to the Z, not just because its my car...but because have such a better time in the Z than in the REX....
Ben
Old Dec 14, 2004 | 05:44 AM
  #82
sgoncalves's Avatar
sgoncalves
Originally posted by x28
The RX7 is defintely a cornering machine, it feels almost like the RX8. The weight is all in the center of the car, so the car is much more willing to turn. Once it turns in, just feed in the throttle slowly and you are pretty much set. It doesn;t have the low end torque liek the Z, so throttle control does not have to be as precise (NOT AS precise for those flamers out there).
I've never driven either the RX7 or -8, but sounds like you're right on the money. Indeed with the Z in the turns I don't think I've even downshifted into first, it's always been around second in the high RPMs and it's definitely very sensitive. What you're saying makes sense about the cornering abilities because with the Z I do feel like I have to be very precise to get out of a turn as fast as possible.
Personally, I love it but it could be because I haven't tried the RXs. I've learned how to handle my Z pretty well, I wonder if it'd make me a better driver in a car more designed for cornering abilities.
thanks man
Old Dec 14, 2004 | 12:54 PM
  #83
x28's Avatar
x28
Ben
You'll have to look at most sports car, they are usually high rev engines. Althought its personal perferences, race cars ARE suppose to have high rpms. M3's and M5's and many other sports car are pushing their redline higher and higher. Mercedes have low redlines, but I never considered Benz as sports car. They are fast in the straight, but they just dun have the sports car feel...
The RX8 is a really easy and fast car. I will say this over and over and over and over again through out this thread. It simply is.
It has really good crash test results too, recieved an award for rollover resistance and got really good results in front and side collosions too!
Old Dec 14, 2004 | 01:05 PM
  #84
x28's Avatar
x28
thanks man
the RX8 will be the car to drive before you drive a Z. Its easier (this is my 1 billionth TIME... getting annoyed yet =P) to drive.
To start race driving, one should start with low powered cars liek Miatas. I know the car is ugly and low powered, but you this is how you learn all the basics. You can just throw that thign into turns and learn how to keep that thing poise and steady throughout the turn. As you do more of that, you slowly learn to feel the car's limit and reactions. A softer and light car will allow the driver to better communicate with a vehicle.
The RX8 is a nimble little car with enough horsepower to give you speed and it has good cornering ability to let you explore the car through the corner without spinning out a zillion time. The Z is more peaky, but its still a very well designed car. Its designed more on the safe side, so you get all the power and everything, then you get that freaking understeer that the deisgners dial in. Designers nowadays think we are all idiots (drivers). THey dun let you switch to the geras you want (automatic and some sequentials), big understeer, and make them super fat (weight) and those added airbags for safety.. well i guess that's a good thing.
Cars deisgned nowadays are just so easy to drive. At least compared to the ones in the old days. Talk about driving a supra or NSX....now .... driving those wild horses will really require some good good technique. Some poeple think they can, but they are only driving like 60-80 percent of the car. If you can truely drive those car to their full potential, man you are GOOD..
Old Apr 6, 2005 | 12:27 PM
  #85
rasp's Avatar
rasp
Originally Posted by Janus
I'm not trying to burst your bubble but...
What were your RPM's when you went onto the ramps?
I highly doubt that the RX8 accellerates that impressively compared to the Z. www.automotive.com lists the RX8 at 197HP @ 7200 RPM with 164ft/lbs torque @ 5000 RPM, and the Z at 287hp @ 6200 RPM with 274ft/lbs torque @ 4800 RPM. Now thats a rather large discrepancy there. Thats almost 100 more HP and almost twice the Torque at slightly lower RPMS. Now the fact taht the RX8 has about 2.5k more RPMS to play with gives it a lot of help... but it has quite abit of a number gap to overcome.
And having swapped cars with my friend who has an RX8, we both agree which one is faster. (And my friend lives in Chapman hills so we are constantly going up hills...)
Again, as per www.automotive.com, it lists the RX8's Curb weight at 3053.4lbs, with the Z weighing in at 3240.8. Thats about 190lbs heaver, which is not that much of a difference. As to handling? RX8 has a wishbone suspension in the front, where Z has Multi-Link...
From driving my friends RX8, I don't remember how the supsension was set up, but I assure you, in my '03 Touring (which is the heaviest of the coupes) with Tein Flex, I experience 0 body roll when I am driving normally, and only slightly when I am cornering hard on freeway offramps. ^_^"
With the RX8, I don't know how well it grips the road. I've never tried the crazy stuff I do in my car with my friends, because, well, its not my car =P
Your experiences may be different however, but I just had to point out the number discrepancies...
I know this was posted along time ago but, you're comparing an auto 8 to a 6sp Z. The RX-8 6sp and RX-8 auto are very different, the 6 speed has almost 50 more horse power, 2 more gears, carbon fibre drive shaft, 9300 redline, better suspension, bigger brakes and wheels, and no power stealing torque converter. You should compare equal cars next time.
Oh yeah, the 6sp RX-8 weighs less, only 2940 lbs.
