Bleeding Brakes on 04 Touring 6spd (As we speak)
Old Apr 21, 2005 | 10:18 AM
Huckingfellers's Avatar
Huckingfellers
Default Bleeding Brakes on 04 Touring 6spd (As we speak)
Painting my calipers right now. I was just wondering if there are any abs bleeder vlaves anywheres or if it just the ones on the calipers themselves? Also is there any special way I have to bleed these brakes wiht the VDC crap or anything I should know? Thanks
Old Apr 21, 2005 | 10:22 AM
rxtrom's Avatar
rxtrom
When I painted calipers on my other car, I didn't need to bleed the brakes. Why do you want to bleed them?
Stuff in the way from painting them?
Old Apr 21, 2005 | 10:35 AM
Huckingfellers
I need to remove the brake lines take them off , clean them . Using a spray to paint them. THerefore fluid will be lost and and air will arrive
Old Apr 21, 2005 | 10:58 AM
Huckingfellers
anyone?
Old Apr 21, 2005 | 11:44 AM
Balthazar's Avatar
Balthazar
I don't know anyone whos taken their calipers off to paint them, so I cannot be of much help. Just cover the surrounding area with newspaper and plastic bags (over the rotors) and there shouldn't be a problem. ALOT easier than taking them off.
Old Apr 21, 2005 | 12:32 PM
Z CRUZN's Avatar
Z CRUZN
Default Bleeding.........
When I had OEM brakes, I removed the calipers to replace the brake pads & add SS lines & painted them while they were off. When I removed the lines, I merely "capped" the line coming to the brake lines so not much fluid was lost. After re-installing the lines & calipers & while bleeding the brakes, I tapped on the calipers with a soft rubber mallet (covered with a towel) while bleeding in order to "help" remove any air pockets in the caliper reservoirs. That took care of things & led to a good, tight, firm pedal.
samansharif
Sep 25, 2015 12:31 PM
