How to bleed NON BREMBO brakes ??
Old Apr 23, 2005 | 11:36 AM
Huckingfellers's Avatar
Huckingfellers
Default How to bleed NON BREMBO brakes ??
Trying to bleed mine now on 04 6spd touring 18". Bled them 7 times around the car so far! The pedal will pump up hard then a second later go to the floor.? Tried bleeding with key off, on, and car running. In this order. Left rear, right front, right rear, left front. Tell me how to do this properly please
Old Apr 23, 2005 | 05:51 PM
Nforce1's Avatar
Nforce1
I have the same quesiton...
Old Apr 23, 2005 | 06:55 PM
Huckingfellers
I just finally successfully bled my brakes. Got hung up a whole extra day because of 2 air bubbles in the rear calipers that i had to remove the caliper and move it around with a buddy pushing the pedal and me releasing the bleeder valve to get the bubbles to release!
Other than that make sure your resorvoir is always; full start at your left rear, then right rear, then right front, then left front. Dont think the order really matters much but not sure so that is how i did it. The only bleeders are on the calipers themselves, no abs bleeders. You will need a partner ! Have fun
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
samansharif
Sep 25, 2015 12:31 PM
