Help.....sos......help!!!!!!
Old Dec 29, 2004 | 12:43 PM
NoahzBurnt's Avatar
NoahzBurnt
Default Help.....sos......help!!!!!!
I was coming to a stop.....while the car was just about full rest i heard a sping like "SPRUNGGGGG" sound. Now the right rear break squeals like a banshee. WTF is wrong??? I mean I had my wheels changed and they said my front brakes were low but this happened shortly after I left there. Is this something they broke or is this a dealer issue??? But most importantly WHAT THE h*$L is it??????
Old Dec 29, 2004 | 01:23 PM
ANXIOUZ's Avatar
ANXIOUZ
If you just left a shop then it sounds like they may have done it.
Old Dec 29, 2004 | 01:33 PM
350zluvr's Avatar
350zluvr
I would take it back to the shop a.s.a.p.
Old Dec 29, 2004 | 06:02 PM
dirtyelk's Avatar
dirtyelk
u should have turned around...
Old Dec 29, 2004 | 08:33 PM
FLZ's Avatar
FLZ
That's what the warranty is for....not trying to be a smart-***......Good Luck
Old Dec 30, 2004 | 05:45 AM
NoahzBurnt's Avatar
NoahzBurnt
yeah......this blows!!!!! It was not immediately after i left the shop but noone has any idea huh?
Old Dec 30, 2004 | 10:44 AM
skank-a-holic's Avatar
skank-a-holic
Default Re: Help.....sos......help!!!!!!
Originally posted by NoahzBurnt
...I mean I had my wheels changed
what does this mean? did you put on aftermarket wheels? if so, what size and measurments?
...I mean, you dont have like 26's with a +3 off-set do you
Old Dec 30, 2004 | 10:46 AM
skank-a-holic
....also, did you look underneith and inside the wheel from the back of it to see if maybe you picked something up and its lodged in there?
I would jack her up and look
Old Dec 30, 2004 | 04:21 PM
JonsilvZ's Avatar
JonsilvZ
Why dont you check your rotors? I hope you didnt **** up the rotors. Well I had this weird screeching noise coming from the brakes awhile back. Nothing was wrong. I think there was a pebble stuck in the calipers. But it did scared the **** out of me!
Old Dec 30, 2004 | 04:54 PM
kcobean's Avatar
kcobean
I'm gonna guess that you cracked a pad and the sound you heard was the piece of the pad hitting the disc shield. Just a guess, but based on the symptoms, it sounds right. The disc shields are very thin metal. Something hitting them would sound like a spring "snapping".
Old Dec 31, 2004 | 08:42 AM
NoahzBurnt's Avatar
NoahzBurnt
It appears as if the brake noise has dissapated only to be replaced by a sloww"CREEEEEEEk" from the right rear wheel when slowly engaging 1st gear. Also if i tap the gas while in 1st it does the same. Now i draw the wrong attention to my car. I get the WTF is wrong with your car attention and that sucks more than the brake noises.
Anyone??? Suggestions???
Old Dec 31, 2004 | 08:50 AM
NoahzBurnt's Avatar
NoahzBurnt
Default Re: Re: Help.....sos......help!!!!!!
Nah man 28's that spin when i stop....And i chromed the whole car too.....and then i bought the gold fronts for my teeth to match
They are 19" x 10" with a 25L offset and 19" x 9" with a 25 SH offset(i believe)
They fit flush with the fenders tho!!!!
Old Dec 31, 2004 | 08:58 AM
skank-a-holic
Default Re: Re: Re: Help.....sos......help!!!!!!
Old Dec 31, 2004 | 09:00 AM
skank-a-holic
Old Dec 31, 2004 | 10:58 AM
Hogstar's Avatar
Hogstar
I agree with "KCOBEAN" I had it happen on my truck. Same "SPAANG" sound.
Old Dec 31, 2004 | 11:13 AM
RangersRule99's Avatar
RangersRule99
The manual says that the squealing noise is created when the brake pads get low. My honda needs new pads and it is squealing right now.
Old Jan 4, 2005 | 09:14 AM
NoahzBurnt's Avatar
NoahzBurnt
What should I look for to see if this is what caused it???
Old Jan 4, 2005 | 09:44 AM
tacomaboy's Avatar
tacomaboy
You need to pull the wheel and look, not keep driving it, you could damage the rotor and cause more exensive damage. It may just be a low pad. It sounds like you are already grinding though, so you may already need a new rotor.
Not sure what the spring sound is.... but I think the first thing you should do is pull it off and look at it. If you dont know anything about brakes, then have someone who does look at it.
And then have them explain how brakes work to you so next time you can do it yourself
Old Jan 4, 2005 | 09:45 AM
tacomaboy's Avatar
tacomaboy
What you may see are cracked pads...
or very very low pads, and the rotor will be scuffed. If the pad is worn down to the metal, or is cracked, and metal to metal contact has been made, you will need to have your rotor ground, or most likely replaced.
Old Jan 4, 2005 | 09:50 AM
350zluvr's Avatar
350zluvr
I was under the impression that rotors must be re-surfaced prior to installing new brake pads. Is this correct?
