stray rock hit my windshield on the highway...
Old Nov 7, 2002 | 08:04 AM
themyst's Avatar
themyst
Default stray rock hit my windshield on the highway...
Leaving a crack about 6 inches long near the bottom of the driver's side. I heard that these are repairable... does anyone here have any suggestions for repairing this? I heard that the windshields for 350z's cost a ton (around 2,000) and thats something i can't afford at the moment thanks
Old Nov 7, 2002 | 08:07 AM
350zSpeedRacer's Avatar
350zSpeedRacer
Insurance should cover windshield replacement. The car won't pass inspection with a cracked front shield. Also, there are several places that do fills in the little cracks before they turn into big ones. I don't know if that would be an option for you since you say yours is already about 6 inches.
Just be sure to find a place with a good rep and good luck!
Old Nov 7, 2002 | 08:08 AM
ares's Avatar
ares
Veteran
wooooooo no no no. first off, chipped are repairable, like a little star. not a 6inch crack, not that I know of anyway. it will spider across the windsheild.
as for 2 grand? I sure hope not. my sister cracked her windshield on her grand prix GTP with heads up display, so they had to give it a special coating for reflectivity(word?) on the inside.
even with that special expensive coating it was like 500. a normal should be around 2-300$. unless theres something really special about the Z's windsheild that Im unaware of.
Old Nov 7, 2002 | 08:15 AM
Electro Z's Avatar
Electro Z
Default Your insurance will know
Normally if it was a star they can seal it so it dosent continue to spread .. but if you have a crack that starts at the bottom or is at the bottom of your windscreen then ..yes your insurance.. minus your deductible will cover the replacement...
Good luck!
EZ
Old Nov 7, 2002 | 08:19 AM
ares's Avatar
ares
Veteran
yes, insurance will cover it, but Id bet you have a 500$ deductable. if it is indeed 2000$ then sure use insurance, but if its barely 500$, or less as I suspect it is. then you are asking for a rate hike for no benifit. and if you even call them about it, they might raise you, even if you dont actually put a claim in(this happened to someone, they called to see if it was worth it)
contact nissan and ask for a reccomendation on a windsheild shop that they have experience with, most dealers dont do this sort of repairs, but they know who can.
Old Nov 7, 2002 | 08:21 AM
padam07's Avatar
padam07
Most insurances has a zero deductible on glass insurance so I wouldn't worry about paying anything out of pocket. If and when you do get it replaced I would only ask for OEM equipment so they won't put any aftermarket part in. On some glass it costs a lot with no insurance. I had my windshield replaced in my 1993 Nissan Altima replaced under insurance and they puit the price they charged the insurance company on the invoice. It said that it cost $700. Regular windshield nothing special.
Old Nov 7, 2002 | 09:22 AM
ChinaClipper's Avatar
ChinaClipper
Default Whoa everybody!
You cannot repair a six inch long crack and not expect it to propagate later. I have researched this already. YOu NEED a Nissan windshield if you have the auto-dimming rear view mirror. There is a cable assembly bonded to the windshield to supply the mirror with 12V power. Nissan windshield cost for the 350Z is $985. (NOT $2K!) I would recommend sticking to Nissan and not go aftermarket.
Old Nov 7, 2002 | 09:27 AM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
themyst, where are u in flushing, maybe i can ask around see if there is a good place around ya. a friend of mine just cracked his wind shield on his es300, i'll ask him how much it was to repair. (although his case is more complicated because he had rain sensors in his windshield.
Old Nov 7, 2002 | 09:29 AM
themyst's Avatar
themyst
I'm right around Flushing HS. I work in Mineola though... but if the damage is repairable for <$70, i wouldn't even bother reporting the damage.... thanks for the help
Old Nov 7, 2002 | 09:57 AM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
you are pretty close to me, i'm in whitestone. anyhow back to your window, i just asked one of my friend, who also happens to be my dealer saleman at starnissan. He told me about this company that fix all of their dealer windshield. you may want to give them a call and let them see your windshield, here is the number 718-533-6142, and here is also a beeper number 917-246-3626. i think the compnay is called "clark windshield repair"
good luck. i don't think it should cost you over 200 bucks for the fix. one more thing, because i'm taking my car back to service tomorrow to look at the shifter problem, i wonder if you have some time tonight that we can meet up and if i can check your shifter. thx. pm me
Old Nov 7, 2002 | 10:52 AM
acid burn's Avatar
acid burn
I too got a rock. It hit hard because it came off a truck going the other way. Immediately there was a crater but no crack. Parked it and a half hour later there was an 8 inch crack. I got the chip repair guys to fix it. They did a normal repair on the impact crater and then drilled a hole at the end of the crack and did a repair there as well. The crack has not expanded in 2 weeks.
About the mirror, if you take off the plastic running between the mirror base and the roof you will see that there is a stand alone cable there. Thus, the mirror will work with any windshield you care to use. I did have the glass shop check, and they said it's a "dealer item" so yes a replacement is probably expensive.
Old Nov 7, 2002 | 11:13 AM
BrainStorm's Avatar
BrainStorm
This happened to me the first month I had my SE-R. For everyone's reference, a Sentra windshield was $399.
Old Nov 7, 2002 | 11:24 AM
ZON's Avatar
ZON
Oh ya i hate it when that happens. I had a bad one on my truck and the insurance co. covered it. Two weeks after the new one was installed it happend again. But not that bad. Now there are two of them in that windshield.
Old Nov 7, 2002 | 12:19 PM
I want a 350Z's Avatar
I want a 350Z
Yo, what street do you live on? Next time I'm in Flushing, I'd love to check out your car.
Old Nov 7, 2002 | 12:23 PM
POWERZ's Avatar
POWERZ
Glass should be zero deductible and won't affect your rate.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
JjL
East Canada
Jun 12, 2019 03:04 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
