Seatbelt Slapping
Old Nov 19, 2002 | 03:05 PM
DiverDown's Avatar
DiverDown
Default Seatbelt Slapping
Is anyone else having an issue with the passenger side seatbelt slapping the side pillar?
Everytime I drive, I hear the clanking of the metal seatbelt against the plastic of the pillar. It's making me crazy.
Old Nov 19, 2002 | 03:06 PM
I want a 350Z's Avatar
I want a 350Z
Happens on every car...
Old Nov 19, 2002 | 03:07 PM
Z CRAZY's Avatar
Z CRAZY
Charter Member #67
There should be a clip to rest it in that "prevents" the noise.
Old Nov 19, 2002 | 03:08 PM
DiverDown's Avatar
DiverDown
You'd think that they'd have thought of that after driving the car around one corner............
Old Nov 19, 2002 | 03:11 PM
DiverDown's Avatar
DiverDown
Don't remember that happening on any of my other cars/trucks. Not that it didn't, I was probably not as focused on them as I am on the Z.
I have only one solution: Radio Volume.
Z CRAZY's Avatar
Z CRAZY
Charter Member #67
No, I'm saying my car has that. Maybe they added that afterward. My VIN is in the 5000's.
Old Nov 19, 2002 | 03:23 PM
DiverDown's Avatar
DiverDown
Must have....I just went and double checked. Mine doesn't have it. It must be mounted to the pillar to avoid the side airbags, right?
Old Nov 19, 2002 | 03:32 PM
rep15's Avatar
rep15
Does no one read the owners manual or do a search before posting anymore?
Old Nov 19, 2002 | 03:35 PM
^Tyr's Avatar
^Tyr
no its there
go check again
Old Nov 19, 2002 | 03:40 PM
DiverDown's Avatar
DiverDown
So sorry to have wasted your time Mr. Bob........but it did take a lot longer for you to type that little stab than if you had just moved on....
Old Nov 19, 2002 | 03:44 PM
DiverDown's Avatar
DiverDown
I digress....It is there....hiding in the shadows.
Thanks to ^TYR and Z Crazy!
Old Nov 19, 2002 | 03:47 PM
rep15's Avatar
rep15
The post was a rant at not just this post but too many that people just seem to post without any research. How many times has this come up? Rehashing the same topics over and over...........
Old Nov 19, 2002 | 03:58 PM
DiverDown's Avatar
DiverDown
I understand your frustration on this matter but I actually did a few searches here. Nothing was found. Now, the thread I started is the only one showing up in one search and the top ranked thread after searching "Seatbelt".
I've been a member of numerous forums and have had the same annoyances from others not doing a simple search. Also, when people use an attention getting subject line such as: "CHECK THIS OUT", "Help" or anything else vague.
As far as reading the manual...did it. Don't remember seeing that in there.
Again, sorry for the waste of time but in the future, it's probably best if we don't have an answer or anything to lead to an answer, not to post at the risk of elevating blood pressures.
D.D.
Old Nov 19, 2002 | 04:20 PM
BacktotheZ's Avatar
BacktotheZ
How about buckling the passenger side seat belt.....end of
problem.
Old Nov 19, 2002 | 04:24 PM
ares's Avatar
ares
Veteran
pain in the *** for a person to get in...
tho its a real problem getting people to reattach it when they leave. so you end up reaching over at a stop light to do it. but its there, and it does its job... so I cant really complain.
Old Nov 19, 2002 | 04:49 PM
rouxeny's Avatar
rouxeny
Just in case some people haven't figured it out, there IS a clip which holds the seatbelt against the side of the car. There is no equivalent for the driver, so it's a big encouragement for all of you out there who don't wear your belts.
Old Nov 19, 2002 | 05:20 PM
shoalhaven's Avatar
shoalhaven
Cool
Comfortable solution --
Bought 2 sheepskin seat belt pads about nine inches long.
No more noise, AND easier on the neck and shoulders.
Old Nov 19, 2002 | 05:24 PM
ares's Avatar
ares
Veteran
shoulda gotten a powered by nissan belt hehe
Old Nov 19, 2002 | 05:30 PM
WayneTN's Avatar
WayneTN
Default CLIP DURABILITY
For those of you using the clip, I seem to remember that it doesn't look very strong. How's it holding up?
WayneTN
Old Nov 19, 2002 | 05:35 PM
ares's Avatar
ares
Veteran
ummm well... what are you planning on doing to it? the clip lets the seatbelt go if you pull foward to use the belt... I guess if you had complete disregaurd for it, you could pull straight out and bend it... but if a person is that immature, they shouldnt be in the car.
