clutch catching very low for everyone?
Old Nov 6, 2002 | 09:51 PM
350zpower's Avatar
350zpower
Default clutch catching very low for everyone?
Is this normal on the 350Z .. ive seen several reports of it but Im wondering if this is true for everyone. My clutch only seems to really catch about an inch off full depression .. my other cars have been a lot more forgiving then this.
let me know if this is true for everyone
Old Nov 6, 2002 | 10:07 PM
myz350's Avatar
myz350
same here, is there a problem with this?
Old Nov 7, 2002 | 02:22 AM
InternetABYSS's Avatar
InternetABYSS
YES......clutch throw is off too in some cars......got mine re-adjusted now i barely push in the clutch for it to work....
Old Nov 7, 2002 | 06:06 AM
ChinaClipper's Avatar
ChinaClipper
Yes - not a problem though.
Old Nov 7, 2002 | 12:46 PM
ztom's Avatar
ztom
Yeah, mine's close to the floor also, but only have 400 miles on it.
On the other hand, my Z32-TT, engages close to the top - have been told I probably need a new clutch, but I'm not sure if I believe that - only has 63K miles, and never been raced or abused. I'm hoping the "under-dash" adjustment will move the clutch engagement closer to the middle of pedal travel. Anyone know?
Old Nov 7, 2002 | 02:10 PM
Zmeflyby's Avatar
Zmeflyby
yea
im havin the same problem..
im gettin my clutch checked tomorrow
Old Nov 7, 2002 | 02:48 PM
cotmfk's Avatar
cotmfk
I'm not exactly sure how to do it on a Z32, since I don't have that kind of car, but yes, the under dash adjustment will change where your pedal engages.
Old Nov 9, 2002 | 03:21 AM
drivebywire's Avatar
drivebywire
I am having the same issue. Zmeflyby, did you get this fixed?
Old Nov 9, 2002 | 03:32 AM
Pitlizard's Avatar
Pitlizard
Same here, clutch engages about 1" from the bottom which seems to casue some standing start stalling and uncomfortable shifting with rev matching.
Is this an easy fix for the dealer?
Old Nov 10, 2002 | 04:40 PM
cotmfk's Avatar
cotmfk
You should definitely get the issue resolved because there could be a number of problems going on. Your clutch could be dragging, meaning it never fully disengages, causing premature clutch wear, and even worse... a fried transmission!
Old Nov 11, 2002 | 09:52 PM
mike952's Avatar
mike952
Originally posted by Zmeflyby
yea
What did they say when you had it checked? This is my first manual, but I think mine is pretty low too...
infact, I have my seat rather forward to I can give it the full push....as a result, my right leg feels a little cramped from what I am used to...
Old Nov 12, 2002 | 06:41 AM
VR3's Avatar
VR3
I would also like to know what came out of the visit.
Old Nov 12, 2002 | 04:17 PM
Ohio350z's Avatar
Ohio350z
I have no problem with the clutch and where it engages. You will get used to it and then you will have no problem with it. I have 2,500 miles on the Z and I don't even think about it anymore. My view is that it actually has a lot of range in the clutch. It starts engaging early but full gripping doesn't take place till you pull your foot back further. I find this allows you to squeeze the throttle and slip the clutch to get great head snapping acceleration off the line. Remember just because it is different doesn't mean it is wrong or broken.
Old Nov 14, 2002 | 11:21 AM
cotmfk's Avatar
cotmfk
Different BAD!!!
(j/k)
Old Nov 15, 2002 | 01:26 AM
drivebywire
I took my car to the dealer yesturday for this particular reason.
He sat with me and watched.
FACTS:
"clunk" sound happens with a jolt on only 1-2 gearing.
I take my foot off or release the gas pedal when I go next gear.
Once I engage the second gear, give more speed.
What am I doing wrong? He told me that I trying on a low RPM. I have been doing this for a long time and never had any problem with that.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
