need best way to make power
Old Jan 20, 2005 | 11:33 AM
1sick350's Avatar
1sick350
Default need best way to make power
Im not sure if this topic has been brought up before but i am just wondering would be some mods that will get me to run low 13s with out blowing it or turboing it. ITs hard to mod without forced induction because its naturally aspirated, but im trying to get about 340-350 to the crank with out forced induciton. Is it just as expensive?
Old Jan 20, 2005 | 12:10 PM
zillinois's Avatar
zillinois
Default Re: need best way to make power
Here's how I got into the low 13's on street tires. I ran a 13.38 my last time out.
Tilton Clutch/Flywheel
3.9 EVO final Drive
LaBree Resonated Test Pipes
UR Y-Pipe
TechnoSquare Reflash
Crank Pulley
About $4500. If you get sticky tires, then you can probably get there with just the 3.9 and Tilton. If you want to get up to 340 to the crank you'll have to add cams, headers, plenum and a really good tune. That will set you back another $3000+. I'm at ~310hp to the crank right now.
Old Jan 20, 2005 | 12:24 PM
sentry65's Avatar
sentry65
the burninator
my setup should be doing what you're looking for as far as power - I recomend getting wider stickier tires (new wheels needed for it) than stock hough - I'm struggling for grip when I floor it
Old Jan 20, 2005 | 01:08 PM
Diesel350's Avatar
Diesel350
Nitrous
Old Jan 20, 2005 | 02:23 PM
BigMoeTaki42's Avatar
BigMoeTaki42
Get yourself some nitrous and a set of sticky tires.
Old Jan 20, 2005 | 04:57 PM
1sick350's Avatar
1sick350
Default Re: Re: need best way to make power
3.9 EVO final Drive
UR Y-Pipe
Crank Pulley
wow this car isnt cheap to mod! I didnt realize that, i mean im only 17. Im going to buy the car in the summer and im just tryin to find out everything about it. I just wann run low 13s so i can compete with my brothers supra befoe who goes bpu plus plus. Which means 500 at the crank viper territory. Ive been in a z and its def a quick and torquey little car, but there is def a noticeable power gap once the second turbo in the supra kicks in. I want it to hang with supra not get walked by it. thanks for info though.
Old Jan 20, 2005 | 06:03 PM
nureulsaranghae's Avatar
nureulsaranghae
hi guys, sorry for being a dumie, but what is a 3.9 evo final drive? and what does it do?
thanks guys
John
Old Jan 20, 2005 | 06:24 PM
PhoenixINX's Avatar
PhoenixINX
Default Re: Re: Re: need best way to make power
bpu++ or whatever isn't going to get you 500...
Stock twins start taking a dump around 420-440, and doesn't deliver NEARLY the torque.
If your brother plans on keeping with Vipers he'll have to go single, add fuel, and management... THEN he can play.
As for your car keeping with it... We aren't driving straight line cars.
Old Jan 20, 2005 | 09:11 PM
Armitage's Avatar
Armitage
thanks guys
John
I'm no tranny expert, but the 3.9 Evo Final Drive replaces the final drive gear in your transmission. In a nutshell, it shortens all the gears, resulting in faster acceleration, but a lower top speed.
I believe installing just the 3.9 Evo Final Drive by itself results in a net loss of .2-.3 seconds off your 1/4 mile time.
Old Jan 20, 2005 | 09:17 PM
drift350's Avatar
drift350
thanks guys
John
it's a replacement of the differential's final drive gear resulting in faster acceleration/shorter gearing.
combined with slicks, an LSD, and a 3.90 rearend, any Z should pull mid to low 13's.
but you'll lose gas mileage on the highway, especially compared to the stock 3.55 rear end.
a friend of mine had a 4.10 in his Mustang... 3500rpm+ at 60mph.
Old Jan 22, 2005 | 05:10 PM
1sick350's Avatar
1sick350
Default Re: Re: Re: Re: need best way to make power
Actually thats wat it makes to the whells (420) if u bpu plus it u can get 500 hp trust me stage one will give u 500 ive seen it. THen again that is pretty pathetic for a supra. ONcee u fid a single turbo supra then there is no point for the z to race it. I mean come one u can get 900 rw of oem parts. wat did u mean by we dont drive straight line cars? I luv the z which is y im gettin it but there is a huge performance gap between the tow one of the best motors to use for mods and can hit 1300 whp. The other is more looks than power. If u single turob a supra and no what ur doing u will make the viper look like nothing. Go to to4r.com and every single person on that site can crap on the viper. There is a guy who has 900 wh hp on oem parts.
Old Jan 22, 2005 | 05:49 PM
Risk's Avatar
Risk
Default Re: Re: Re: Re: Re: need best way to make power
If this is your position, why did you buy a Z instead of a supra??
Old Jan 22, 2005 | 05:56 PM
1sick350's Avatar
1sick350
Default Re: Re: Re: Re: Re: Re: need best way to make power
supra is to expensive plsu dont want the same car as by bro. I like the z in looks more im just tryin to tell the facts not tryin to put the z down. I dont have the z yet ive just seen wat it can do and love it. Im just a fan of the supra and backin it up. Sry if im bein annoyin bro.
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
