Trunk isn't staying up
Old Jan 31, 2005 | 08:51 AM
Synergy350Z's Avatar
Synergy350Z
Default Trunk isn't staying up
Al right well the search is still messed up so I can't find the thread about this. I remember reading something similiar. What's the deal with this? Anyone else experience? Do I need new trunk shocks already? Do I just go to the dealer and have them fix it?
Thanks in advance for the help.
-Travis
Old Jan 31, 2005 | 09:23 AM
mdacko's Avatar
mdacko
do you have a spoiler?
i have the nismo spoiler, and i have to pop the trunk twice to open it, and then soemtimes it doesnt stay up w/ the shocks. theres an added weight in the trunk lid that you can take out, its under the plastic panel on the inside of the trunklid, that should help in keeping it up
Old Jan 31, 2005 | 09:26 AM
King Tut's Avatar
King Tut
Do you have an aftermarket spoiler on your trunk? I don't think I have seen any threads on this other than extra spoiler weight causing issues, but the search works fine for me. It searches all the way back to 2002 posts just fine.
Old Jan 31, 2005 | 10:57 AM
longbowe's Avatar
longbowe
I had a similar problem with my trunk, which popped up fine when I first bought it, but not after it had been fixed after an accident. It's possible the body shop used the wrong spec trunk latch spring, but I'm not sure that they'd had to restore that part. I brought it to my dealer and they installed the stronger spring without a fuss. So maybe even the "good" ones do get weak over time. What year's your Fairlady?
Old Jan 31, 2005 | 11:01 AM
Aggro_Al's Avatar
Aggro_Al
I had my trunk struts replaced under warranty. I had the same problem. I have an aftermarket spoiler but I didn't start experiencing the problem until the weather got colder. The dealership told me that it had something to do with the valves getting stuck in the open position when it's cold. I haven't had a problem with that since they replaced the struts. (knock on wood)
Old Jan 31, 2005 | 11:22 AM
Mantis3024's Avatar
Mantis3024
The weather may have something to do with it. I have 2 other hatchbacks and the hatch on all of them all seem to have trouble staying up when its really cold outside. Ive had my hatch fall on my head several times.
Old Jan 31, 2005 | 12:37 PM
Synergy350Z
Yeah it seems it may be a weather thing. It was fareecing this morning and last night. I'll try it in a few. I also have to click the button more than once to open it like mdacko was saying. There is a stock spoiler on there, can't imagine how bad it's going to be if I add something more. It really seems like the shocks have gone out.
SEARCH function is not 100% accurate. Someone had the exact same problem and I can't find it now. There are plenty of threads on this in the bug report section, I think it just depends on if your looking for something exact.
Thanks for the help guys!
-Travis
Old Jan 31, 2005 | 01:00 PM
xswl0931's Avatar
xswl0931
One word:
Viagra
Old Jan 31, 2005 | 01:38 PM
Aggro_Al's Avatar
Aggro_Al
-Travis
There is a TSB for the hatch lock not releasing all the way. Apparently the stock trunk shocks are not powerful enough. If you have the problem they will replace the trunk shocks with new springs.
Old Jan 31, 2005 | 04:49 PM
BigMoeTaki42's Avatar
BigMoeTaki42
My trunk needs 2 pushes of the button to open it. The shocks aren't very strong either, if the hatch has even a little bit of snow on it then it won't stay open. From what I've heard (from others on this forum), Nissan should fix this under warranty.
Old Jan 31, 2005 | 05:14 PM
kcobean's Avatar
kcobean
Just to clarify this, there is a TSB out for the springs in the black plastic casings on the sides of the hatch. You can pop these off, pull the springs out, put a couple of pennies in each side, and reassemble. It will have the exact same effect as the TSB....longer springs. The struts will only be replaced under warranty if they are in-fact blown out.
Old Jan 31, 2005 | 08:50 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
there expensive but this will do the trick...
http://performancenissanparts.com/ca...oducts_id=1429
use the 10% off on nismo products code Z33FORUM on this item!
Old Feb 1, 2005 | 07:53 AM
jester7500's Avatar
jester7500
LOL, the hatch fell on my head a couple of times too. It only happens when it's really cold.
Old Feb 1, 2005 | 07:57 AM
kcobean's Avatar
kcobean
Well that explains a few things
Old Feb 1, 2005 | 09:04 AM
jester7500's Avatar
jester7500
Hahahah...teh hard-hat i Kepe in meye car isn't not only fhore wurk...(*thinking to myself*...I hope my brain wasn't damaged from all those times the hatch fell on my head)
Old Feb 1, 2005 | 09:29 AM
kcobean's Avatar
kcobean
ha ha....The worst part when that happens (my car does it too, in a big way with the Vizage spoiler on the hatch) is when the metal latch hits you in the back....Ouch!
Old Feb 1, 2005 | 05:28 PM
all_bark's Avatar
all_bark
I aprreciate the offer but to spend over $200 to fix a problem that I should not have to fix.......
no thanks.
BTW - I have the shock problem and the double tap of the remote to open problem as well. (sometimes I want to double tap some of nissan's designers! j/k)
and for those that do not know, that is a mafia term.....
3vilbunny
Jul 18, 2017 05:10 PM
SharX59
Sep 30, 2015 10:54 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
