Storing summer tires for the winter
Old Nov 15, 2002 | 10:40 AM
afr0puff's Avatar
afr0puff
Default Storing summer tires for the winter
Are there any precautions I should follow before I put the tires away for cold storage? Should I coat the rubber with some sort of solution to protect the rubber? I don't have a heated garage... is that going to matter? Am I better off putting the tires down in my basement instead?
Old Nov 15, 2002 | 11:31 AM
DCABF's Avatar
DCABF
if you are only storing them for winter they will be fine as long as they are inside somewhere. as far as to where to put them where ever you have space will be fine. If I were you i would make sure the tires are clean and apply a tire dressing to the sidewalls. just my $.02. good luck
Old Nov 15, 2002 | 12:25 PM
justwant1's Avatar
justwant1
afr0puff
What are you putting on for the winter? Did you buy new rims or replacing the tires on the rims you got with the car? Which rims do you have 18" or 17"
Thanks
Old Nov 15, 2002 | 01:46 PM
afr0puff's Avatar
afr0puff
Actually, I'm not getting the Z. I'm waiting on a call saying that my G35c is in. Before everyone begins to flame me, I was told that the Z and G35c share a lot of similarities, so I decided to register on this forum also for general VQ FM info.
I am getting the 6MT with brembo's and 18" wheels. The rotors/brakes are identical I beleive with the Z. There are only three rims that fit over the g35 brembos at this point...
17X7.5 5-114 ET35 SE FOX 5
17X8 5-114 ET35 MM AVIA
17X8 5-114 ET35 MM HT3
All rims are ugly, but I will be going with the FOX 5. Still debating to go with either the blizzaks or the
225/50-17 Pirelli W210 Sno Sport front
225/55-17 Pirelli W210 Sno Sport rear
lapham3
Oct 7, 2022 03:15 PM
Mattg350z
Oct 2, 2015 06:51 AM
