Car won't start
Old Jan 30, 2005 | 08:25 PM
kelvin1704's Avatar
kelvin1704
Default Car won't start
My car can't start again. Its only driven 14000 KM...
first incidence, car can't start. then when the mechanic arrive, it suddenly could start again.
second incidence this morning..... wonder it would start later tonight or not...
can anyone analyse or guess what is the possible problem?
i could still hear the car starter click, but it just won't start. its not even making any other sound... only a starter click sound
Old Jan 30, 2005 | 08:42 PM
PhoenixINX's Avatar
PhoenixINX
Is it even turning over?
Dead battery? Do you have interior lighting?
Old Jan 30, 2005 | 09:12 PM
ksj's Avatar
ksj
Starter click but no go could be a bad battery or a bad solenoid. Does it work if you give it a jump?
Old Jan 31, 2005 | 10:53 AM
longbowe's Avatar
longbowe
Check the caps on the battery and make sure there's full contact.
Old Jan 31, 2005 | 11:18 AM
FLZ_Boy's Avatar
FLZ_Boy
Check if the key transponder battery isn't dead.
Old Jan 31, 2005 | 11:25 AM
islandsnow's Avatar
islandsnow
I had a similar thing happen to my old 92 300ZX when it was new, would just stop starting intermittently. The bad thing was it was very intermittent, you could stop 1 mile away, or 200 miles away and you didn't know if you could start it again. It really sucked, I had to tow it home 3 times. After the 3rd trip to the dealer, I was going to call the lemon on the car, but of course they finally traced it back to the starter relay. Not sure if the current Z has this but if it does, have them check that.
Old Jan 31, 2005 | 11:56 AM
BigMoeTaki42's Avatar
BigMoeTaki42
The only thing I can think of is the battery, check that out.
Old Jan 31, 2005 | 03:28 PM
nicolaycastro's Avatar
nicolaycastro
A friend has a chrystler sebring, which used to have this problem, the dealer could not find what the problem was, after 5 times and my friend saying he was going to go through lemon law, they found the ECU had to be reprogrammed. They did that and the problem was solved.
Another one I would suggest is reading the section on the manual that talks about interference with the chip on the key that could couse the chip to not be read good.
Old Jan 31, 2005 | 04:23 PM
BadDriver's Avatar
BadDriver
try pushing the clutch ALL the way down to the floor
Old Jan 31, 2005 | 04:48 PM
FLZ_Boy's Avatar
FLZ_Boy
+ make sure its on neutral too.
Old Jan 31, 2005 | 05:09 PM
kcobean's Avatar
kcobean
Ha ha.....Did anyone else catch this? That was funny!
Old Jan 31, 2005 | 08:02 PM
FLZ_Boy's Avatar
FLZ_Boy
Scratch the transponder battery, that was my bad . Yes, I get branded as an idiot.
Old Jan 31, 2005 | 08:46 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
turn on alarm, then turn it off. then try starting?
Old Jan 31, 2005 | 08:53 PM
xjerseyzfinestx's Avatar
xjerseyzfinestx
Default ...
maybe your z doesnt like you?? have you take it out in snow?..maybe its upset
Old Jan 31, 2005 | 10:59 PM
kelvin1704's Avatar
kelvin1704
sorry for late reply.
The battery is fine i suppose cause i still can have ligths and listen to CD.
Old Jan 31, 2005 | 11:09 PM
kelvin1704's Avatar
kelvin1704
i assume that if i can listen to CD, it should be fine right?
if so, then what is the posible problem?
Old Jan 31, 2005 | 11:12 PM
ksj's Avatar
ksj
Well, the CD uses alot less amperage than trying to start the engine.
Have you tightened the battery cables on the battery terminals? Have you checked that the chassis ground cable from the battery is tightened?
Old Jan 31, 2005 | 11:18 PM
kelvin1704's Avatar
kelvin1704
Alright, I will check that when i go back.
If that is not the problem, anything else?
Old Feb 1, 2005 | 10:50 AM
paul_kemshall's Avatar
paul_kemshall
Transponder interference can cause this.
There is a TSB on it:
http://www.infinitihelp.com/Ownershi.../NTB03-031.htm
Cheers
Paul
Old Feb 2, 2005 | 07:09 PM
seabass's Avatar
seabass
If it is the nats system, then the engine will crank, but not start and the light above the dash will remain solid red.
