Question About Getting Rims
Old Dec 10, 2004 | 12:28 PM
fblue's Avatar
fblue
Default Question About Getting Rims
I know nothing about wheels. I have the Enthusiast model, so I think I have 17inch wheels. If I want to go get rims, I see that most are either 18in or 19in. Does anthing else have to be done to the car to add bigger wheels? Anyone have any advice on a good place to get rims? Thanks.
Old Dec 10, 2004 | 01:38 PM
DavesZ#3's Avatar
DavesZ#3
You'll probably have better luck posting in this forum:
https://my350z.com/forum/wheels-and-tires-60/
Old Dec 10, 2004 | 02:16 PM
Built2shredZ's Avatar
Built2shredZ
The best place to buy your first set of rims is www.tirerack.com
It will also show you what the rims will look like on the car and what tire sizes you will need to use on those rims...
I buy all my rims and tires from them..
Old Dec 10, 2004 | 02:25 PM
fblue's Avatar
fblue
Thanks, buddy. I'll take a look.
Old Dec 10, 2004 | 02:26 PM
LanceG33's Avatar
LanceG33
Default Re: Question About Getting Rims
Here is very informative 101 on plus sizing your wheels:
Wheels 101
I have bought two sets from Disocunt Tire Direct and they are fast and reputable. They also have the interactive wheel system to see how they look on your car.
Old Dec 10, 2004 | 07:42 PM
kcobean's Avatar
kcobean
The short answer to your question is that no, you don't have to make any modifications to the car to change to a set of aftermarket wheels. Depending on how big you go, rubbing on the fenders can be an issue, but most 19" tires w/ reasonable offsets will fit with no problem.
With a bigger wheel, your speedometer will be slightly off because one revolution of the tire isn't the same as it is with your stock tires. Bigger tires make the car think it's going slower than it actually is.
Bigger wheels tend to bend easier under pothole like impact.
A bigger wheel of equal weight to a smaller wheel will take more initial power to get rotating because the weight is on a larger moment now (further from the hub). Probably not an issue for daily driving.
If you have TCS/VDC, you need to keep the front/rear size ratio within about 3%, otherwise your control systems will falsely detect slip.
Some people have eliminated the stagger (front's smaller than rear's) in their setup, but I wouldn't recommend it since the Nissan Engineers designed the cars handling with this stagger in mind.
Bigger tires will hydroplane easier than smaller tires because the vehicles weight is distributed over a larger contact patch.
If you have the Tire Pressure Sensor system on your car, some mods might be necessary to mount the sensors in aftermarket wheels.
If you have an '03 and you have feathering issues, non-OEM wheels/tires will void the extended warranty that Nissan is offering '03 owners.
Can't think of anything else off the top of my head, but this should get you started.
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
