What is the stock ride height for the z?
Old Apr 14, 2005 | 07:39 AM
KenWH's Avatar
KenWH
Question What is the stock ride height for the z?
Could someone please measure the ride height of your stock z.
Just measure from the ground up through the center of the front and rear wheels to the bottom of the fender lip and post the measurements. I know it won't be to exact but unless someone knows a better way it will do.
I bought my z used from a nissan dealer and it's probably stock height but to me it looks like it may be slightly lowered. Even after adding the 19's which can sometimes make cars look like their a 4x4.
Thanks in advance!!!
Old Apr 15, 2005 | 05:14 AM
Armitage's Avatar
Armitage
I'm pretty sure the stock ground clearance is 4.7".
Old Apr 15, 2005 | 07:07 AM
Fab_vr6's Avatar
Fab_vr6
I also would like to know what is the stock ride height front and back? measuring from the fender to the ground. My mechanic installed my HKS RS coilover yesterday w/o mesuring the stock ride height, now I may need to raise the front by .25 inches and I am not sure if I should do the same for the rear. please help!
Thanks
Old Apr 15, 2005 | 04:44 PM
Kolia's Avatar
Kolia
Ride height is mesured from the ground to the inside of the wheel arch (highest point)
Here we go:
Z Coupe with 225/50R17 front and 235/50R17 rear tires
Front: 681mm (26.81in) Rear: 700mm (27.56in)
Z Coupe with 225/45R18 front and 245/45R18 rear tires
Front: 683mm (26.89in) Rear: 706mm (27.80in)
Z Roadster with 225/50R17 front and 235/50R17 rear tires
Front: 679mm (26.73in) Rear: 699mm (27.52in)
Z Roadster with 225/45R18 front and 245/45R18 rear tires
Front: 683mm (26.89in) Rear: 705mm (27.76in)
Taken from the 2004 Nissan Technical Manual
Old Apr 16, 2005 | 05:41 PM
KenWH's Avatar
KenWH
Thank you, thank you, thank you!!!!
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
