1st Gear
Old Nov 14, 2002 | 03:01 PM
BacktotheZ's Avatar
BacktotheZ
Default 1st Gear
I'm only getting up to a speed of 13-18mph in first gear before I hit the 4000rpm mark and have to shift. Since I have 200 miles on the car, I can't push it any more. Is this normal, and will I get more performance out of 1st gear when I have more miles on my Z?
Old Nov 14, 2002 | 03:22 PM
WayneTN's Avatar
WayneTN
Well, it is a 6-speed and 1st is geared lower........so you'll have to change a little earlier than you would on a 5 speed, especially since you only want to go to 4k RPMs. When broken in and you can go higher in RPMs, then you won't have to "short shift".
Hang in there until broken in.
WayneTN
Old Nov 14, 2002 | 04:04 PM
vin1024's Avatar
vin1024
you could just start it in second. there should be plenty of torque. that might be a little hard on the clutch for daily use though .
Old Nov 14, 2002 | 04:10 PM
ares's Avatar
ares
Veteran
shift man, 1st gear is actually harder than many cars Ive driven. I drove my last and 10mph was at about 5grand... that was just a pain.
nothing will change about the speed of the car in a specific gear at a set RPM. but as I said, the Z actually has low RPMs for the speed in 1st gear.
I would advice against starting in 2nd gear, if your not willing to shift at 15mph(I shift around 8-10 actually) then you should have gotten manual. thats just how a manual goes. if your on a roll at all, do 2nd, but from a stop, thats how the cookie crumbles.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
