04.5??
Old May 1, 2005 | 04:31 AM
zownz's Avatar
zownz
Default 04.5??
I know this may be a noob question but..whats considred a 04.5...obviously sounds like a Z that has been made in june/july 2004...but then again some Late 2003's are considered 04's...mines february 2004...is that considered 04.5???
whats the difference anyway?
Old May 1, 2005 | 06:25 AM
DavesZ#3's Avatar
DavesZ#3
I originally found the official distinction between the two on the nissan-tech.com site. You can tell in the VIN numbers:
2004 Nissan 350Z Coupe/Roadster (Coupe VINs up to D*4T160000,E*4T060000) (Roadster VINs from D*4T102001 to D*4T110000 & from A*4T002001 to A*4T010000)
2004.5 Nissan 350Z Coupe/Roadster (Coupe VINs from D*4T160001, E*4T060001) ( Roadster VINs from D*4T110001, A*4T010001)
Mine had a December ('03) build date.
The only major difference was the suspension. There were some minor cosmetic differences like the "padded" console, knee pads, etc.
Old May 1, 2005 | 06:55 AM
zownz's Avatar
zownz
yeah mine has that knee pad as well...what were the suspension changes?
Old May 1, 2005 | 08:06 AM
DavesZ#3's Avatar
DavesZ#3
One complaint with the '03 models was that the ride was too bouncy. There were some minor changes made to reduce the bounce. Can't say for sure what changes were made.
Old May 1, 2005 | 08:12 AM
Jim 350Z Boston's Avatar
Jim 350Z Boston
Correct me if I'm wrong on this, but from what I can gather, a true 04.5 was built at a different plant. In early 2004 Nissan changed assembly plants for the 350Z. The new plant is disignated by the letter M (it's the 11th digit in the VIN #). The letter T indicates that it was built in the older plant.
Old May 1, 2005 | 08:50 AM
zownz's Avatar
zownz
sounds legit..im still trying 2 find something that will tell online
Old May 1, 2005 | 08:53 AM
DavesZ#3's Avatar
DavesZ#3
Not true, mine's a "T". They actually started building the 2004.5's some time in October, the plant swapover took place the last week or two in Dec. if I remember correctly.
Old May 1, 2005 | 08:56 AM
zownz's Avatar
zownz
october 2003? or 2004?
Old May 1, 2005 | 09:03 AM
Jim 350Z Boston
Also, my 04.5 came with the new tred design on the Pretenzas front tires
Old May 1, 2005 | 09:29 AM
zownz's Avatar
zownz
yeah same here..so i asume mine is a 04.5
Old May 1, 2005 | 10:01 AM
smoothludey's Avatar
smoothludey
where do you get your info??? Mine was built in june of 2004 and i have the euro suspension, knee pads, etc...
Old May 1, 2005 | 10:06 AM
Jim 350Z Boston
Check your VIN Number see what letter it has T or M
By the sounds of it you have an 04.5
Old May 1, 2005 | 10:54 AM
DavesZ#3's Avatar
DavesZ#3
2003.
Old May 1, 2005 | 10:56 AM
DavesZ#3's Avatar
DavesZ#3
June 2004 would be near the end of the model year run, so naturally you'd have the 2004.5 version. It really all depends on the VIN numbers, especially if your was built late 2003. Remember, they stop building a model year late in the summer and start producing the next model year in fall.
Old May 1, 2005 | 01:00 PM
zownz's Avatar
zownz
i have M...so thats an 04.5...does it really matter when ordering performance parts...so far it didnt..just curious
Old Nov 22, 2005 | 10:14 AM
FirstZ's Avatar
FirstZ
Another great bit of resource found today, my VIN is JN1AZ34D34M*******, also has the knee and dash pads!
Confirmed, I have a 2004.5! Build date 7-29-04 , first titled 1-20-05, confirmed via carfax.
I think the changes did not address the tire feathering issue, I have VERY slight feathering on my Z after 13K miles. I did notice the ride changes while shopping for the Z, drove a few 03 and 05s
Off topic, but dropping the Z off next week at the dealer for 2 new front tires, alignment, axle clicking and passage window alignment! Getting it all done in one pass!
Old Nov 22, 2005 | 11:15 AM
Plant code
T: Oppama
M: Tochigi
Old Nov 22, 2005 | 03:44 PM
ZZ33bOI's Avatar
ZZ33bOI
wut about if ur vin starts with J? im sure that is manufactor in Japan correct?
Old Feb 20, 2006 | 08:52 AM
highside107's Avatar
highside107
Sorry to bring this back... but I found this after I did a 'search' and I still haven't found an answer to my question even though I'm sure it's been discussed before
Are '04.5 models technically '05's? Or are '05's "newer" than the 04.5's? If they are different, how can you tell? Reason why I ask is because if people with 04.5's sell their car, can they technically say it's an '05 model?
Old Feb 20, 2006 | 09:22 AM
DavesZ#3's Avatar
DavesZ#3
Technically, they're still '04s since that's what it said on the window sticker and all the other associated documents.