Old Apr 6, 2005 | 03:17 PM
  #86
Santacruzslick's Avatar
Santacruzslick
Veteran
Way to bring back a dead thread. LOL
Old Apr 6, 2005 | 03:25 PM
  #87
rasp's Avatar
rasp
Well, someone had to correct the guy.
Old Apr 6, 2005 | 03:38 PM
  #88
trefling's Avatar
trefling
It's all about horsepower to weight ratio. That's what made the great 93
RX-7's so awesome and that's what makes the RX-8 cool too. Based on the weight difference of the two I see no reason why the RX-8 couldn't be just as fast over a stretch of road.
Old Apr 6, 2005 | 04:31 PM
  #89
rasp's Avatar
rasp
RX-8: 2940lbs / 238hp = 12.3 lbs per hp
350Z: 3240lbs / 287hp = 11.3 lbs per hp
All this nonsense over 1 pound per horse power difference!
It all comes down to the driver.
Lets not even mention that the 350Z Roadster weighs in at 3462 pounds.
Old Apr 6, 2005 | 08:29 PM
  #90
Wedge1212's Avatar
Wedge1212
That's the boat i'm in right now. I'm of course in the market for a new car. I've got my list o cars
RX8
350z
Evo8
STI
s2k
My parents own and s2k and I drive it just about every time I go visit them. Its a blast to drive and I would definately love to have one of m own. I've test driven the RX and the Z. The Z just feels faster. Secondly I like the way the Z feels on the inside. To me it just feels right to sit in. I still gotta drive the Evo and the STI so the jury is still out on those cars...but from what I hear they're a blast to drive as well. Just throw'n my thoughts into the mix.
Old Apr 6, 2005 | 10:26 PM
  #91
nbdyfcnsqnc's Avatar
nbdyfcnsqnc
>> THe Z wins .. I guess becasue I have the Brembos..
Just a side note here, but the Brembos are just about the same as the standard brakes except they don't fade as quickly with rapid use. That won't come into play in street driving, unless the driver is racing on the street, or is a exceedingly bad driver!
Old Apr 7, 2005 | 02:15 AM
  #92
sselway's Avatar
sselway
Originally Posted by x28
RX8 and 350z.... yay.... now I can drive the one that matches my outfit for that day...
That sounds kinda homo.
Old Apr 7, 2005 | 07:06 AM
  #93
Winchm60's Avatar
Winchm60
Sell the 8
Old Apr 7, 2005 | 07:16 AM
  #94
rasp's Avatar
rasp
The brembo's look awesome, but like you said they only really help on the track. They're not going to make it stop faster.
I was reading some info from the Nissan and Mazda website, it turns out that the brakes on the RX-8 out perform the Brembo's on the Z! (this is only in stopping distance, not fading)
350Z: http://www.rx8club.com/attachment.ph...chmentid=45912
RX-8: http://www.rx8club.com/attachment.ph...chmentid=45913
Old Apr 7, 2005 | 07:37 AM
  #95
tsixr's Avatar
tsixr
I own a 2003 enthusiast and my brother owns the RX8, driving the two is very different. The Z has that great low end torque which I feel makes the car much more fun to drive, the 8 on the other hand needs the crap revved out of it in order to make any type of power. It is quite nimble once you do get it going and I like the smoother shifter feel and the soft clutch. But its makes a funny wining noise as well...I like the sound of my injen and pop charger much more. He has the added convenience of 2 more seats but that comes at a price...specifically getting about 13 mpg and his car not starting with less thta 5k on the odometer...my vote goes to the Z
Old Apr 7, 2005 | 08:23 AM
  #96
rasp's Avatar
rasp
Just wondering, which does your brother prefer?
Old Apr 7, 2005 | 11:04 AM
  #97
tsixr's Avatar
tsixr
That i'm not too sure of, i dont' think he or most guys would come out and say "Your car kicks my cars a$$" but considering his car doesn't start right now and gets crappy gas mileage he might be leaning towards the Z...they he is getting a computer reflash that is supposed to improve the mpg to 19+ from mazda.
Old Apr 7, 2005 | 11:13 AM
  #98
klubhedsi's Avatar
klubhedsi
The two cars at highway speeds arent comparable. The Z is much faster from a roll!
Old Apr 7, 2005 | 11:23 AM
  #99
HeelnToe's Avatar
HeelnToe
but considering his car doesn't start right now and gets crappy gas mileage...
Why won't it start? Flooded?
Most owners typically report around 18mpg, depending on conditions of course. I've never seen less than 16, and never higher than 20.
Old Apr 7, 2005 | 11:31 AM
  #100
rasp's Avatar
rasp
It gets very bad mileage in the city, about 15-16. The highway mileage is much better, around 25. The most I have seen is 28 on the highway and 18 in the city. I get 16 city, 24 highway. One thing that I have noticed is that if I shift at 3k, I get 16/24 city. If I shift at 9k, I get 16/24.
As for flooding goes, there are two main things that cause it.
1) the car must not be shut off until it is in the normal opperating temp.
2) due to the fact that they burn oil, they go through spark plugs fast. The pulgs should be changed every year or 15,000 miles, which ever is first.
If the two steps above are followed the RX-8 will never flood.
